Block heater -- that's interesting
Old Feb 23, 2005 | 04:01 PM
V_for_velocity's Avatar
One more couldn't hurt
From: Saskatoon, SK -- go to Winnipeg then head west
I was under the impression that the RX-8 doesn't accept a block heater (for whatever reason) but my dealer assures me that it can and that mine has one installed. And on inspection that's what it appears to be. It's definitely not a pump that heats and circulates coolant. The service mgr. in a fit of honesty said Mazda Canada "doesn't specifically recommend" installing block heaters but they do it anyway because it gets so ****ing cold here, it's the only commensense thing to do. (He didn't say "****ing," though. So now I'm hoping they knew what they were doing and that my engine won't blow up one fine day. Comments?
Old Feb 23, 2005 | 09:00 PM
Gord96BRG's Avatar
Interesting to say the least! What sort of block heater? The Renesis can't use the Mazda block heater from the FD RX-7 due to space limitations, and there are no Mazda freeze-plug replacement type of block heaters available as far as I know. Is it a stick-on oil pan heater?
Regards,
Gordon
Old Feb 24, 2005 | 04:54 PM
Mr M's Avatar
Evolution of REvolution
Photos please, we don't have them in Europe and it is *****ing cold here too!
Old Feb 24, 2005 | 05:36 PM
CaptainZoom's Avatar
Have you experienced any drop in the fuel consumption?
I feel that my 8 drinks extremely much when it is cold.
Old Feb 24, 2005 | 06:30 PM
JM1FE's Avatar
Thumbs up
It's probably a tank-type heater. Simple to install, just splice into a heater hose and mount it somewhere. Not very expensive, either. JC Whitney carries them.
Old Feb 25, 2005 | 06:05 AM
Mr M's Avatar
Very simple, never seen one of those before. On inquiry I found out they use them is some of the Scandinavian countries in Europe.
Regarding the initial question, the heater cannot possible cause any damage so I think you are safe to install it. I don't know why Mazda Canada doesn't allow it, probably warranty (coolant leaks). Can you ask them why?
Old Feb 25, 2005 | 06:37 AM
rx8wannahave's Avatar
Follower of CHRIST!!!!!!!
I always thought the 8 might need one of these to avoid the "flood" issue, but I'm in FL so I probably don't need it.
Old Feb 25, 2005 | 10:26 AM
Will do. I have to pick up some floor mats next week and will make some inquiries then.
Old Feb 26, 2005 | 04:33 AM
Mikelikes2drive's Avatar
shaving weight off the 8 is too expensive... gahhh light flywheel pullies racing seats, tit. exhaust. wheels, OH MY GAWD! thats already.... 5000? MORE! 8000??? MORE! including installation and crap.... omy
Old Feb 27, 2005 | 10:48 AM
Uh, are you OK?
Old Feb 27, 2005 | 11:23 AM
JM1FE's Avatar
Uh, are you OK?
Something may have been off with the forum's mySQL database.... I noticed some other misplaced posts around that time.
Old Oct 23, 2006 | 12:34 PM
Marx8nka's Avatar
back to the topic... found that Defa is selling block heaters to RX-8, in Finland. These are not same kind of heaters I have experienced with other models, instead this is just attached to the side of the engine block. Does anyone have any experience of these?
More details
http://www.defa.com/finn_dok_h.php3?...=2&lang=&ndid=
Old Oct 23, 2006 | 12:41 PM
StealthTL's Avatar
Cool Hot topic....
Yes, it's that time again!
If I didn't have one already, I would certainly try that Finnish model.
I have a stick-on on the bottom of the oilpan, works great.
S
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
dezau
RX-8 Racing
10
Mar 9, 2016 09:50 AM
JCTaylor
Sep 30, 2015 07:31 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
GK1707
Sep 27, 2015 07:33 PM
