First oil change
Old Feb 22, 2005 | 04:02 PM
RX8rider's Avatar
Question First oil change
I'll be going for my first oil change this Thursday. I have ~4100 miles on so far. I'll definitly bring up several issues with the mechanic such as:
-it's almost impossible to read the oil level due to all the foam on the dipstick
-rust on rotors
-brakes squeak sometimes
Are there any other issues that you guys have been bringing up when visiting the dealership? Any advice for my first oil change? Thanks
Old Feb 22, 2005 | 04:17 PM
124Spider's Avatar
-rust on rotors
Just a thought--rust on rotors and brake squeaks with disc brakes are both normal behavior. There are aftermarket rotors which have the parts of the rotor which are not meeting the pads painted, so they won't corrode, but the stock rotors will rust if they get wet.
Old Feb 22, 2005 | 04:26 PM
salituro64's Avatar
Check your headlight lenses and make sure there is no film inside (if this is an 04)
Old Feb 22, 2005 | 04:49 PM
RCMarquis's Avatar
#1 in the hood G
Yeah I noticed the foam on the dipstick as well. Anyone have an idea what that's from?
Old Feb 22, 2005 | 04:51 PM
SE3PO's Avatar
Its from water condensation build up coupled with cold weather. I have it too and dont worry too much
Old Feb 22, 2005 | 04:58 PM
StewC625's Avatar
Insanely Yellow
I find that a good hour-long drive at highway speeds cooks off the crisco from the dipstick. Or is it "rotary smegma"?
Looks like something you'd find after a yeast infection, and smells like unburned hydrocarbon.
Old Feb 22, 2005 | 05:05 PM
ddub's Avatar
always preoccupied.
There's foam that forms with all emissions still on the car? That seems odd. The condensation should be taken care of by the PCV valve and there shouldn't be any foam formation. I know my 2nd gen rx7 had absolutely no foam until I did a full emissions removal along with the vacuum rack, which contained the PCV. Afterwards I got foam (water condensation) all the time, but I'm taking care of that with a catch-can and vac source.
It seems weird that the 8 would have foam build-up with full working emissions equipment.
Old Feb 22, 2005 | 06:33 PM
Go48's Avatar
Read the sticky!
Old Feb 22, 2005 | 07:18 PM
salituro64's Avatar
Is there a PCV valve?
Old Feb 23, 2005 | 01:56 PM
SpinninAgain!'s Avatar
There are TSB's for foam on the dipstick and squealing brakes. The dealer should perform those for free.
Rust on rotors is normal. It will wear off with a few applications of the the brakes - until they get wet again.
Rust on hubs shouldn't be normal, but is on the RX-8. If your dealer likes you you might get them to paint the hubs and calipers for you, maybe even for free if they really like you. Otherwise it's fairly easy to do yourself. Check the DIY forum.
Skyl3r
Dec 2, 2019 04:51 PM
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
talonhart2
Aug 26, 2015 04:14 PM
akagc
Aug 11, 2015 07:07 PM
RotaryRider
Jul 20, 2015 07:05 AM
