will a AUTO RX-8 still make that blow off valve sound with a turbo?
Old Jun 29, 2005 | 04:52 PM
Minda's Avatar
You kno when you switch gears with a Turbo RX-8 it makes that air sound from the blow off valve. Well would it make that sound with a Auto RX-8?
Old Jun 29, 2005 | 04:57 PM
cleoent's Avatar
n00b
it would yes. Maybe not as pronounced.
Old Jun 29, 2005 | 05:01 PM
what does a blow off valve do minda?
Old Jun 29, 2005 | 05:36 PM
lurch519's Avatar
www.evoperform.com
yes, when you step off the gas, and the throttle plate closes, restricting airflow into the engine, the bov will vent, just like when you let off the gas to shift in a mt. now in the auto 8, it shouldnt happen unless the ecu is closing down the throttle plate enough when the tranny shifts gears.
the other thing, unless you are tuning correctly for it, you need to use a recirculating bov as the car has a maf, so if the bov vents to atmosphere, the car will most likely "stumble", running extremely rich and possibly bogging down and stalling.
Old Jun 30, 2005 | 07:38 AM
DreRX8's Avatar
Well you could hear the BOV noise in the A/T FD.
jay_tibo
22
Sep 13, 2016 08:10 PM
rotorocks
47
May 11, 2016 03:23 PM
Sifu
Aug 30, 2015 10:51 PM
akagc
Aug 11, 2015 07:07 PM
dbarber
Jul 25, 2015 01:34 PM
