Sunglass Holder Foam dislodging
Old Feb 28, 2005 | 09:04 PM
truemagellen's Avatar
Attracts tree branches
Ok I've had this problem since for a long time and it really is a problem only in the summer on hot days
the black foam insulation in the sunglass holder in the headliner...KEEPS FALLING OUT!
Drives me nutz...in fact during a TSB trip I told the dealer...some of the guys lauged but they said they'lll reapply the adhesive. The did and it worked for about a week...then kept falling out...moving around, sticking to my sunglasses
Anyone have this problem?
Anyone know a fix or suggest a fix?
Old Feb 28, 2005 | 09:07 PM
tiggerlee's Avatar
May Cause Anal Leakage
Velcro?
Old Feb 28, 2005 | 09:15 PM
hmm that still involves adhesive
Old Feb 28, 2005 | 09:21 PM
mr2000x's Avatar
pro_digi
i know this might not help u now
but prevention could come with one of those
reflective sunshields,
which reminds me i need to order one!
Old Feb 28, 2005 | 09:27 PM
I have one :D but I never use it since I live in minnesota and the car is garage kept at home and work
any alternative adhesive suggestions...would be great
hmmmmmmmmm should I have them replace the overhead console just for a new foam piece pre-assembled at factor? :p
tiggerlee's Avatar
I remember a friend in Illinois used this on his carpeting on his Camaro. http://products3.3m.com/catalog/us/e...er/output_html
But since you'll be applying to plastic I'm not sure.
Old Mar 8, 2005 | 11:56 AM
any other ideas?
Old Mar 8, 2005 | 01:19 PM
Gambit's Avatar
Screw gas mileage
krazy glue
that'll stick anything to anything
Old Mar 8, 2005 | 01:41 PM
Nubo's Avatar
Lubricious
3M makes an adhesive referred to as "Gorilla Snot". Should hold it forever. Of course with any adhesive, preparation is important to get a bond. You may need to do some light sanding and wipe down good with alcohol to remove any old, crumbly adhesive and let dry, before using the glue.
Gorilla Snot = 3M #8001 Weatherstrip Adhesive
Another adhesive I've had good luck with is something called "Marine Goop". Used it to re-attach my Miata's top to the overhead rails and lasted about 8 years until I got rid of the car. Stinks like rotten meat though. Takes a while for the smell to fade.
Old Mar 8, 2005 | 01:56 PM
English's Avatar
So many roads to ride...
Gorilla snot has ruined a couple of projects of mine because I didn't account for the area it oozes. The stuff 'foams up' and comes out all over the place...use sparingly.
Perhaps a nail gun and 3/4" ribbed nails would hold your foam pad in place.
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
vapor2
Jul 9, 2016 07:35 AM
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
