Brakes
Old Mar 23, 2005 | 08:20 PM
Brakes
Ok, I installed new front rotors and all new pads front and rear.
Added new fluid and bled more than 1 quart through the system.
Brakes are very spongy. I have to push 3 to 4 inches instead of tapping them.
Is it possible to back out the piston too far when putting in new pads?
What is causing this spongy Feeling.
I swear there isn't any air in the system.
Do I need to get them pressure bled
Old Mar 23, 2005 | 09:07 PM
Spin9k's Avatar
Momentum Keeps Me Going
Did you bleed the underhood brake fluid tank both before and after you bleed the four wheels?
Old Mar 23, 2005 | 09:10 PM
What?
You talking about the master cylinder?
Old Mar 23, 2005 | 09:20 PM
expo1's Avatar
He's as bad as Can
He is referring to this step mentioned in the shop manual.
Old Mar 24, 2005 | 08:32 AM
TrackAddict's Avatar
I miss my 'Bu
I don't understand air-bleeding. I used a power-bleeder when I flushed my brake fluid and just followed the instructions on it.
Old Mar 28, 2005 | 07:23 AM
Spin9k's Avatar
Don't know about power bleeding specifically, but likely you could do it to the master cylinder as well. Follow directions above (for the car) rather than on the PB pkg.
hufflepuff
May 30, 2016 10:45 AM
Road Cone
Nov 6, 2015 01:52 PM
Oct 3, 2015 09:51 AM
D13
Oct 1, 2015 07:55 AM
