Closing the doors
Old Jul 15, 2003 | 11:03 PM
carnut's Avatar
Closing the doors
Not having seen an actual RX-8 yet (hopefully getting mine later this month!), I'm curious what protects the doors if someone (hopefully not one of us as the owners) shuts the front door and then tries to shut the rear door on top of it. Perhaps one of our lucky new owners can fill us in? Congratulations to you, by the way!
Old Jul 15, 2003 | 11:07 PM
ELX13's Avatar
CHAH-LAY MURPHAAAAAY!
i was curious abbout that too so i tried that at the STL rev-it-up (with a mazda rep yelling, "BACK DOOR FIRST!" at me).
the back door just bounces back. i didn't see any damage to either of the doors and i didn't inspect to see what was stopping the back door from hitting the front door.
owners...thoughts?
Old Jul 15, 2003 | 11:08 PM
brothervoodoo's Avatar
RainMan is Back
Not much really. But it would be difficult to slame it hard, I don't think it swings that far. There are pictures on the forum somewhere that show this. Also you can buy a door trim protector (little piece of rubber that you can stick on, I just received mine through Trussville Mazda, they cost $20.
http://www.trussvillemazda.com/partsstore/
Old Jul 15, 2003 | 11:09 PM
jd62's Avatar
Old Fart
Re: Closing the doors
I've got one in my garage, but I'm not going to try it. Maybe someone else will oblige
Old Jul 15, 2003 | 11:11 PM
carnut's Avatar
I don't blame you, JD62! I'm sure all cars are built to handle the occasional less-than-careful passenger. That's one reason we don't want our vehicles used as demonstrators, right?
Old Jul 15, 2003 | 11:23 PM
jd62's Avatar
Old Fart
I was just being a little silly. I could go out in the garage and try it now, but I'll wait until morning. I'm thinking that the inside door upholstery would probably take care of it unless you managed to bang the metal together. I think that the original writer has a good point, and it's a serious point to consider.
I'll play with the doors tomorrow and see if it could be a real problem.
Old Jul 16, 2003 | 10:09 AM
Edge's Avatar
Murphy was an optimist!
Actually there's a worse case: Let's say you've got a passenger in the back. You pull up to a rest stop, get distracted by something as you hop out and go to close your door. But your rear seat passenger has started to open the back door. Now what happens? I say this because if you're not used to the front door having to be open, and assume it's a 4 door car, then it's easy to assume the rear seat passenger can take care of themselves.
I did this recently on an Element and it survived no problem (rear door was open about an inch. But it was a nasty surprise for the back seater, and I could foresee some serious consequences for unaligned frames, latches, etc coming together, not to mention the potential for fingers and limbs.
Old Jul 16, 2003 | 11:34 AM
jd62's Avatar
Old Fart
I couldn't get metal to metal contact. I don't think you can hurt the doors.
Old Jul 16, 2003 | 09:26 PM
carnut's Avatar
Thanks for the input. I knew all of you would have some answers. Happy driving (as I wait for my delivery e-mail)!
Old Jul 16, 2003 | 09:45 PM
jd62's Avatar
Old Fart
I wouldn't hold my breath on the email. I think they're having some problems with those. I didn't get one, and my car is in the garage. Better keep close tabs on the dealer and make sure he calls you.
Old Jul 16, 2003 | 10:36 PM
TJRX8's Avatar
RX-R8ED
The plastic on the backdoor hits fairly flat and wide enough to prevent damage. Of course if you slam anything hard enough it will cause some damage. One thing to keep in mind is that if you close the front door first it doesn't have anything to latch to and will bounce back. So unless the backdoor is slammed right away after attempting to close the front door I would imagine most people would catch themselves. At least quick enough to stick an arm or leg out to save the car. :D
Jst4fun
Apr 17, 2021 07:43 AM
Jst4fun
Mar 5, 2021 07:16 PM
nferguson88
Oct 6, 2015 12:45 PM
archon
Oct 1, 2015 06:08 AM
Learners_Permit
Sep 27, 2015 07:38 PM
