Revving engine to 3000rpm before shutdown???
Old Apr 29, 2005 | 07:10 PM
jAydApiNoy83's Avatar
jAyDaPiNoy83
hey guys quick question on just starting/shuting the engine???
starting: do you guys usually wait for ur car to go around 1k rpm or wait for the temp to reach in between hot/cold before driving??
shutting: do you guys rev your engine every time to 3000 rpms before shutdown on a normal drive or do u guys do that only when u drive short distance (ex. car wash)
i just wanna get ur input on what daily routines yall do to ur 8
Old Apr 29, 2005 | 07:20 PM
expo1's Avatar
He's as bad as Can
No more than 2 minutes then I am on my way.
Only do the 3,000 RPM thing on cold shutdowns (temp needle not in the middle)
Old Apr 29, 2005 | 08:19 PM
MI_FamilyMan's Avatar
Sold on Rotaries!
Omigosh people, you do not have to wait before driving your car upon start up. Maybe 10 seconds tops until the revs drop to 2000 or less might help, but not absolutely necessary.
Upon shutdown there is no need to rev to 3,000 RPM if the engine is sufficiently warm. I still can't believe how much paranoia is being spread around these boards because some people have flooded their cars. It is an issue, but if you warm up the engine before shutting off you should be fine. And even that is a precautionary measure.
Old Apr 29, 2005 | 09:17 PM
Vertigo-1's Avatar
I dunno, whenever I go out for a hard driving session and then shutdown without doing a 3k rev, the next startup is always hard, unless the car gets left alone long enough for everything to go absolutely cold. Makes me wonder if it's an issue of a lot of fuel being dumped into the combustion chamber from the hard driving, and there being leftovers when shutting down. I've started doing 3k rev shutdowns after hard driving sessions.
Old Apr 30, 2005 | 12:21 AM
jbrasure's Avatar
I never rev my car at shutdown (unless it's cold). Never had a problem.
Old Apr 30, 2005 | 01:41 AM
BlueFrenzy's Avatar
Rotary Powered Decepticon
I only rev the engine up and shut down if the car is not sufficiently warmed (ie from a cold snowy day).
But yea, never really wait for the car to warm up either. Only waiting I do is adjusting the stereo ... then it's GO time.
Old Apr 30, 2005 | 02:10 AM
dpm's Avatar
dpm
Danimal
I never rev it before shut down, even in dead winter on short drives( moving out of driveway) and have never flooded.
Old May 1, 2005 | 04:13 AM
Nubo's Avatar
Lubricious
As long as the idle is smooth you should be good to go. Just take it easy until she warms up.
I do make use of the 3000rpm technique sometimes. Like today. I needed to wash/wax/clean the car. Pull out of garage onto driveway to wash. Back into garage and out of the sun to wax. The leather conditioner says to let the sun warm up the leather, so back into the driveway. Finish cleaning/conditioning the leather, back into the garage. I usually try to be conscientous about warming up but 4 times is a little ridiculous. So I put my faith in the 3000rpm procedure.
Old May 2, 2005 | 08:54 AM
MrMethane's Avatar
Well call it paranoia if you will, but I have personally experienced very hard starts when not reving before shutdown. When I first got the car I reved to 3k every time I shut down, then after about a month I thought I was just being paranoid and I stopped doing it. Then I started having occaisional hard starts.
Now this only occurs when the car has not completley cooled down before restarting it. If the car is left to cool down compleltey I don't have a problem. Its just after its gotten warm and cooled down slightly. For example, I leave work, and on my way home stop at the mall. The car is warmed up completley. I'm in the mall for about 30 minutes. Come back out and start the car and it doesn't turn over for about 10 seconds. After this happend on several different occasions weeks apart, I went back to reving to 3k before shutting down and have not had that problem since.
It could be purely coincidental, but it doesn't bother me to take 2 seconds and rev to 3K even if just for peace of mind.
Old May 2, 2005 | 09:22 AM
Moostafa29's Avatar
Storm Trooper
The whole revving before shutdown, and warming up has become second nature to me now. I really don't even think about it anymore.
Old May 2, 2005 | 10:43 AM
SHOWOFF's Avatar
NOT SEARCHING
I guess I am being stupid, but I have always warmed my cars up before going anywhere. I let the car run for a couple of minutes and then drive off. You have different metals all within .000's of an inch of each other and they all expand and contract differently. It just makes sense to have the fluids at temp and the metals at operating temp before running the car hard. I mean Humans, dogs, cats etc. usually all stretch their muscles before moving around when they wake up in the morning, why wouldn't you do the same with your car?
As far as the 8 goes it gets a minimum of 2 min and then I don't rev the car over 3 grand until it is fully warmed unless I have to. When I have to move the car in the driveway or something like that I always do the rev to 3k thing. I have had my car flood once and it's a pain in the *** to get it started after that.
Old May 2, 2005 | 11:45 AM
army_rx8's Avatar
X-Sapper
i just wait until the fluids are at operating temperature...hehe which is easy for me to read b/c i have gaugers:p but i never go anywher ewith out warming her up..not b/c of flooding (she's already on how can she flood lol)..but b/c of teh different metals in teh side housings and intermidiate housing on teh 13b-msp :D
but to each his/her own
Old May 2, 2005 | 11:49 AM
Glyphon's Avatar
脾臓が痛みました
I start it up , put my seat belt on, then put it in gear and away i go.
1) letting your car warm up before driving kills your fuel economy.
2) driving at low rpms (under 3000 rpm) is the quickest/safest/most efficient way to bring the engine to temperature
and as for the animal analogy, yes, you are supposed to stretch before doing physical activity, but you get a better stretch if you do some mild exercises first to get the blood flowing and loosen up the muscles. think of the <3krpm driving as the warmup and stretch rolled into one.
Old May 2, 2005 | 11:51 AM
army_rx8's Avatar
X-Sapper
it doesn't kill mine..it's not like a 13b-rew...idleling isn't as bad in our car (for fuel economy)...haha and besides it isn't like our cars are very effeicent mpg wise anyways :D
Old May 2, 2005 | 12:10 PM
Purple Helmet's Avatar
in warm weather, I wait a minumum of two minutes warm up time and I never red line it unless its fully warmed up and I do redline the car each time I drive it, as it helps keep the combustion surfaces cleaner and less prone to poor or stumbling idle, running BG44k through every 3 months helps too,
winter, I warm it up at least 5 minutes if the car is parked outside, my garage is insulated there for it never gets below 50 degrees in the winter and I still wait two minutes for warm up. I never go above 3000rpm until it is almost warmed up all the way, I have had hard starts whether the car was fully warmed up or not when it was shut off, but with the yellow top optima, starting is no longer a problem, even if it floods, that battery will melt the starter before it dies, and I try not to over heat the starter when it floods, and it flooded twice, but I was able to follow the flooding procedures and it started, does not make me happy when it floods, it s embarassing with neighbors staring, they dont understand rotaries
as far as revving it to 3000 rpm before shutting down, its new to me, its seems odd to do, I will have to do some research on that one, think I'll ask a rotary certified mechanic, see what they say, I do know that you have to idle the car and cool down the oil a bit before you shut it down, and it cools down the rotors too, and I have not found mazda literature that states that you rev 3 grand before shutdown...
I remember years ago, my Engineer Uncle bought a Mazda Cosmos I believe it was, my Aunt hated it, it was not all that reliable, he was really proud of that car, he has passed away years ago, I am guessing he would have been thrilled with the rx8........
Old May 2, 2005 | 02:37 PM
V_for_velocity's Avatar
One more couldn't hurt
From: Saskatoon, SK -- go to Winnipeg then head west
It's mentioned in Mazda's own literature, although not the owner's manual.
Old May 2, 2005 | 10:11 PM
demob05's Avatar
Is it due primarily to the carbon buildup issue??
Old May 2, 2005 | 10:16 PM
Gomez's Avatar
Shifty Bastard.
It's also on the DVD MNAO sent out to MSP04 customers in February.
Old May 2, 2005 | 10:52 PM
DrRockin99's Avatar
Zoom Zoom Zoom
I always warm me car up till it hits the "c" , the rpms are usually around 1200 rpms when I take off . If I take off too soon , the rpms jump around alot , like its not warm . No harm in warming it up a bit . I also always rev up to 3000 rpms and kill it ...only once have I had a hard start and thats when the car sat for 15 hours in 15 degree weather . Once it got started , wasn't a problem . Never flooded and I always get 17mpg .. I figure it might cost me 1 mpg warming it up a little longer , but in the long run it will pay off !
Old May 3, 2005 | 02:40 AM
RX4life's Avatar
i warm my car up till the needle rests at 1.5k rpms... then i drive slowly tiill it hits normal running temp...
i rev the car to 3k EVERY time as a precautionary measure.. and immediately shut it off ... the car starts in less than a second when doing this the next time! and i rev to 4K for 3secs when taking it out to wash.. and shut it off..
Old May 3, 2005 | 06:57 AM
derwankel's Avatar
Well, a word of caution, reving to 4k activates the secondary injectors along with the primaries ... thus dumping more fuel into the chambers. I'd suggest you only rev to 3k as this dumps less fuel that needs to be swept out to avoid flooding.
Old May 3, 2005 | 12:54 PM
vroom007's Avatar
On Every Street
hmmm..........
Old May 3, 2005 | 01:09 PM
Aoshi Shinomori's Avatar
Kaiten Kenbu Rokuren
Why would letting your car warm up kill your fuel economy?
Old May 3, 2005 | 04:02 PM
wintergrn's Avatar
refreshing
^ Because it's running a rich mixture and not driving anywhere? :D Sorry, I try very hard not to be a smart-a$$, but it's in my nature. What I mean to say is that it's not doing anything permanent, if that's what you're wondering. It's just worse in the sense that stop-and-go traffic is worse than continuous driving.
Seriously, though, there's not a huge difference between running at idle and driving under very low load, but it does seem like the car runs much more smoothly once the temperature rises enough that the idle speed is below about 1500. The dissimilar metal expansion thing makes me kind of cautious here, too, but then I've only had the car for 3 months and need to learn to relax.
And a rev before shutdown, turning off the ignition as your foot leaves the throttle and the revs drop, does help sweep the chamber clean, and it doesn't hurt anything, so I've got in the habit of doing it every time.
Old May 3, 2005 | 04:23 PM
apotocki's Avatar
My 2 scents is as long as you don't drive the car 'hard', there really isn't any need to warm it up for a lengthy period of time.....as long as all the fluids are circulating, there shouldn't be a problem.
As to the rev before shutdown......why is this a concern? My feeling......'JFDI' (Just F@#*in Do It) What harm does anyone think it will do? I think its been 'proven' (don't really like using that word) to be of benefit. Its a habit at this point and besides that it gives me an excuse to hear the exhaust. My Dealer salesman also suggested doing this.
