engine cover stay on or Go??
Old Jul 12, 2003 | 01:13 AM
TerenceT's Avatar
not sure if this is the right forum
but are you guys going to keep the engine cover on when you get the car or take it off?
also
is there a rear tower bar availible for this car or the C pillar is doing all the work?
Old Jul 12, 2003 | 04:28 AM
Digisan's Avatar
Alpha Powered
Re: engine cover stay on or Go??
A: but are you guys going to keep the engine cover on when you get the car or take it off?
B: also
A: Dunno
B: Yes, there is a stock rear brace behind the seats
Old Jul 12, 2003 | 09:18 AM
neit_jnf's Avatar
Re: Re: engine cover stay on or Go??
Originally posted by Digisan
A: Dunno
A: I handled the cover when i saw the car and I found it to be quite light in weight. It may even help with airflow, so I'm planning on keeping it on.
B: There's a V brace behind the rear seats that's why they don't fold down but I also saw an optional Mazdaspeed shock-tower installed rear brace as well as underbody X-braces.
Anybody know what the underbody X-brace is for? I thought this chassis was as rigid as it can get...
Old Jul 12, 2003 | 09:28 AM
RomanoM's Avatar
I Just Can't STOP!
That's technically not possible, you can always make something stiffer.
The real question is by how much and at what price and weight gain!?
Extra bracing may only add weight and cost with a nearly negligible increase in stiffness, making the brace not just useless but a drawback.
Or it may not! Only the structural engineer knows for sure
B: also
is there a rear tower bar available for this car or the C pillar is doing all the work? ?
A: Depends what it looks like under there, chances are it's not pretty. Like most cars.
B: I would bet any more bracing will be of very, very little benefit. You'll just be adding weight.
Old Jul 12, 2003 | 10:42 AM
JRobUSC's Avatar
without the engine cover all you can see is the alternator and some tubing. The engine is tucked low and under where the windshield starts, so there's really nothing to look at, making the cover on much prettier than the cover off.
Old Jul 12, 2003 | 04:28 PM
B-Nez's Avatar
Also, according to the technical highlights CD, the cover provides cooling for the battery. I think there was something else over there that is cooled, also, but I can't remember what it was. Oh darn - I guess I'll have to watch the technical highlights CD again...:D
Old Jul 12, 2003 | 05:04 PM
MrWigggles's Avatar
The cover makes things prettier and should reduce the sound from the engine a little as well.
I plan to keep mine on unless an aftermarket FI system forces me to take it off.
-Mr. Wigggles
Old Jul 12, 2003 | 06:14 PM
TerenceT's Avatar
wouldn't taking it off provide more cooling tho?
Old Jul 12, 2003 | 06:35 PM
not if it is used to direct air to a certain spot. removing it could cause that area to become too hot.
Old Jul 12, 2003 | 06:47 PM
QuantumTheory08's Avatar
Colors are cuter
Hey!!!!!!!!!!!!!!!
I think Truseville is offering color coordinated covers for the engines; check it out!
Old Jul 12, 2003 | 11:24 PM
B-Nez's Avatar
The underside of it has channels directing air to the battery. Without the cover, you'd be leaving it up to luck that enough air gets to that spot.
Old Jul 13, 2003 | 12:29 PM
Farsyde's Avatar
-Mr. Wigggles
AMEN!!! Nothing like showing of a barking turbo or whinning super.
Old Jul 13, 2003 | 04:24 PM
JaxFL_RX8's Avatar
Wait a minute... those pics above are photoshopped images of that Autoart model. Yeah I'll take two, here's my credit card number...
Old Jul 13, 2003 | 04:26 PM
tribal azn2's Avatar
Re: Colors are cuter
Originally posted by QuantumTheory08
Hey!!!!!!!!!!!!!!!
or u could just spray paint them
Old Jul 13, 2003 | 05:59 PM
Pistashio Disguisio
.....Sneaky Sneaky
I couldn't help myself.
Old Jul 13, 2003 | 08:03 PM
wizardrummer's Avatar
Leave it on...........
Old Jul 13, 2003 | 08:20 PM
ibfubar2000's Avatar
ZOOM ZOOM
Re: Pistashio Disguisio
.....Sneaky Sneaky
looks great though. maybe somebody reading this will make real ones!
Jesus Martinez
44
May 6, 2025 08:09 AM
vapor2
Nov 3, 2020 03:38 PM
ShadowDragon78
Aug 21, 2015 03:29 PM
ShadowDragon78
Aug 11, 2015 06:42 AM
marc2820
Jul 26, 2015 10:47 PM
