Nav System is Lost
Old Jun 14, 2005 | 06:54 PM
Jimbo's Avatar
Angry Nav System is Lost
Hello everyone, I have a nav system and I recently had my car shipped to Boston from California. When I turned the car on in Boston, my nav system thinks it's still in california. I drove it for a couple hours and I move on the map, however the curser is still in cali. I tried taking the DVD out for a while and putting it back in later and that didnt help, I also tried inputting a local address however it gave me directions from california to boston. Any idea how to fix this???
Old Jun 14, 2005 | 06:56 PM
Photic's Avatar
I WAS BEES
Go to your options and set your region to something other than the west coast.
Old Jun 14, 2005 | 06:58 PM
Jimbo's Avatar
I didn't see anywhere in the options to set what region you are in, I only saw one that sets where you want to go (and I selected northeastern US)
Old Jun 14, 2005 | 07:30 PM
kachud's Avatar
Mad Scientist
You must have the northeast disk. There are about 8 or ten disks in all for the US.
Old Jun 14, 2005 | 08:59 PM
Jimbo's Avatar
It says north american disk. If there was a spererate disk for the northeast, it wouldnt give me step by step directions on how to get from southern california to boston. I think i just need a way of resetting the nav system so it searches for the sattalites again and figures out where it is. Anyone else
Old Jun 14, 2005 | 09:12 PM
TheDosDog's Avatar
Recovered Modaholic
There is one disk. Just go to set up menu/Vehicle position and change the vehicle position then make sure your in an area with clear view of sats and drive around for about 20 minutes.
Old Jun 18, 2005 | 10:17 PM
Kel Rx8's Avatar
if your not 1st your last
region needs to be changed.
Old Jul 2, 2005 | 10:01 AM
Batman220's Avatar
Did either of these options work for you?
Old Jul 2, 2005 | 04:58 PM
Jimbo's Avatar
i simply just drove around for a little longer and eventually it figured out where i was.
Old Jul 4, 2005 | 01:21 PM
Batman220's Avatar
Okay, I figured this out!!!!!!!
Go to Menu.....System Setup......Vehicle Position: Now use the zoom key to zoom out as far as you can go. Now you can see the whole United States. Use the joystick to move your position to where you actually are. Start zooming in until you find the road you are on, then press enter. The next screen is which direction you are pointing, use the joystick to move the arrow until it is pointing the direction you are going. Press Enter.
Now that the system knows your approximate location it can look for the correct satellites. If it thinks you are in New York it will be looking for a different set of satellites and will take a long time to figure out where it is.
I hope this helps everybody.
cliffkemp
Dec 24, 2024 10:48 AM
Hunterkelley24
Jun 14, 2022 08:32 AM
ShellDude
Oct 1, 2015 09:55 PM
XianUnix
Sep 29, 2015 03:48 PM
FubarI33t
Sep 28, 2015 08:45 PM
