CA Emissions vs. Federal Emissions
Old Jun 7, 2003 | 01:18 PM
gazita123's Avatar
Question CA Emissions vs. Federal Emissions
I noticed on the VIN # thread, the info had CA Emission package and Federal Emissions package listed, depending on where the vehicle is going.
Here is my question and problem. Is the CA emission package going to be more restrictive or produce less power, or is there a real difference except in the name?
The reason this may be a problem is that I've pre-ordered in CA, but am moving to FL, so I may be able to find one that was not pre-ordered locally in FL.
Old Jun 7, 2003 | 06:21 PM
MazdaMan182's Avatar
Aren't CA emissions more strict? If it were, you should be fine as your car will be cleaner than the other RX-8s there (FL).
Not sure about the technical stuff though (power, restrictive, etc)... someone help?
Old Jun 7, 2003 | 07:31 PM
lefuton's Avatar
tyranosaurus rex-8
california emissions are much stricter. i don't know the details of it, but i know like when you buy certain cars, or..say..a harley for instance (this is the example i am actually familiar with) then you have to pay an extra like $400 for california catalytic converter so the harley will pass smog. anywhere esle and you don't. some cars are the same ways too, but most of the modern cars which are notable clean, ie, say a camry or accord there's no difference as they well exceed ca emissions as well.
Old Jun 7, 2003 | 10:18 PM
Keeper's Avatar
I can't speak about what Mazda is doing with the RX-8, but I can tell you what the differences are with a different make and model.
On a Mitsu 3rd gen Eclipse, the difference between a cali spec and fed spec car was primarily the addition of two precats. These two catalitic converters are smaller than the main cat and sit much closer to the engine. Mitsu also changed the O2 sensor configuration -- from one set of sensors before & after the main cat to two sets of sensors before & after the precats. The ECUs are also different (to account for the extra O2 sensors; nobody really knows if mitsu did anything else to the ECU regarding engine performance). Additionally, there were other changes regarding the exhaust fittings and whatnot that have caused problems with aftermarket parts (cali spec cars are consistant; fed spec cars are not).
The additional precats add more restriction to the exhaust flow, which means that the engine doesn't breath as well, which reduces power. The fed spec engine in the 3g Eclipse GT is rated at 205hp at the crank. The cali spec engine is rated at 200hp.
This difference looks about right on a dyno between a stock fed spec and cali spec car. However, cali spec cars don't take to mods nearly as well as the fed spec cars -- even if the mod removes the precats (ex: headers) -- hence, people wondering if mitsu did something else to the ECU.
On a track, the difference is MUCH more pronounced. A good driver on a fed spec GT can pull high 14s with basic mods. Cali spec cars seem to have trouble getting down to 15.1 with the same basic mods (15.2 - 15.3 seems much more common). That's a pretty huge difference for only a 5hp loss... while I know that runs will vary depending on the driver, conditions, and altitude, there generally seems to be about a 0.3 difference in 1320 times between otherwise equal fed & cali spec cars (from my observations anyway).
So, get the fed spec car if you can.
gwilliams6
General Automotive
60
Nov 3, 2015 02:50 PM
br0wm
Oct 24, 2015 11:06 PM
Steve Dallas
RX-8 Racing
10
Oct 7, 2015 10:30 AM
r-enzyme
Oct 1, 2015 01:27 AM
