View Poll Results: Do you use your back windows?
all the time
10
8.33%
often
10
8.33%
sometimes, but not too much
28
23.33%
never
35.00%
only when parked
3.33%
i'd use them more if they were automatic
41
34.17%
Multiple Choice Poll. Voters: 120. You may not vote on this poll
Back windows
Old Jul 26, 2005 | 11:53 AM
ccrooks's Avatar
Back windows
Do you use yours?
poll coming...
Old Jul 26, 2005 | 11:55 AM
pcimino's Avatar
I have 7 year old twins. So when they ride in the back (not often) I'll open the vent windows.
Old Jul 26, 2005 | 12:15 PM
RedLineShinka's Avatar
Do they actually help with ventilating the car, in other words, making some sort of wind vacuum? I've noticed that the car is very aerodynamic, meaning that if you're hot on the inside, you ain't gettin' any air if you drop your windows & open the sunroof...
Old Jul 26, 2005 | 12:17 PM
ZoomZoomH's Avatar
Mulligan User
turn your AC to vent instead of recirculate, at speed the vent will have quite good airflow, works even better if you use AC with it :D
Old Jul 26, 2005 | 12:25 PM
ms292399's Avatar
Sadly enough, I've never had them open. I actually forget that the open.
Old Jul 26, 2005 | 12:30 PM
Dima26's Avatar
What do you mean "had them open" Can you open the back windows? Never knew that
On a serious note, I have never used them since the first day when I just opened them to see how it worked.
Old Jul 26, 2005 | 12:31 PM
rotten42's Avatar
Mentalhealth is overrated
only when the kids are back there.
Old Jul 26, 2005 | 12:33 PM
ccrooks's Avatar
turn the vent to vent instead of recirculate... sunroof tilt... back windows open
quite a good breeze
midlifer's Avatar
My 4 year old twin girls love to play with them. I always have to make sure they are closed when I get home in caase it rains.
Old Jul 26, 2005 | 12:43 PM
KYLiquid's Avatar
Oil Injection
i open them when i have all the windows and the sunroof open on a nice night... maby 25% of the time i drive the car.
One night i did leave one of them open, cars in a garage so not much happened but it could have been worse.
i will also 2nd the fact that with just the windows and sunroof open, there isnt much air movement in the center of the car. i actualy like that, cuase it also means less windnoise.
Old Jul 26, 2005 | 01:17 PM
Nubo's Avatar
Lubricious
Hardly ever, but my wife opens 'em any time she drives the car. I know that because she always forgets to close 'em
Old Jul 26, 2005 | 03:27 PM
labutler's Avatar
yeah, had mine open once - when I climbed in the back seat of the car (just to check things out, nothing else) a couple of days after buying it. Took me forever to get the little hicky popped in at the correct angle to hold them open (and I think I'm of average, or slightly above, intelligence). I would definitely use them more if they were power.
Old Jul 26, 2005 | 03:32 PM
fullsmoke's Avatar
Anatomy of a corner...
I broke my arm trying to open it while driving. Just kidding. But think there will be an aftermarket part to motorize this laborious process?
FS
Old Jul 26, 2005 | 03:34 PM
8is>enuff's Avatar
Bland
Constantly. I drive with all the wondows open unless it's raining or 90+degrees.
Old Jul 26, 2005 | 04:07 PM
aggietiff28's Avatar
Mean Green Keeny Machine
Never opened them...not once (and I am a button pusher). I even sat back there one evening with the stereo on and forgot that they were there, maybe I should try it sometime.
Old Jul 26, 2005 | 04:58 PM
1.3L's Avatar
Originally Posted by ccrooks
Do you use yours?
Only to look through. I never open them.
1.3L
Old Jul 27, 2005 | 12:36 AM
Old Rotor's Avatar
I wish they were electric like they were in my '74 RX4. They were great in getting more ventilation threw the car. Or was it in my '79 RX7........anyway it work good. I think I will try them tomorrow if its under 100 deg F. Its been HOT!
Old Jul 27, 2005 | 08:28 AM
msrecant's Avatar
Hubble has been saved!
The '79 RX-7 did not have back windows, unless you modded the fixed side panes on the rear hatch glass.
My 7 year old routinely uses the rear window on her side and complains that it doesn't open far enough.
Old Jul 27, 2005 | 02:17 PM
Frank Patrick's Avatar
You mean those windows open?
Wow!
Old Jul 27, 2005 | 02:43 PM
truemagellen's Avatar
Attracts tree branches
I think I'm going to have to finish the DIY automatic window actuators/regulators...someone just give me time to do it!
I even have the parts from the rear side windows on a 1991 dodge caravan :D
Old Jul 27, 2005 | 07:22 PM
Straight8's Avatar
I couldn't even tell you if mine work.
Old Jul 27, 2005 | 08:33 PM
tiggerlee's Avatar
May Cause Anal Leakage
quite a good breeze
exactly :D
delicious_dallan
Jan 17, 2020 09:17 AM
Ugafan97
SE For Sale/Wanted
Apr 28, 2016 03:35 PM
patjza80
Aug 26, 2015 02:49 PM
akagc
Aug 11, 2015 07:07 PM
reddozen
Aug 7, 2015 10:20 AM
