Anyone have Racing Beat Screen Install Instructions?
Old Mar 28, 2005 | 11:57 AM
m82492's Avatar
I'm looking for a PDF of the install instructions for the Racing Beat Oil Cooler and Air Conditioning Condenser screens. I'm having it done by a local guy but he's asking for the instructions ahead of time.
Old Mar 28, 2005 | 05:05 PM
ScudRunner's Avatar
On time, on target
Email Racing Beat and ask. They will email them to you right away.
Old Mar 29, 2005 | 08:35 AM
orbist's Avatar
beyond the ultraworld
Its dead easy, the oil cooler grills just slide in between the oil coolers and rubber surrounds. The main grill requires the removal one by one of the bolts holding the A/C condenser and the insertion of the brackets before putting the bolts back. Then the grill slips behind the brackets and is bolted on.
I did mine yesterday! I did have some problems with the fixing supplied to bolt the grill to the brackets and ended up just using standard nut, washer and bolt!
Old Mar 29, 2005 | 10:44 AM
Tigster's Avatar
RX8 ADDICTED!!!
It is very easy, you can do it yourself in less than 1 hour. If you are doing the oil cooler screens I suggest you do the AC Condensor screen at the same time as well. Do a search and you will see a few people have damaged the ac condensor and it is not covered under warranty. I can get you a pdf if you really need it let me know.
Old Mar 29, 2005 | 12:08 PM
bureau13's Avatar
You pretty much have to remove the front nose (which is MUCH easier than it sounds) to do the oil cooler screens. I would imagine that would make the AC condenser screen a lot easier as well, but I already had my oil cooler screens done when I got the condenser screen, and I did it simply by unbolting the bottom protective panel from the front and sliding it in.
I'm sure Racing Beat will be able to email them to you as someone else said though...they tend to be really good about stuff like that.
jds
Old Mar 29, 2005 | 04:03 PM
Tigster's Avatar
RX8 ADDICTED!!!
here are my instructions, I forgot I can scan them and save as a PDF... Hope this helps. The photos didn't come out perfect though you'll get the idea.
File Type: pdf
File Type: pdf
File Type: pdf
Old Mar 29, 2005 | 08:34 PM
m82492's Avatar
Perfect! Thank you all!
Old Mar 29, 2005 | 08:52 PM
Tigster's Avatar
RX8 ADDICTED!!!
Ask and you shall receive.....
Pelleilee
Sep 29, 2019 10:07 AM
motohegg
Aug 23, 2015 08:14 AM
PTQLam
Aug 16, 2015 05:40 PM
RXeckless
Aug 16, 2015 12:51 PM
