Oil Change
Old Feb 28, 2005 | 10:37 AM
skerrane's Avatar
Oil Change
I know this is probably a dumb question and has been asked before. I did do a quick search but couldnt find an answer before I get flamed.
I bought my rx-8 about 2 weeks ago. Already at 1400+ miles and I checked the oil and I think its about half empty. The foam made it hard to tell. How much oil should I add.
Mind you I'm not the type of person who has ever changed his own oil so I havent a clue wether it need 1/2 a quart or 4 quarts. Hell, I had hard enough time trying to reach and read the dipstick
Thanks for the help
Old Feb 28, 2005 | 10:39 AM
StealthTL's Avatar
Safe way.....
Just add a half, then recheck, if it's still low, add the other half.
S
Old Feb 28, 2005 | 12:49 PM
skerrane's Avatar
thanks, I know its a dumb question but I would never figure it out til oil was spilling over the top, and I still got 6000 miles before the first oil change
Old Feb 28, 2005 | 05:49 PM
beachdog's Avatar
If you are planning to change at the 7500 mile interval in the owner's manual, be sure to check your oil level every 2-3 tanks of gas. Most of us burn a qt every 1500-2000 miles.
Which leads to the next point...why 7500 miles before changing? Most do the first change within the first 1000-3000 miles even if they plan to do longer intervals later. The first change is the most critical since it gets rid of the break-in crud.
If you plan to keep the 8 a long time, you might want to consider a shorter interval. I go with 4000 myself after doing the first at 1500 and the second at 4000.
Old Mar 1, 2005 | 12:35 PM
skerrane's Avatar
just because of the manual. but since you mention the break in crud maybe ill just go get the oil changed this week and then i get free top offs by them
thanks for the advice
Old Mar 1, 2005 | 01:39 PM
Rotario's Avatar
Long Member
That's good advice from Beachdog, and it's not particular to just the rotary engine (ie: piston engines apply too). I've been fortunate enough to have a lot of new cars in my life, and I always do the first oil change at ~1k miles. That's just me, but I figure that it's really cheap insurance to get the most miles possible out of the engine.
My $0.02,
Bill
Skyl3r
Dec 2, 2019 04:51 PM
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
talonhart2
Aug 26, 2015 04:14 PM
akagc
Aug 11, 2015 07:07 PM
RotaryRider
Jul 20, 2015 07:05 AM
