DIY: Whole navigation System!
Rating: Thread Rating: 4 votes, 5.00 average.
Old Apr 27, 2005 | 06:13 AM
RX8 XTC's Avatar
Wink DIY: Whole navigation System!
****This is time consuming****
It took me the whole weekend to do if you are attempting to do this fined a nice big space to work on your car doors are going to be OPEN all the time.
Am just getting right to it, the Shop manual or the one that I have did not Show Some of the stuff that I needed to take a part to install the whole thing I did take some Pix but since it was too much work to take Pix I will use the PDF format Pix that I have.
Tools & the parts that you NEED!
1- OEM navigation system harnesses
2- The DVD player + the DVD CD
3- The motorized 7” screen
4- Center consol for the navigation controller ( you can modify your original one if you want to)
5- GPS ANTANA
6- Philips screw driver. You will use it a lot.
7- Smallest FLAT head you can find. You will use this To Unplug the Weirs it makes life a lot EASYER, or any thing that will do the job
8- A wrench + Extensions and size’s ((10m to 17m)) I can’t remember what sizes I used but I know I used the ones that are in that RANGE.
9- Get a Box to Put the Screws and BOLTS in so you DON’T lose them!
If I missed something out I will add it Later on.
Old Apr 27, 2005 | 06:18 AM
RX8 XTC's Avatar
1st
take the FRONT and REAR seats out using a 13m Wrench Do NOT disconnect the battery yet until you remove the Driver side if it is Electric. If u are asking why because you will need to move the Driver side seat FROWARED and back words to get to the SEAT bolts
2nd
After doing that disconnect the battery and Remove the FRONT SEATS and the BACK Seats.
FRONT SEAT
FRONT SEAT REMOVAL/INSTALLATION
WARNING:
• Handling the front seat (with a side air bag) improperly can accidentally deploy the side air bag, which
may seriously injure you. Read the service warnings before handling the front seat (with a side air
bag).(See SERVICE WARNINGS .)
1. Turn the ignition switch to the LOCK position.
2. Disconnect the negative battery cable and wait for 1 min or more .
3. Disconnect the connector.
4. Remove the covers.
5. Remove the bolts, then remove the front seat.
6. Install in the reverse order of removal.
REAR SEAT
REAR SEAT REMOVAL/INSTALLATION
1. Lift the point A in the direction of the arrow, then remove the rear seat cushion.
2. Remove the bolts, then remove the rear seat back.
3. Install in the reverse order of removal.
Attached Thumbnails DIY: Whole navigation System!-forn-rh-lh-seats.jpg   DIY: Whole navigation System!-rear-seat.jpg
Old Apr 27, 2005 | 06:24 AM
RX8 XTC's Avatar
CONSOLE
CONSOLE REMOVAL/INSTALLATION
2. Detach clips A and remove the upper panel.
3. Disassemble in the order indicated in the table.
1 Screw A
3 Cigarette lighter connector
5 Storage compartment
6 Hole cover
7 Screw B
8 Rear console
9 Screw C
10 Front console
11 Screw D
12 Under cover
4. Install in the reverse order of removal.
Attached Thumbnails DIY: Whole navigation System!-concel.jpg
Old Apr 27, 2005 | 06:32 AM
RX8 XTC's Avatar
INTERIOR TRIM
LOWER PANEL REMOVAL/INSTALLATION
1. Pull the upper part of the lower panel, and detach clips A.
2. Detach clips B from the dashboard and remove the lower panel.
SIDE PANEL REMOVAL/INSTALLATION
2. Remove the front side trim.(See FRONT SIDE TRIM REMOVAL/INSTALLATION .)
3. Detach clips A and B, using a flathead screwdriver wrapped with protective tape.
4. Pull the side panel outward and detach tab C from the dashboard, then remove the side panel.
5. Install in the reverse order of removal.
Attached Thumbnails DIY: Whole navigation System!-panel1-2.jpg
Old Apr 27, 2005 | 06:37 AM
RX8 XTC's Avatar
AUDIO UNIT
CENTER PANEL MODULE REMOVAL/INSTALLATION
2. Remove the lower panel.(See LOWER PANEL REMOVAL/INSTALLATION .)
3. Remove the console.(See CONSOLE REMOVAL/INSTALLATION .)
4. Remove in the order indicated in the table.
1 Screw
2 Bolt
Center panel module
(See Center Panel Module Removal Note .)
4 Connector
5 Antenna feeder
CAUTION:
• When installing the center panel module, make sure that the wiring harness and antenna feeder
are not caught between the unit and dashboard.If the wiring harness or the antenna feeder is
caught between the unit and dashboard, it may cause malfunctions.
1. Pull the center panel module outward, detach clip A from the dashboard, and then remove the center
panel module.
Attached Thumbnails DIY: Whole navigation System!-audio-unite.jpg
Old Apr 27, 2005 | 07:03 AM
RX8 XTC's Avatar
VENTILATOR GRILLE REMOVAL
Center
1. Remove the console.(See CONSOLE REMOVAL/INSTALLATION .)
2. Remove the center panel module.(See CENTER PANEL MODULE REMOVAL/INSTALLATION .)
3. Remove the screws.
4. Pull the ventilator grille outward and detach clips A and B.
5. Detach tab C and remove the ventilator grille.
Attached Thumbnails DIY: Whole navigation System!-center-ventilator.jpg
Old Apr 27, 2005 | 07:08 AM
RX8 XTC's Avatar
LCD UNIT
LCD UNIT REMOVAL/INSTALLATION
2. Remove the following parts:
a. Lower panel(See LOWER PANEL REMOVAL/INSTALLATION .)
b. Console(See CONSOLE REMOVAL/INSTALLATION .)
c. Center panel module(See CENTER PANEL MODULE REMOVAL/INSTALLATION .)
d. Center ventilator grille(See VENTILATOR GRILLE REMOVAL/INSTALLATION .)
3. Remove in the order indicated in the table.
1 Screw
2 LCD unit (See LCD Unit Removal Note .)
3 Connector
1. Pull the lower LCD unit outward, detach clip A from the dashboard, and then remove the LCD unit.
Attached Thumbnails DIY: Whole navigation System!-lcd-unite.jpg
Old Apr 27, 2005 | 07:13 AM
RX8 XTC's Avatar
CENTER SPEAKER REMOVAL/INSTALLATION
e. LCD unit(See LCD UNIT REMOVAL/INSTALLATION .)
1 Screw
2 Center speaker
3 Connector
Attached Thumbnails DIY: Whole navigation System!-center-speaker.jpg
Old Apr 27, 2005 | 07:21 AM
RX8 XTC's Avatar
COLUMN COVER REMOVAL/INSTALLATION
1. Disconnect the negative battery cable.
2. Remove the upper column cover.
3. Remove the ignition key illumination.(See IGNITION KEY ILLUMINATION BULB
4. Remove the screws.
5. Remove the lower column cover.
IGNITION KEY ILLUMINATION BULB REMOVAL/INSTALLATION
2. Remove the column cover.(See COLUMN COVER REMOVAL/INSTALLATION .)
3. Remove the ignition key illumination bulb.
Attached Thumbnails DIY: Whole navigation System!-column-cover.jpg
Old Apr 27, 2005 | 07:33 AM
RX8 XTC's Avatar
OK Now the Manuel did not say how to take the steering wheel their are ( 4 ) bolts HOLDING the steering wheel. you only NEED to take them 4 bolts of to get the whole thing Out of the way when you take off the Dash Bored.
Mark How the steering shaft/wheel alignment was before taking it out because you can Adjust it by moving it Up and DOWN that is the shaft is what am referring to.
be very careful when taking the bolts of it is heavy and u don’t want to hurt your self.
Attached Thumbnails DIY: Whole navigation System!-steering-wheel.jpg
Old Apr 27, 2005 | 07:51 AM
RX8 XTC's Avatar
INSTRUMENT CLUSTER REMOVAL/INSTALLATION
1. Remove the column cover.(See COLUMN COVER REMOVAL/INSTALLATION .)
2. Remove the screw.
3. Pull the instrument cluster outward and remove it.
4. Disconnect the connector.
CAUTION:
• The removed instrument cluster should be placed with the display side up to prevent grease from
leaking from the meters.
Attached Thumbnails DIY: Whole navigation System!-instrument-cluster.jpg
Old Apr 27, 2005 | 07:58 AM
RX8 XTC's Avatar
GLOVE COMPARTMENT REMOVAL/INSTALLATION
1. Pull the stay damper in the direction shown in the figure, and detach the connecting part between the
glove compartment and the stay damper.
2. Press the stopper in and remove it.
3. Lower the glove compartment.
4. Detach the clips from the dashboard and remove the glove compartment.
Attached Thumbnails DIY: Whole navigation System!-glove-compartment.jpg
Old Apr 28, 2005 | 05:38 AM
RX8 XTC's Avatar
DASHBOARD GARNISH REMOVAL/INSTALLATION
2. Remove the instrument cluster.(See INSTRUMENT CLUSTER REMOVAL/INSTALLATION .)
4. Pull the dashboard garnish outward, and detach clips A.
5. Remove the dashboard garnish.
Attached Thumbnails DIY: Whole navigation System!-garnish.jpg
Old Apr 28, 2005 | 05:42 AM
RX8 XTC's Avatar
A-PILLAR TRIM REMOVAL/INSTALLATION
1. Partially peel back the seaming welt.
2. Detach clips A using a fastener remover.
3. Pull the A-pillar trim and detach clip B (1).
4. Pull the A-pillar trim upward and remove clip B from the A-pillar trim (2).
5. Pull clip B out and rotate it 45° .
6. Remove clip B from the grommet by pulling it upward.
7. Install in the reverse order of removal.
Attached Thumbnails DIY: Whole navigation System!-pillar-trim.jpg
Old Apr 28, 2005 | 06:31 AM
RX8 XTC's Avatar
See Pix for instrection !
Attached Thumbnails DIY: Whole navigation System!-airbag2-copy.jpg   DIY: Whole navigation System!-air-bag-info-copy.jpg
Old Apr 28, 2005 | 06:38 AM
RX8 XTC's Avatar
DASHBOARD REMOVAL/INSTALLATION
a. Console (See CONSOLE REMOVAL/INSTALLATION .)
b. Glove compartment (See GLOVE COMPARTMENT REMOVAL/INSTALLATION .)
c. Side panels (See SIDE PANEL REMOVAL/INSTALLATION .)
d. Lower panel (See LOWER PANEL REMOVAL/INSTALLATION .)
e. Column cover (See COLUMN COVER REMOVAL/INSTALLATION .)
f. Steering shaft installation nuts (See STEERING WHEEL AND COLUMN
g. A-pillar trim (See A-PILLAR TRIM REMOVAL/INSTALLATION .)
1 Nut
2 Bolt A
3 Bracket
4 Cap
5 Bolt B
WARNING:
• Removing the dashboard without supporting it can be dangerous. The dashboard may fall and
injure you. Always perform the following procedure with at least another person.
4. Remove the dashboard.
5. Take the dashboard off from the front driver-side door opening.
DASHBOARD DISASSEMBLY/ASSEMBLY
1. Remove the following parts:
a. Center panel module (See CENTER PANEL MODULE REMOVAL/INSTALLATION .)
b. Passenger-side air bag module (See PASSENGER-SIDE AIR BAG MODULE
c. Instrument cluster (See INSTRUMENT CLUSTER REMOVAL/INSTALLATION )
d. A/C unit (See A/C UNIT REMOVAL/INSTALLATION .)
e. Blower unit (See BLOWER UNIT REMOVAL/INSTALLATION .)
2. Disassemble in the order indicated in the table.
3. Assemble in the reverse order of disassembly.
Attached Thumbnails DIY: Whole navigation System!-dash-bord-1.jpg   DIY: Whole navigation System!-dash-bord-2.jpg
Old Apr 28, 2005 | 06:43 AM
RX8 XTC's Avatar
SCUFF PLATE
INNER SCUFF PLATE REMOVAL/INSTALLATION
1. Pull the inner scuff plate upward, detach clips A from the body, and then remove the inner scuff plate.
2. Install in the reverse order of removal
Attached Thumbnails DIY: Whole navigation System!-inner-scuff-plate.jpg
Old Apr 28, 2005 | 06:46 AM
RX8 XTC's Avatar
PILLAR TRIM
REAR PILLAR TRIM REMOVAL/INSTALLATION
1. Remove the rear seat.(See REAR SEAT REMOVAL/INSTALLATION .)
2. Remove the inner scuff plate.(See INNER SCUFF PLATE REMOVAL/INSTALLATION .)
3. Remove the tire house trim.(See TIRE HOUSE TRIM REMOVAL/INSTALLATION .)
4. Remove the cap using a fastener remover.(Vehicles with curtain air bags)
5. Remove the bolt.(Vehicles with curtain air bags)
6. Remove the fastener.
7. Detach clips A and locator pin B, using a fastener remover, and remove the rear pillar trim.
8. Install in the reverse order of removal.
Attached Thumbnails DIY: Whole navigation System!-rear-pillar-trim.jpg
Old Apr 28, 2005 | 06:49 AM
RX8 XTC's Avatar
REAR SIDE TRIM
REAR PACKAGE TRIM REMOVAL/INSTALLATION
a. Rear seat(See REAR SEAT REMOVAL/INSTALLATION .)
b. Inner scuff plate(See INNER SCUFF PLATE REMOVAL/INSTALLATION .)
c. Tire house trim(See TIRE HOUSE TRIM REMOVAL/INSTALLATION .)
d. Rear pillar trim(See REAR PILLAR TRIM REMOVAL/INSTALLATION .)
2. Remove the rear package side trim fasteners.
3. Pull the rear package side trim upward and detach clips A from the body.
4. Detach tabs B and pin C from the rear package center trim.
5. Detach tabs D from the body and remove the rear package side trim.
6. Pull the rear package center trim upward and detach clips A, tabs E, and locator pin F from the body.
7. Detach tabs D from the body and remove the rear package center trim.
Attached Thumbnails DIY: Whole navigation System!-rear-package.jpg
Old Apr 28, 2005 | 07:11 AM
RX8 XTC's Avatar
TRUNK SIDE TRIM REMOVAL/INSTALLATION
1. Remove the trunk end trim.(See TRUNK END TRIM REMOVAL/INSTALLATION .)
2. Remove the fasteners, then remove the trunk side trim.
1. Remove the fasteners.
REMOVE ONELY THE PEACE that u see in the Pic
Attached Thumbnails DIY: Whole navigation System!-trunk.jpg
Old Apr 28, 2005 | 07:13 AM
RX8 XTC's Avatar
.this is the fun part, Now am Sure u are able to see the Wires and where they all go just start by Disconnecting the wires ONLY AND ONLY Disconnect the wires that are PART OF THE THICK MAIN WIER HARNES's.
Just remember how the wires are lay' d out in the car and oh yeah you do not need to remove the whole carpet just Move it out of your way when working under the carpet
Old Apr 28, 2005 | 07:21 AM
RX8 XTC's Avatar
ANTENNA FEEDER
ANTENNA FEEDER LOCATION
1 AM/FM antenna feeder No.1
2 AM/FM antenna feeder No.2
3 GPS antenna feeder
In this Pic u can see where is the GPS and AM/FM antenna are at
In Pic #2 i was pointing at where woulde the GPS antenna will go.
in pic #3 am showing u where woulde it be at its under that Cover that is in the middile.
Attached Thumbnails DIY: Whole navigation System!-gps.jpg
Old Apr 28, 2005 | 07:24 AM
RX8 XTC's Avatar
CAR-NAVIGATION UNIT
CAR-NAVIGATION UNIT REMOVAL/INSTALLATION
2. Remove the console.(See CONSOLE REMOVAL/INSTALLATION .)
1 Connector
2 Bolt
3 Car-navigation unit
Attached Thumbnails DIY: Whole navigation System!-navi-dvd-player.jpg
Old Apr 28, 2005 | 07:40 AM
RX8 XTC's Avatar
to Put back every thing together again do every thing in back Order i do hop this info and D.I.Y Will help a lot of People out their i am Sorry for using the PDF format Pix and words as well the reason i did it that way it was a lot easier + it give a lot more info than what i probably would of gave you so if any one gets stuck or I missed something Out i will be glade to help and Post extra Info to help out i did my best at this.
Thanks for the People who helped me in doing this by supplying some info to me.
here is the Thred that i started when i was attempting to install the navi system click here
Old Apr 28, 2005 | 07:44 AM
cgrx's Avatar
DRIVEN
you are insane ! :D
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
