Upgrading tire size
Old Jul 15, 2003 | 11:46 AM
ffjaydee's Avatar
Upgrading tire size
Is anyone thinking of upgarding their tires to 245/45 or 40/18??
Also I've noticed that the 350Z has different tire sizes on the front and back. Is this a possiblity on the RX? It looks like there is lots of room for an increase in tire size according to the wheel wells.
Looking for your thoughts!
JayDee
Old Jul 15, 2003 | 11:50 AM
colin204's Avatar
245/40/18 should not be a problem but it will be about .9 inches shorter. There are a lot more tire choices in the 40 series vs the 45 series.
Old Jul 15, 2003 | 01:07 PM
Quick_lude's Avatar
Love to rev!
If you go with a different overall diameter you will have to account for the rpm/speedo/odometer differences.
I wouldn't put a staggered tire setup, ie rear tires wider/larger than the front on a car that doesn't come stock like that. Staggered tire setups are done for a reason and are designed to fit the suspension. If the 8 is non staggered, keep it that way.
Old Jul 15, 2003 | 01:22 PM
KKMmaniac's Avatar
VW coulda had it...
Hmmm; accordion to my calculations, a 245-40/18 would only be about .25" smaller in O.D. than a 225-45/18. I would think this would have a pretty insignificant effect on meter readings.
I agree with Quick_lude about using two different sizes, especially if the car has 50-50 weight distribution and fairly neutral handling.
Old Jul 15, 2003 | 01:31 PM
SPDFRK's Avatar
The specs I checked for S-03's says only a .3" difference between 245/40 and 225/45, does the RE040 have a different spec than the S-03's for the 225/45? They weren't shown on tirerack. The .3" shouldn't really be noticeable but .9" might be.
Old Jul 15, 2003 | 02:17 PM
colin204's Avatar
When I looked up the height of the 2 sizes they were on 2 different rim widths. On the same rim width the difference is only about .2 to .3. The difference between 7.5 and 8 inch wide rim made it the .9 difference.
Old Jul 15, 2003 | 02:34 PM
Quick_lude's Avatar
Love to rev!
This is a good error calculator: http://www.mindspring.com/~toy4two/tire.html
According to that, the 245/40/18 is only off by .99% from a 225/45/18 tire. So your speedometer will show a slower speed and your odometer will be off by 10km less over a 1000km distance.
Old Jul 15, 2003 | 04:20 PM
SPDFRK's Avatar
If the tire is less than 100% wouldn't it read more mileage than you are really traveling.
Old Dec 7, 2003 | 09:29 PM
Rotary Nut's Avatar
"...I'm a Dapper Dan man"
I have found that the 255/40WR18 is only .2% slower than stock. Not enough to make a difference!
Old Dec 11, 2003 | 10:16 PM
Rotary Nut's Avatar
Side wall difference between the 225/45WR18 and the 245/40WR18 is only .1 inch and tire diameter is only .3 inches smaller so it should be practicaly nill.
Paul_Y
Sep 21, 2015 02:23 PM
Octomus
Sep 3, 2015 11:40 AM
20b-3rotor
Sep 2, 2015 08:54 AM
