A/C cutout
Old Jun 21, 2003 | 12:50 AM
eccles's Avatar
Prodigal Wankler
Smile A/C cutout
It was previously asked whether the A/C cuts out under full throttle conditions, to provide all available power for accellerations. Well, I've just started watching the RX-8 Technical Highlights CD, and I can report the answer is YES, it does.
Apparently, the PCM (as they're calling the ECU), automatically disengages the A/C compressor for 5 seconds when the throttle opening exceeds 65%. (No mention is made of what happens if the throttle remains wide open for more than 5 seconds.)
Old Jun 21, 2003 | 01:13 AM
91vert's Avatar
Awesome! Give us that extra little bit of power when we need it.
To hell with staying cool!!
Old Jun 21, 2003 | 02:22 AM
MarkRx's Avatar
I think you should be coverd... think about it, if you are in second gear for ex. and you floor it, i think you will be shifting into 3rd within 5 seconds Of course the higher in the gears you go the longer between shifts... but if you are going that fast on a public street you should get a ticket... then again if you are on an open part of land and want to see what it can do, you shouldnt have the a/c on in the first place
Old Jun 21, 2003 | 09:21 AM
MikeW's Avatar
The AC compressor would not re clutch because the rpm difference is too great. This would lead to too much stess on the belt.
I think that MB AMG SC V8 automatically engages the supercharger at 3500 rpms because anything higher would lead to eventual belt failure (and it has its own drive belt) and the supercharged V6 engages at 2500-it uses a common belt with all the other accessories.
Old Jun 21, 2003 | 11:22 AM
Rich's Avatar
Junior Member
The Miata has the same feature.
Old Jun 21, 2003 | 12:21 PM
eccles's Avatar
Prodigal Wankler
The Miata is supposed to have a similar feature, but it's never worked on either my '99 or my wife's '02, nor that of anyone else who I've asked.
Old Jun 21, 2003 | 03:42 PM
P00Man's Avatar
uhhhhh....hello?
artificial turbo boost!
.5lbs thrust baby! blahahha
________
WELLBUTRIN LAWSUIT INFO
RevMeHarder
Jun 1, 2026 02:30 PM
nadodave
Aug 28, 2019 05:55 AM
Epitroch
Epitroch
Oct 24, 2015 12:04 PM
djp6783
Sep 19, 2015 12:12 PM
mazdaverx7
Jul 21, 2015 07:31 PM
