93 octane
Old Feb 18, 2005 | 11:59 PM
SharkDiver's Avatar
ZoomZoom
93 octane
This may be a stupid guestion but here goes,To get the best performance I should be running the highest octane I can get right?I was reading a thread on another forum about some of them saying you are just wasting your money.I dont know alot about the wankle and this is just another thing I guess.. :o
btw I run 93 here in Indiana..
Shark
Old Feb 19, 2005 | 01:09 AM
jenkins-crew's Avatar
higher octane is better performance.
Old Feb 19, 2005 | 02:16 AM
dazygirl415's Avatar
ok. i've been using 93 since i bought the car and the last time i filled up, i put in 89 just to see if the car would perform differently. so far, no major differences. i can feel "less smooth" in higher revs than compared to the 93 but nothing bad. i'm also getting much better mpg. i may do it again for another tank to get the full effect, but so far i'm not convinced either way.
Old Feb 19, 2005 | 02:37 AM
markd's Avatar
Lawyer in training :)
I'm also running on 89, but I really don't know how smart that is. The rotary engine can be so temperamental and sensitive, you have to be careful. For a few months, I dropped to 87 and it caused really bad engine knocking when I revved the engine high. It also felt a little more sluggish. So far with 89, I'm not having as bad a problem, although I do get the infrequent knock (dealer mechanic, and others here, say it has to do with the fact that the change in octane causes either misfire or screws up the engine timing--I can't remember which). Having used all 3 grades here in GA--87, 89 and 93, I do not notice a change in gas mileage.
Old Feb 19, 2005 | 02:57 AM
Nubo's Avatar
Lubricious
Higher octane resists engine knock better. The RX-8, like many cars nowadays, has "knock sensors". If they sense that knocking is imminent the computer does things like retard ignition timing, to prevent damage to the engine. These anti-knock measure also reduce power. So, it is possible that 93 octane may give you some additional power under conditions such as maximum acceleration where knock is most likely. But, it is not a guarantee of additional power. There are many factors that come into play. Even the manual only mentions a "slight" reduction in power. Whether or not that's important or even noticeable is up to you.
Also, octane rating does not necessarily correlate with the energy content of gasoline. In fact it is possible to increase the octane rating by adding compounds that actually reduce the "energy density" of the fuel. So it is entirely possible that you are getting better mileage with the lower octane. Again, many factors and it depends on how the particular gasolines are being formulated.
Personally I've always followed the school of thought that says don't buy more octane than you need. The manual says I can run 87, and my car seems to have no problems with it so that's what I use. Other peoples' circumstances are different. Such things as altitude can influence octane requirements. Also, how you drive. I think you're taking the right approach by trying different grades. If running a lower grade works for you, go for it.
Old Feb 19, 2005 | 06:35 AM
max5roadster's Avatar
INDY RX8 CLUB - Officer
The octane rating is also a reference to the ignitability or stability of the gas-i.e 93 octane is more stable and burns slower-allowing the engine to run more timing=more power because the flame front and rotor interface are able to make contact at the optimum angle or stroke if we were talking pistions. Under such situations, a lesser grade can ignite prematurely or too quickly, causing detonation or pre-ignition.
Old Feb 19, 2005 | 09:14 AM
markd's Avatar
Wow, very interesting info that I never knew. Thanks for the insight, Nubo and ma5.
Old Feb 19, 2005 | 11:50 AM
SharkDiver's Avatar
ZoomZoom
I guess Ill try a few tanks of 87 and see what happens.Thanks for the info peeps.
shark
Old Feb 19, 2005 | 02:46 PM
Vertigo-1's Avatar
Just keep in mind that you won't necessarily hear or feel every single ping or knock if you use lower octane gas...and by the time you do hear it, you may have already done serious damage to the engine. The rotary in particular is sensitive to knocking due to the apex seals.
Old Feb 19, 2005 | 03:03 PM
irish8's Avatar
Get in ma belly!!
Stick with 93. However, I have heard from reliable sources that a lower octane is better during cold, cold months. Can anybody else confirm this?
- Irish
P.S. I actually read a thread once where someone put 110 octane in their 8!! Nice!
Old Feb 19, 2005 | 05:39 PM
Good info, I better boost upto 93.
Old Feb 19, 2005 | 06:07 PM
GRT8's Avatar
I've used all three grades and haven't noticed any difference in mileage and/or performance. I usually stick w/ 89 mid-grade though.
Old Feb 19, 2005 | 06:15 PM
r0tor's Avatar
i've been using 89 octane for a year and a half now without problems (even with a cz unit)... i get better gas milage with 89 octane and with all the data logging i did i never saw the car act differently that would give more performance with 93 octane when i tried it
Old Feb 19, 2005 | 08:06 PM
rx8cited's Avatar
I'll let y'all know when I get a new engine :D. So far 16 k miles on 87 octane and it's not damaged yet.
Old Feb 19, 2005 | 08:18 PM
AvatarQAZ's Avatar
Not as smart as you
Higher octane does not necessarily mean better performance.
Higher octane means better protection. The higher the octane fuel, the less likely it is to ignite out of phase (or detonate). The more you compress a volatile substance like gas, the higher the temp and the more likely it will, literally, blow up under pressure.
With that in mind, 87 octane SHOULD be the most efficient form of fuel since it is easy to ignite... giving you total burn and full power. But, it may ignite all by itself (sans the aid of a spark plug) and cause trouble in that brittle engine. The manual recommends 91 octane or higher because the compression ratio of our beloved 8 is ~10:1. That is...fairly... high and may cause some detonation on 87 fuel.
Old Feb 19, 2005 | 08:28 PM
mfreilly's Avatar
23000 miles, 99% on 87 octane. Did two tanks of 93 a while back when gas prices dipped. Maybe a little smoother and about a mile/gallon better mileage, but at $.20 /gal price difference it doesn't seem worth it. I'm averaging about 19mpg in mixed driving.
Old Feb 19, 2005 | 09:06 PM
bxb40's Avatar
Rotary Newbie
Mreilly, which brand of gasoline you use in NJ? My car was pinging on Shell 87 but is OK with 89.
Old Feb 19, 2005 | 10:34 PM
mfreilly's Avatar
Mainly, Citgo. Sometimes Sunoco or Shell.
Old Feb 20, 2005 | 02:07 AM
Nubo's Avatar
Lubricious
As a point of argument - the manual does not warn against 87 octane on the basis of engine damage, rather it cites performance. It only cites concern for engine damage with fuels BELOW 87 octane.
Old Feb 20, 2005 | 02:21 AM
Correct me if I'm wrong, but doesn't the manual recommend 91? Why can't I find 91 anywhere? It's either 93 or 89.
Old Feb 20, 2005 | 02:40 AM
AvatarQAZ's Avatar
Not as smart as you
Octane rating is determined by many factors.
91 is the minimum because in places like colorado (mountains), 93 octane is not available because of the air. Octane is rated by the amount of fuel that can be compressed before it blows up. In thinner air (mountains), it is easier to compress the fuel. Hence, in colorado and other such places, their highest octane rating is 91.
Old Feb 20, 2005 | 03:13 AM
Fanman's Avatar
Because you are very lucky. Out here in Cali. the best you can get is 91 octane. I wold love 93 octane, that would allow those of us with turbos to run a little more boost and not have to worry as much about detonation. If you use 93 octane it is fine for the engine. The engine is set to function optimally at a 91 octane. If you put 93 octane or higher it might get you a few more hp, it might not as the engine is a it's peak performance at 91 octane & up. If you use 87 or 89 octane the car will just not function at optimal settings, i.e. it may retard timing and lower your hp. But for around town driving this might not matter to some people.
This subject has been brought up a few times, there have been a few threads on this. I linked an article that was done by Car & Driver on octane ratings & performance. On cars set to run with 87 octane gas (Mustang & Hoda Accord) there was little gain on using 91), but on cars that were recommended to run 91 octane (M3 & Saab Turbo) performance & hp dropped 6%-12% when they used 87. Please no "seat of the pants" performance comments by the peanut gallery please.
Old Feb 20, 2005 | 07:34 AM
I think I will go ahead and just use 93 unless the price just breaks my bank.....
Old Feb 20, 2005 | 09:43 AM
rx8cited's Avatar
Exactly!
Old Feb 20, 2005 | 10:00 AM
Better to be safe than sorry, if you can afford it........
