mazdaspeed front sway bar
Old Jul 11, 2005 | 07:22 PM
pritch's Avatar
i just picked up the front sway and was wandering if i could install just the front and then the back another time
Old Jul 11, 2005 | 07:40 PM
M-ster's Avatar
of course you can, just that you'll get a little different handling characteristic, like over or under steering. If i remember correctly, reading somewhere... having a stronger front sway, will induce a more understeer handling.
Old Jul 11, 2005 | 11:40 PM
Kel Rx8's Avatar
if your not 1st your last
what he said ^
its a fairly simple install, well after a few times on different rx8's
but be prepared for a few stubborn bolts on the endlinks.(varies in cars)
Old Jul 12, 2005 | 01:00 AM
Mikelikes2drive's Avatar
i thought it was tough getting the sway bar in and out... quite frustrating and a two man job
the endlinks were tough too when it was being stubborn just as kel mentioned which thankfully was only on one side for me
Old Jul 12, 2005 | 02:43 AM
IZoomZoomI's Avatar
Boost needed
o yeah the front is a b***ch to get out. Man, makes me quiver thinking about that install
Old Jul 12, 2005 | 09:12 PM
proper technique is everything
https://www.rx8club.com/showpost.php...55&postcount=6
Old Jul 12, 2005 | 11:18 PM
IZoomZoomI's Avatar
Boost needed
You are going to induce more understeer if you keep just front only. The car already understeers, if anything get thicker rear sways.
Old Jul 12, 2005 | 11:27 PM
brillo's Avatar
Go Texas Longhorns!
its no big deal, I did the front first, then got the rear soon after. car does push a hair more, but what I really noticed was the flatter cornering. the front really reduced the body roll.
Old Jul 13, 2005 | 12:59 PM
not true, if you have understeer with a Mazdaspeed front bar only then your alignment isn't correct, it's only marginally stiffer than OE, not really worth the money or effort IMO
we run a custom front bar that is stiffer than the Mazdaspeed bar for use with the OE rear bar and don't have an issue, will be offering them FS soon
Old Jul 13, 2005 | 01:52 PM
pritch's Avatar
now you tel me team rx-8
Old Jul 13, 2005 | 02:14 PM
tuj's Avatar
tuj
TeamRX8: how does your sway compare to the RB sway in terms of stiffness over stock? I believe the RB sway is something on the order of 200% of the stock unit.
Old Jul 13, 2005 | 02:27 PM
pritch's Avatar
mazdaspeed cant be that bad they race with it and use eibach springs
Old Jul 13, 2005 | 02:31 PM
army_rx8's Avatar
X-Sapper
^cool i was not aware of that :D kudos
Old Jul 13, 2005 | 03:05 PM
crimson-rain's Avatar
Maybe we would have to take Mazda's entire suspension setup to really understand why they designed the bar that way. Afterall, suspension is a team of parts working together. Besides, it's Mazda's car.
I going to shut up though. I'm still running stock (trying to learn as much as I can from the car stock versus my driving style).
Old Jul 13, 2005 | 03:33 PM
Dark8's Avatar
Ride Naked!
Who are they?
Old Jul 13, 2005 | 07:52 PM
pritch's Avatar
who is mazdaspeed?
Old Jul 14, 2005 | 10:44 AM
Dark8's Avatar
Ride Naked!
^ No. Which pro racing teams are using the same MS bar that we can buy? I find that on the internet it is so easy to say "they" use it with no real data to back it up. The MS suspension system is made to give you a suspension better suited for spirited driving, not real racing. It's what the 8 should have come with.
Old Jul 14, 2005 | 11:59 AM
pritch's Avatar
oh i thought that speedsource uses it i talked to them at watkins glenn and they said they use the mazdaspeed stut bars and sway bars with eibach springs.
Old Jul 14, 2005 | 12:08 PM
Dark8's Avatar
Ride Naked!
Maybe you are right, but I still have trouble believing that with all of the money Speedsource has invested they don't use custom adjustable anti-sway bars. I can truely belive they use the MS strut bars and Eibach springs on custom adjustable shocks though.
Old Jul 14, 2005 | 12:22 PM
pritch's Avatar
i think there are restictions on what they can use im really not sure but i did see all the cars in the garage and they all had the mazdaspeed strut bar on them
Old Jul 14, 2005 | 12:29 PM
pritch's Avatar
well i would like to find out for sure to if they use the sways. anybody out there know for sure please post.
Old Jul 14, 2005 | 03:55 PM
you can use soft swaybars coupled with extra stiff springs for a dedicated race car, try it on the street and you'll learn the true meaning of misery ...
Old Jul 14, 2005 | 06:06 PM
r0tor's Avatar
well, they also use the stock brake calipers, stock tranny, and stock rear sway bar, and a mostly stock engine :o
for reference, the MS sway is about 15% stiffer while the RB sway is about 50% stiffer then stock.
the MS suspension uses stiff springs, stiff shocks, and softer sways - great track setup, but brutal ride comfort on the street. The RB setup uses soft springs, stiff sways, and a medium shock - liveable ride comfort, good performance, but when pushed hard the stiff sways can be a bit unpredictable.
Old Jul 14, 2005 | 08:44 PM
pritch's Avatar
im going with eibach springs and stock shocks i hope this will work
Old Jul 14, 2005 | 08:58 PM
salituro64's Avatar
If this is true, I'll go with Mazdaspeed.
