Strange Sounds and Noises of the 8
Old Jun 22, 2005 | 09:15 PM
NicoRx8's Avatar
NicoRX8
Hey, Just wondering what "strange" sounds people are experiencing with their 8s.
i.e whirling, buzzing, rattling, humming etc
My 8 seems to experience a variety of strange sounds and was trying to determine if they were common and maybe therefore "normal" or require further investigation.
It would be good if people would post their "sounds" and we can get a good idea i.e maybe a poll or something and maybe even try and work out what is causing the sounds.
I note their is quite a bit of concern RE sounds in this forum and i think it may help alleviate fears about people's RX8s.
Cheers
My sounds
1) high pitched whirling/ buzzing at about 7000 revs just before the "beep"
2) the "clunk" (well documented in forum) in early stages after starting car
Old Jun 22, 2005 | 09:29 PM
takahashi's Avatar
Nico,
I have 3 noises identified and not annoying enough to fix it.
The rattle in the seat belt. It happens sporadically and related to how you shut the door.
The squeal in my seat. The bolts come loose and the metal part is rubbing each other.
The Axial flow short shifter.. I don't mind the mechanical noise really.
Oh 4th...
My baby and my wife ... it is illegal to put a sock in their mouths :p
Old Jun 22, 2005 | 10:02 PM
Revolver's Avatar
Shootin' from the hip
I've got the following:
Small clunk when moving off but we all know that's normal.
Some squeaking from the seat but I put that down to a healthy appetite! :D
A small mechanical whistle (not the rev alarm) when I lift off close to redline to change gear - but I love that one!! :D
The odd bit of squeaking from the rear parcel shelf area but not regular or loud enough to worry me.
Otherwise I haven't noticed anything out of the ordinary.
Old Jun 22, 2005 | 10:11 PM
ILIV48's Avatar
Then you would love my lightened flywheel. Get of the gas at high rpm and you can really hear it spinning/whistling. Sounds hardcore... I love it :D
Old Jun 22, 2005 | 10:16 PM
Revolver's Avatar
It's on my list Livey!!
Still conducting the extensive marital negotiation required in order to get the Hymee exhaust. I knew those joint accounts were a bad idea!! :D :D
Old Jun 23, 2005 | 12:36 PM
aa@uow's Avatar
recently I found out whenever I pressed the gas pedal very lightly, there was 'high pitch noise'.. not sure where it came from.. and the noise was not obvious at all.. no way you can hear it if music is on, the noise doesn't exist if i press the gas pedal when car stops. the noise occurs at different level of speed so i don't think it was because of the speed.. any idea?
Old Jun 23, 2005 | 03:52 PM
xxup's Avatar
Might be a cat trapped under the bonnet.. On cold nights they like to sleep in cars.. :D
Old Jun 23, 2005 | 04:40 PM
Revolver's Avatar
Originally Posted by MissRx8
Soft voices in my head mmmmwahahahaha
How the hell do they ever get a word in??? :p
Old Jun 23, 2005 | 06:27 PM
timbo's Avatar
rock-->o<--hard place
^^^LoL
They interrupt and talk over the top of each other...
Old Jun 23, 2005 | 07:57 PM
RXXX8's Avatar
is it sort of a very sharpish sorta noise? i think it could be air intake coz i got it too.. but i can always here it when i step on the accelerator
Old Jun 24, 2005 | 01:02 AM
aa@uow's Avatar
Yes sort of.. but the noise is not noticeable and it only happens when I do the gas lightly n it won't happen if the car stops... so have you get it fixed?
Old Jun 25, 2005 | 03:12 AM
NicoRx8's Avatar
NicoRX8
Another noise noted
a "creaking" of my front dash whilst driving - bloody plastic
Old Jun 25, 2005 | 04:06 AM
sco's Avatar
sco
I had a creaking in my dash caused by the instrument cluster rubbing on the dash. I popped my cluster off and put some stick on rubber on the side of the instrument cluster -- solved the problem.
Old Jun 25, 2005 | 04:07 AM
sco's Avatar
sco
Only noise ive come across is the squeeling brake pads.
How old is your car? I complained about squealing brakes at my last service and they were replaced under warranty. There is a TSB out for this problem with earlier cars.
Old Jun 26, 2005 | 06:52 PM
Jambos's Avatar
I had the same change done at the 10k service, good for 1or2k before squealing returned, complained again at 20k service, they applied anti squeal gunk, two days later squealing is back, took it back in after squealing all the way in to work, mechanic sat in car with me as I drove around and around, guess what no squealing made me look like a fool.
Don't know what to do now, some days they squeal some days they don't.
Old Jun 26, 2005 | 07:37 PM
Revolver's Avatar
I did some freeway driving on the weekend and noticed some wind noise behind my right ear, like the door seal was letting air in.
Cannot hear it at lower speeds.
Anyone else notice that before?
Old Jun 26, 2005 | 07:41 PM
RXP33D's Avatar
Its plastic, id expect it.
A "creaking" doesn't affect me anyhow cause close to redline my intake shakes the whole
damn thing including my steering wheel!
So let it be guys, listen to what happens under that bonnet and what happens at the rear
tail pipes, ignore all else. Enjoy it will ya!
Cheers.
Tuan.
Old Jun 26, 2005 | 08:14 PM
timbo's Avatar
Maybe the rear window is not completely shut/sealed. There have been some issues with this
Old Jun 26, 2005 | 09:06 PM
Revolver's Avatar
I'll double-check that next time I hear it but I usually check the rear door is properly shut because I understand that damage can occur if you attempt to shut the front door if the rear door isn't properly shut.
Thanks for the tip.
Old Jun 26, 2005 | 11:09 PM
timbo's Avatar
No...I mean the little latched window in the rear door, which is locked via an over-centre catch. Sometimes that catch needs an adjustment. I think there's a DIY on it
Old Jun 27, 2005 | 12:43 AM
Revolver's Avatar
Oh, I get it. Sorry, misread your post.
I'll check that but I don't think I've ever opened them!
