Removing Btake Pads - Any tips
Old Apr 9, 2005 | 07:46 PM
mikeyr's Avatar
i need a new photo
Question Removing Btake Pads - Any tips
Am going to paint the calipers, have a copy of xcelr8's great DIY guide, but read a few conflicting reports on removing the brake pads. (only covers front calipers too.)
Taka etc, know few of you have upgraded pads, any tricks? Are the pads easy to reinstall? Few years since I have done this, vaguely remember having a hard time with rear pistons one time??
Appreciate any tips! :o
Old Apr 9, 2005 | 08:55 PM
mikeyr's Avatar
i need a new photo
OK found out about the rear brake caliper tool, as I don't have one and there are no "sears" handy, anyone else bought one in Aus or NZ? One post i read said the guy used his angle grinder chuck key?
Old Apr 10, 2005 | 04:14 PM
takahashi's Avatar
hehe I did not see your name calling...
I have my done by a professional. Did not notice any comment made by him during the process.
Where can I get some Caliper paint locally???
Old Apr 10, 2005 | 04:43 PM
Hymee's Avatar
Race Steward
For the rear caliper "tool", I'm assuming you refer to the tool to wind the piston back in?
I got Phil to do that bit, and he used a big stonking pair of multigrips, from memory. Same as what I used to squeeze the front pistons back in.
Don't forget to watch the fluid level in the reserviour...
I only replaced the pads, and you don't need to take the whole caliper off to do that, just one bolt, and it swings away from the rotor to allow access to the pads. For the front calipers you remove the bottom bolt, and for the rear calipers, remove the top bolt. Also, you need to remove the hand-brake linkage from the rears - fairly simple to do.
Cheers,
Hymee.
Old Apr 10, 2005 | 06:22 PM
Gibbo's Avatar
In between cars, RX8-less
Supercheap auto have the caliper presses. About $20.00
Let me know how it goes, I am getting tempted, the car is looking a bit plain.
Old Apr 10, 2005 | 07:51 PM
mikeyr's Avatar
i need a new photo
Thanks all,
Taka
I picked up the Holts Duplicolor kit from my local Repco (NZ I know, but I would expect them to have in Aus too), on special this week at NZ$21, cheaper than the US prices everyone has posted!? It's includes everything, tin of paint, cleaner, brush even a bloody paddle pop stick stirrer. It's the "ceramic added" paint" which is the highest heat resistance, 1500C i think! Many posts reckon the paint and brush gives a better finish and you don't need as much masking.
Hymee
Ta, am going to use ac clamp, yank's reckon it works on the front and needlenose pliers or the magic tool if i can find for the back. I'll have to remove the pads or risk getting paint on them
Gibbo,
Ditto, they had a nice yellow colour and orange (ezzy, probably not bright enough for you). Although Gibbo, how will anyone be able to see your nicely painted calipers after being flashblinded by the mags?
Cheers all
Mike
Oct 3, 2015 09:51 AM
Racingjunkie
Sep 29, 2015 05:05 PM
xAgyex
Sep 28, 2015 08:54 AM
Learners_Permit
Sep 27, 2015 07:38 PM
