how to program keyless remote remote ?
Old Apr 6, 2005 | 02:41 AM
williamngRX8's Avatar
Flyboy
how to program keyless remote on my rx8 ?
got a brand new keyless remote.
can anyone share how to program it ? thanks
Old Apr 6, 2005 | 05:32 AM
Go48's Avatar
Go here:
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-code-your-own-key-remote-43873/
Before posting questions such as this, it's a good idea to do a search and thereby avoid the flames.
Old Apr 9, 2005 | 09:09 PM
nsxpowered's Avatar
I got two remote on ebay as well and I can't program the 2004 RX8. When following the instructions, I got everything until I get to the step when I push the new transmitter twice (then nothing happens). Did it over and over again. The discreptency that I noticed between my original remote was the following:
My original remote:
Visteon Model: 41848
FCC ID: KPU41805
IC: 4238A-12076
TW: "3 ASIAN CHARACTERS" 91LP0424
Ebay remote:
Visteon Model: 41805
FCC ID: KPU41805
CANADA: 4238A 12076
The car is manufactured in Oct of 2003 and billed as a 2004. I swapped batteries from both remote and the original one always worked. When I press the remote twice during programming I just get no response from the car. Any leads? Thanks in advance.
Old Apr 10, 2005 | 06:47 AM
Go48's Avatar
I had the same problem, and eventually found a procedure that worked for me. Try the following, referring to the shop manual page attached.
Make sure your new remote is attached to your key ring and do not remove the key and remote from the ignition until all programming steps are completed.
Run through the first 4 "boxes" exactly as stated in the instructions. (Note the 24 second requirement for the second two "boxes".)
For box #5 which starts: "Verify that door lock actuators...", reach over to the door (which remains open) and manually work the lock on and off one time. (May not be necessary, but it worked for me.)
For the next box, the instruction should read (my change in bold type): Push any button twice on the remote transmitter you are programming. (Don't forget, the remote is attached to the key ring and the key is still in the ignition.)
Continue with the remaining steps and the remote should work. Good luck!
Old Apr 12, 2005 | 08:51 AM
nsxpowered's Avatar
I'll give it a try. Thanks for the input.
Old Apr 12, 2005 | 10:34 AM
Go48's Avatar
You're welcome. Let us know how it goes.
Old Apr 14, 2005 | 07:19 PM
nsxpowered's Avatar
LOL I must be an idiot. Still can't get it to work! I feel like swallowing the remote and declaring victory.
Old Aug 15, 2005 | 10:14 PM
KidZoom's Avatar
Dammit Jim, I'm a doctor.
Hard to read the scan, but worked perfectly the first time. THANKS
Old Aug 16, 2005 | 11:57 PM
Higgs1's Avatar
i tried this & my alarm ended up going off & my damn remote doesnt' work to stop the alarm........so it went off for about 20+ minutes then my damn horn stopped working
Old Jul 20, 2008 | 02:40 PM
ryoko's Avatar
Remote Problems
my remote has recently died, so I changed the battery only to find the remote didn't work. So I've managed follow every step until it says 'push any button twice on the remote', when I do this nothing happens. Now I have a 53 r3 model, now i'm wondering if this has anything to do with it.
Old Mar 8, 2009 | 06:57 PM
RXFORLIFE's Avatar
RX8 Remote Problems
Hey. Does anyone know if there is a special trick to programming these darn remotes. I've spent a whole afternoon trying to do this and I got nothing.
Help Help Help
Old Mar 9, 2009 | 01:38 PM
cody6766's Avatar
Here's how I did it last night
Step 1: Open driver side door and leave open.
Step 2: Lock and Unlock the drivers door using the power door lock switch on the door
Step 3: Insert key into the ignition.
Step 4: Turn Key to ON position and return to Lock (off) position. Do this 3 times within 10 seconds. LEAVE key in the ignition in Lock (off) position.
Step 5: Close and open the drivers door 3 times. Leave door open after this step
Step 6: ECU should respond by locking and unlocking the doors once.
Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
Step 8: Additional remotes, repeat Step 7 for up to 3 remotes total.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series (about 4) of door locks and unlocks. You're done!
Old Aug 9, 2009 | 12:55 PM
Benjamz's Avatar
Tony says, RX8s are GREAT
Step 5 is the same as pushing the door ajar switch on the rear door 3 times.
I think my remote went bad.... crap.
Old Aug 11, 2009 | 11:23 AM
mikebrow74's Avatar
Make sure you're going to full off/lock and not just the off position when you turn the key. As previously stated the door locks will cycle when the receiver is ready to receive the new remote signal.
Old Aug 24, 2009 | 07:24 PM
marbgroovy's Avatar
For what model/year are these steps good for? I have a 2006 RX8, tried the steps but nothing seems to happen. Is there another DIY solution? I am using the OEM keyless remotes (credit card style).
Old Feb 17, 2010 | 02:09 PM
rx8jamaica's Avatar
How to programme Keyless entry ?
Still no luck in programming my keyless entry remote. I have tried both ways.
Remote :Visteon Model 41805
FCC ID: KPU41805
Canada: 4238A 12076.
Can anyone help ?
Old Feb 18, 2010 | 07:39 PM
RXFORLIFE's Avatar
Reply for rx8jamaica
Hey have you gotten your problem solved yet? I think the same thing happened to me.
I think i have your answer. What year is your RX?
Krisflow
Old Feb 19, 2010 | 05:17 PM
Musker's Avatar
Yeah I bought a Visteon Model 48105 off of ebay which was claimed to work on an RX8
Cosmetically it looks exactly like mine, but mine says Visteon Model 41848
My car is a 2004 MT
Old Feb 20, 2010 | 10:54 PM
rx8jamaica's Avatar
I called the dealer and they said that the Visteon Model 41805 won't work, i have to get the Visteon Model 41848, so i have ordered that model and i will post when i have tried to programme it.
Old Feb 21, 2010 | 08:53 AM
RXFORLIFE's Avatar
Answer for rx8jamaica
Thats what i was gonna tell you that when I got the Visteon Model 41805 it did not work and I sent it back to the people who sold it to me on ebay. They exchanged it for the Visteon Model 41848 at no charge. It programmed perfectly when i got it. Paid less than 20 bucks for it.
RXForlife
Old Feb 27, 2010 | 01:20 PM
blingleng's Avatar
remote problem.
Ok, so i did all the steps but when i press the remote twice nothing happens... But after i pull the key out it will unlock and lock like how u guys said.
Can anyone still help me.
Dealer wants around 100 bucks to do this. I aint down for that.
Help me!!
Old Feb 28, 2010 | 10:58 AM
RXFORLIFE's Avatar
Remote Problem
What year is your Rx-8? What does your remote say on the back?
RXFORLIFE
Old Feb 28, 2010 | 05:08 PM
blingleng's Avatar
Its a 2004.
The remote on the back says the following....
Visteon Model 41848
FCC ID: kpu41805-12076
Old Mar 2, 2010 | 01:59 PM
rx8jamaica's Avatar
I got the remote with Visteon Model 41848; FCC ID : KPU41805; IC: 4238A-12076, and it works fine when i programme it.
Thanks for helping guys !!
Old Mar 4, 2010 | 02:40 PM
blingleng's Avatar
Everything works as far as the intrustions until the part where you hit a button 2 times.... Ive replace the batt as well.... When i hit the button 2 times i get nothing, until i pull the key out of the ignition then it will lock and unlock like it says......
Am i doing something wrong here?
