Brake fluid flush
Old Jul 18, 2005 | 02:27 PM
Frank Patrick's Avatar
Brake fluid flush
Checked Search- could not find
First -Is it absolutely neceassary at 30K
second- anyDIY
Old Jul 18, 2005 | 02:29 PM
beachdog's Avatar
Is it in the owner's manual at 30k? If it is in the manual, do it. If it isn't, don't unless you want to switch to a higher performance fluid.
staticlag's Avatar
The Professor
Its pretty easy, Im doing it myself today.
https://www.rx8club.com/showthread.p...=speedbleeders
Speedbleeders make the process so much easier!
Old Jul 18, 2005 | 02:30 PM
ZoomZoomH's Avatar
Mulligan User
probably not *necessary* unless you do track-type activities in your 8, but a good extra maintenance thing to do, never hurts to have fresh brake fluids in the system
no actual DIY thread I know of, but it is identical to any other cars with hydraulic braking system :p (ie bleed from farthest wheel to closest to the resevoir)
Old Jul 18, 2005 | 02:49 PM
beachdog's Avatar
I would check the shop manual on that zoomzoomh... I have never done a brake fluid change on a car with abs before but I seem to recall that there is a special procedure or sequence becuase the ABS pump is in between the master cylinder and the wheels.
Old Jul 18, 2005 | 02:54 PM
ZoomZoomH's Avatar
Mulligan User
actually that IS what the shop manual says for brake bleeding/flushing procedure... have shop manual in pdf files :D
Old Jul 20, 2005 | 08:52 AM
Thanks for the help-and the hint on Speed bleeder=- made the job a snap!
theblinkof
Oct 4, 2023 05:24 PM
Oct 3, 2015 09:51 AM
D13
Oct 1, 2015 07:55 AM
XianUnix
Sep 29, 2015 03:48 PM
