Mazda didnt screw my rotors back in.....
Old May 7, 2005 | 05:34 AM
slllygrl10's Avatar
EX-Member
Ok so I took my car in to have my rotors painted. Days later I went to Tire Plus to have my front driver tire replaced and the tech had told me that the 2 screws were not screwed in! I wonder if Mazda screwed the rest of my rotors in. How bad is this?
Old May 7, 2005 | 05:56 AM
Go48's Avatar
Only the front rotors have screws holding the rotor to the hub. The rear rotors are held by the wheel-studs-lug nuts when the wheel is installed. Were the screws missing or just not tightened? If they were there but not tightened it shouldn't be a problem. The tire guy probably tightened them and you're good to go.
If the screws were missing it's not a mechanical problem because the wheel will hold the rotor in place, but it certainly is evidence of a very sloppy job by whoever did the work. Take it in and have them install the screws. And you might want to lodge a complaint with management in either case.
Old May 7, 2005 | 06:31 AM
slllygrl10's Avatar
EX-Member
They were not tightened and yes the tire guy tightened them for me. And no matter what I tell the dealership they probably deny every wrong doings.
Old May 7, 2005 | 06:49 AM
Go48's Avatar
Doesn't your dealership give you a follow-up call after a visit to their service department? Most do. If they do, you should at least register a complaint at that time. Just out of curiosity, is this Fitzgerald you're dealing with?
Old May 7, 2005 | 08:08 AM
slllygrl10's Avatar
EX-Member
No, its Congressional Mazda in rockville md
Old May 7, 2005 | 08:09 AM
slllygrl10's Avatar
EX-Member
Oh someone called me and I told him about what happened to my wheels and everything else he said he will have the service manager call me never heard anything from them.
Old May 7, 2005 | 08:14 PM
being screwless sux
:D
Old May 7, 2005 | 08:22 PM
tiggerlee's Avatar
May Cause Anal Leakage
I sure hope your bout of bad luck is over. Seems like lately you've had more than your share of it. I feel for ya!
Old May 7, 2005 | 08:38 PM
slllygrl10's Avatar
EX-Member
No kidding Im sick of this. Im just trying to avoid dealerships or anything handling my car except for me period. If no one touches my car it will be mighty fine.
akagc
Aug 11, 2015 07:07 PM
MarkX
Jul 31, 2015 07:50 AM
digitalmonkey79
Jul 29, 2015 12:09 AM
dbarber
Jul 25, 2015 01:34 PM
Bamaham
Jul 23, 2015 08:08 AM
