Dipping out the back....????
Old May 5, 2005 | 11:46 AM
RX8 JET's Avatar
I have noticed that my differential (I guess you would call it) is wet. I notice that on my driveway that there are drops present. I told the dealership about it but they attirbuted it to the overflow. I did not think much more about since my driveway has a tilt to it. I started to park the car pointing down but still see the drips.
Anyone else see this kind of behaviour?
Old May 5, 2005 | 11:54 AM
smrx8's Avatar
Not me did they change the oil there maybe they left some wet spots on there.
Old May 5, 2005 | 12:12 PM
Brice-RX8's Avatar
Spray it will degreaser and then the water hose and if it comes back then you got a problem and you can then tell them you did that and that something is really leaking.
Old May 6, 2005 | 09:56 PM
RX8 JET's Avatar
Thumbs up
Apparently there is a real problem!!
I finally "squeaked" loud enough that the dealership looked beyond a quick visual. It appears that my other problem was also related to this.
I was told when they had the car on a hoist and running that the fluid in the diff was flowing quite nicely out of the overflow screen. They called Mazda to discuss the situation and had to order a new part. Should be in Monday.
It would be great to have these 2 problems go away with one full swipe... :D
DVerdeyen
Sep 13, 2015 11:19 AM
mitchrx8
Sep 13, 2015 08:05 AM
PotatoCannon
Sep 6, 2015 11:48 AM
talonhart2
Aug 26, 2015 04:14 PM
