My review of the Potenza RE55S semi slick - Sandown lap time plummeted!
Old Jul 19, 2005 | 08:39 AM
takahashi's Avatar
Cool My review of the Potenza RE55S semi slick - Sandown lap time plummeted!
I have done the best time after review of all the videos. (and they are coming later)
The previous best time from the half worn RE040 is 1'35.9"
Since then I have done.
2nd oil cooler,
Odula intake,
R Magic air filter, RB short shifter,
but the most responsible piece of equipment.
Potenza RE55S 245/40-18 SR rated (hard compound)
My review of this tyre:
The tyre is FAN-TAS-IC.
1. Very noisy tyre.
It is extremely noisy but the ride is good. I had to get dance music to Vol 7 or above so I will not hear the road noise.
It has a very stuff side wall so it gives a very good road response.
But the trade-off is to have more road noise to your ears, so it is not really confortable if used as a road tyre. :o
2. Fantastic grip
Hence, more confident with the turn in. The stock suspension (strut reinforced) holds pretty well but there are too much load on the tyre still. Coilover will help.
I turned in the first turn of the Sandown raceway like a man possessed. Going oversteered, understeered when turning in, the tyre helped you to grip and stay away from the outside curve. PERFECT!
In the wet, it can be tricky since the grip is resulted from a higher temperature generated from the tyres but it is not going to acheive that in the wet road. DSC is required
3. Still last as much as the road tyres
After all this fun, only a small portion of rubber has been used. I reckon I can have it for 7-8 track days on those. Similar wear was seen in the RE040 on the track. IMO
4. Reasonably priced
Best of all it is cheap. You can get one for about $450, but I got a special price of $380 a corner
Highly recommended if you track your car a lot. You will end up saving and having so much fun.
LAP TIME
This is from the afternoon session (T = Traffic; W=Warm up; C= Cool down)
Session 1
,Lap,1, ,'1m58.69,s,'118.69,s, W
,Lap,2, ,'1m32.22,s,'92.22,s,
,Lap,3, ,'1m31.45,s,'91.45,s,
,Lap,4, ,'1m31.91,s,'91.91,s,
,Lap,5, ,'1m40.05,s,'100.05,s, T
,Lap,6, ,'1m37.74,s,'97.74,s, C
Session 2
,Lap,1, ,'2m8.24,s,'128.24,s, W
,Lap,2, ,'1m35.32,s,'95.32,s, T - ILIV48 :p
,Lap,3, ,'1m31.71,s,'91.71,s,
,Lap,4, ,'1m31.80,s,'91.80,s,
,Lap,5, ,'1m31.85,s,'91.85,s,
,Lap,6, ,'1m32.86,s,'92.86,s,
,Lap,7, ,'1m40.44,s,'100.44,s, C
Session 3
,Lap,1, ,'2m18.73,s,'138.73,s, W
,Lap,2, ,'1m35.56,s,'95.56,s, T
,Lap,3, ,'1m32.59,s,'92.59,s,
,Lap,4, ,'1m39.55,s,'99.55,s, T
,Lap,5, ,'1m31.89,s,'91.89,s, C
In the morning,
Behind the JDM Honda Integra Type R (162kW + Mugen ECU and Suspension, Semislick).
,Lap,1, ,**********error
,Lap,2, ,'1m34.88,s,'94.88,s,
,Lap,3, ,'1m39.53,s,'99.53,s, T
Behind the 2 Carrera (one S and other normal Porsche 911)
,Lap,1, ,'1m35.61,s,'95.61,s,
,Lap,2, ,'1m36.25,s,'96.25,s,
I will try to put the video up in my website later in this thread.
Old Jul 19, 2005 | 05:54 PM
auzoom's Avatar
Hmmmmmm.........
Good stuff Taka. The picture isnt coming through though.
Andrew
Old Jul 19, 2005 | 06:00 PM
timbo's Avatar
rock-->o<--hard place
Good review, taka...I'll be interested to see what they do for you at Wakefield (if you have room to bring them ) 1:14 is about the number on road tyres, although Michael Taylor (Motor editor) said Ric Bates did 1:12 when Motor did the 2003 PCOTY at Wakefield.
Old Jul 19, 2005 | 06:19 PM
Lock & Load's Avatar
AUGUST MOTOR MAGAZINE HAD A PORSCHE TURBO S around wakefield doing 1:07.6 it shows a map of wakefield and shows the entry and exit speeds around the track needed to achieve that result
B....free
michael
Old Jul 19, 2005 | 06:32 PM
takahashi's Avatar
I also find that I don't need that much air pressure in the semi slick, since the heat on the semi slick increases the volume of air inside.
I ran at 36psi (hot) all around and found it is the best for me. I ran 43 psi (hot) and the car was very bouncy on fast turns.
When I used to have the road RE040, I ran 43 psi hot and 40 psi cold.
Old Jul 20, 2005 | 06:17 AM
RXP33D's Avatar
[QUOTE=Lock & Load]AUGUST MOTOR MAGAZINE HAD A PORSCHE TURBO S around wakefield doing 1:07.6 it shows a map of wakefield and shows the entry and exit speeds around the track needed to achieve that result
And if we were to go by those guidlines I don't think we'd stay on the track
for very long. They are guidelines for Porsche's top model and useful to
very few people. I only managed 150km/h at the end of back straight which
is hopeless i think?
Old Jul 20, 2005 | 06:52 AM
[QUOTE=RXP33D]
If you were to read the last line , i never suggested that the RX8 WOULD / COULD match those figures , however lowering those posted speeds made by the porsche by 20 % would be achivable from memory i got around 170 km/h on the straight .
I found the information very usefull :D , allowing for the type of car, used and driver it can be used as a guideline
B....free
michael
Old Jul 20, 2005 | 08:57 AM
takahashi's Avatar
Don't you love Lock and Load's simplistic approach to track driving.... :p
I am the sort of person who does not care and will not look at the odometer 50-100m before the first turn.
I am the sort of person who cares about the gear that I am in, where to break, where to lift off, which line I take and should I turn in late with light braking to get more grip, am I hurting the front outside tyre by doing this...., when to put the throttle and am I ready to catch the power slide ..... :p.
Oh well it is just me.
I have found a clean lap in my tapes and here it is on my site (use right click and "save target as....")
Old Jul 20, 2005 | 03:48 PM
Use the KISS ( Keep it simple stupid ) method Taka. :D
Knowing your car,self and your driving abilities on the track :p to me is the most important aspect , , your senses are your guide to speed no need to look at the dials .or check your gears go with the force
Your waaaaaaay to techknical , learn to feeeellll your car and be as one grasshopper :D
Anyhow as stated before its not a race but a fun drive
B.....free
michael
Old Jul 20, 2005 | 04:57 PM
timbo's Avatar
Nice lap....you seem to have a nice, smooth style (although I'd need sound to be absolutely sure ) Your approach above sounds just right....might be time to get yourself a Formula Ford
Hey, I just noticed something! You run anti-clockwise at Sandown! Is it like horseracing and the Melbourne Cup? Cos we seem to run clockwise up here
:p
Old Jul 20, 2005 | 06:41 PM
takahashi's Avatar
Thanks for the comments timbo. You are very kind, although I can show you the lap that I misshifted and slide out haha. :p
You are absolutely right Timbo. I took the tyre off yesterday and there are more wear on the right front than the left rear --- very clearly too --- especially on the outside. I think there is due to the first turn and the Dandenong corner that the car is off camber slightly, high speed and turning left. There are Michellin tyre guys there and they said it is very normal due to the lay out of the track. And yeah the Wakefield run I can use the left side more...
One thing to add. They are directional tyres... so there are a set of right and a set of left tyres and you cannot swap it around. :p
Old Jul 20, 2005 | 07:03 PM
Revolver's Avatar
Shootin' from the hip
Taka, for some strange reason when I clicked on your link my computer went straight to my media player and after downloading I got sound fine but no image.
What's the url of your site again? I'll see if I can get it better from the web page.
Old Jul 20, 2005 | 08:53 PM
takahashi's Avatar
Download a codec from www.divx.com (coz the file is in DivX format).
Or the divX player.
More clips coming.... :p
Old Jul 20, 2005 | 09:29 PM
takahashi's Avatar
Here is another one in DivX.
Taka vs JDM Type R
The car in front is my mate Stephen, and he is in a JDM DC5-R with Mugen ECU, intake, suspension and running RE55S in a SSR comp 17".
Old Jul 20, 2005 | 10:07 PM
timbo's Avatar
Typical frikin' Porsche driver..! :p
Shows how the 8 loves the corners, and its strong braking ability
Old Jul 21, 2005 | 12:25 AM
Revolver's Avatar
Thanks Taka - figured it out and watched both.
What Timbo said! :D
olivierapex
RX-8 Racing
12
Sep 4, 2015 12:14 PM
escapedan
Series I Do It Yourself Forum
Jul 29, 2015 10:44 PM
Jvswan
28
Jul 23, 2015 09:02 AM
