View Poll Results: Which gear do you use?
1st
61
43.88%
Reverse
4.32%
Other
4.32%
None (Neutral)
32
23.02%
First for nose uphill, Reverse nose facing downhill.
31
22.30%
First for nose facing downhill, Reverse for facing uphill.
2.16%
Voters: 139. You may not vote on this poll
MT owners, parking?
Old Apr 5, 2005 | 01:18 AM
ccrooks's Avatar
MT owners, parking?
What gear do you put the car in when you park?
Old Apr 5, 2005 | 01:25 AM
Captain Amazing's Avatar
I put her in first.
Old Apr 5, 2005 | 01:34 AM
BlueFrenzy's Avatar
Rotary Powered Decepticon
first gear if I'm on an incline and reverse if I'm on a decline.
Old Apr 5, 2005 | 01:36 AM
truemagellen's Avatar
Attracts tree branches
exactly...someone want to change the poll
Old Apr 5, 2005 | 01:42 AM
ccrooks's Avatar
what should i change it to?
what gear do you put your car in on flat ground?
Old Apr 5, 2005 | 01:51 AM
Mikelikes2drive's Avatar
when the car is flat... i put my ebrake up
if there is a slight incline or a slight decline i stick it in either first or reverse
Old Apr 5, 2005 | 01:55 AM
usually first...but is really doesn't matter first or reverse is fine
it is easier to put it in first that is why I do it :p
always e-brake no matter what
Old Apr 5, 2005 | 02:05 AM
ccrooks's Avatar
yeah... this is my first MTX car, and i've heard different theories about 1st or reverse... i was just curious
Old Apr 5, 2005 | 02:07 AM
Aurelius's Avatar
I live in Florida. The highest point in the state is a bridge. Neutral here...
Old Apr 5, 2005 | 03:45 AM
Leadfoot27's Avatar
Also, if you park on a steep incline it doesnt hurt to turn the front wheels.
Old Apr 5, 2005 | 04:41 AM
6speed8's Avatar
General rule is to use the lowest gear for parking. Reverse is definitely ok. I use first gear always no matter on incline or level. Always pull up the parking brake first, before letting out the clutch so the brakes do the holding. Leaving it in gear is just a safety in case the P-brake fails.
Old Apr 5, 2005 | 04:42 AM
6speed8's Avatar
Old Apr 5, 2005 | 04:43 AM
6speed8's Avatar
Old Apr 5, 2005 | 06:24 AM
apotocki's Avatar
Yep, ditto 6speed8......first gear. Usually, I stop, pull up the e-brake, rev it to about 5k, shut it off, then release the clutch.
Old Apr 5, 2005 | 07:07 AM
shocar's Avatar
On an incline (nose higher than tail) reverse gear should be used. On a decline first gear should be used. On a non-rotary engine, you don't ever want it to turn opposite from the normal running direction. Selecting the wrong gear when parked on a hill could cause that to happen.
Old Apr 5, 2005 | 07:13 AM
rx8wannahave's Avatar
Follower of CHRIST!!!!!!!
Neither, Im in FL too so I have always placed it in N...I actually get ticked if someone leaves (in my past cars) my car in 1st.
E-Break and turning the wheel is the method I use but if the incline or decline is really bad then, like he said:
Old Apr 5, 2005 | 08:18 AM
JonsToy's Avatar
Registered Rep
The Florida crowd sticks together! I, too, place the car in neutral and pull up firmly on the e-brake (though not too hard, I wouldn't want it to break). The e-brake seems to hold the car just fine down here.
Old Apr 5, 2005 | 08:56 AM
poorman's Avatar
Can someone explain in more detail?
currently i use
Old Apr 5, 2005 | 09:39 AM
ÜberJumper's Avatar
The big question is, which way do you turn your tires when parked on a hill, facing uphill, when there's a curb?
Shocar:
What the HECK are you going on about? I was taught to always put a 'normal' engine car in First gear if facing up hill, and in reverse if facing down hill. I believe our province's driver instruction manuals even state the same thing.
Even the aussies say the same thing (last point on page).
Saskatchewan, same thing (search for brake, it'll be in the section about parking).
This article indicates you ALWAYS put it in reverse (no matter which way the car is pointed).
Louisiana teaches up=first, down = reverse.
Old Apr 5, 2005 | 09:47 AM
G8rboy's Avatar
Mmmmm... Rotary Donut
Why would you be ticked? It's always safer to keep it in gear when parked... if the ebrake ever fails or isn't engaged enough, do you want to find your car banged up in the middle of a parking lot? I lived in Florida for 20 years and I've seen plenty of parking lots with valleys in the middle for drainage... my buddy once came out of the office to find his Integra 20 feet from his parking spot after it slowly rolled away... he was fortunate it didn't bang into anybody else's car.
Old Apr 5, 2005 | 10:39 AM
Nubo's Avatar
Lubricious
Yeah, the biggest hill in Fl is an overpass :D
I was "trained" to use 1st gear. Logically though, I'd think the highest gear would give the most "staying" power as it would be harder to turn the engine with the lower torque. Ah well, 1st has always been good enough, and too late to change now...
Old Apr 5, 2005 | 10:44 AM
Elara's Avatar
Shocar:
Yes, shocar, I think you may typed it backwards- there's no point in putting a car facing up a hill in reverse- that's just going to encourage it to roll backwards if the handbrake for some reason fails(not that the gear will catch it, necessarily, if it's a steep hill, but it may help on less of an incline). And vice-versa for the car facing down a hill.
I edited the poll for the two above options.
Old Apr 5, 2005 | 10:49 AM
G8rboy's Avatar
I think officially the high point is a landfill outside of Orlando :D
Old Apr 5, 2005 | 10:51 AM
ptiemann's Avatar
Exclamation
@Aurelius:
Good luck with that attitude. I parked mine on a flat parking lot and apparantly the wind was strong enough to overcome the parking brake.
There have been several threads on this board finding that the parking brake is exceptionally weak on the -8 mostly concluding that we (who relied on the P-brake and left it in neutral) were idiots.
Take a look here:
https://www.rx8club.com/rx-8-discussion-3/little-warning-about-parking-brake-31420/
and check out the pictures of the "incline"
https://www.rx8club.com/attachment.p...chmentid=20875
Old Apr 5, 2005 | 11:03 AM
ptiemann's Avatar
Post
And this is the thread where some people were made fun at:
("..For Those Born Without A Brain..")
https://www.rx8club.com/rx-8-discussion-3/need-vent-big-problem-54993/
However, something good came out. rotaryjoe explained how we can easily adjust our parking brake:
"Hey guys sorry for the post if someone already said it but there is an adjustment just inside the center console, top right corner there is a piece of plastic you pop out and there is a screw or something u can adjust to make the brake stronger. just my .02 cents."
