Greddy Turbo working on auto RX8
Old Feb 11, 2005 | 12:17 PM
apex8's Avatar
Hi Everybody,
Just wanted to let the automatic RX8 owners know that the Greddy kit fits on the car. The e-manage would not work however, so I used my other e-manage that I had been experimenting with. I used the harness that came with the kit. Jumpers 5 and 6 inside the emanage were turned off. I am using just the additional injector map to control the 4 injectors. My initial tuning has the air/fuel ratio in the 11 range. I would like to gradually lean it out to about 11.5. The only problem is that the injectors are running at about 95%+ duty cycle. This is too high, so I am going to replace the secondary injectors with 550 cc ones from RC Engineering.
For a blow off valve, I used one from a 1993 RX7. It is plumbed between the pipe near the throttle body and the air inlet pipe coming from the air filter.
I had done some 0 - 60 mph tests before the turbo install. I averaged 8.8 seconds. After the turbo install, I averaged 6.4 seconds. These times were done by pre-loading the torque convertor by standing on the brake and gas at the same time. I plan to dyno the car after the larger injectors are installed.
Later,
Rick
Old Feb 11, 2005 | 12:44 PM
PUR NRG's Avatar
FYI, apex8 is Rick from Rick's Rotary. They're the guys in Pleasanton who work on RX-7s, recommended by Bern and installed my ACT flywheel. Rick has lots of experience with eManage tuning in general. The turbo'd auto is his personal car so you can be sure he's doing a meticulous job. This is Rick's first post although he's been lurking for a while.
________
Coach purses
Old Feb 12, 2005 | 01:14 PM
Overport's Avatar
Overport
cool. it would have been nice to hear that from him though.
Old Feb 12, 2005 | 06:01 PM
09Factor's Avatar
Original Turbo 'd Auto !!
There is a light at the end of the tunnel. Thanks Rick.
Also could you take a pic of the BOV near the TB?
Old Feb 13, 2005 | 03:24 AM
JeRKy 8 Owner's Avatar
Stuck in a love triangle
Rick congratulations man - thatsgreat news for all of us auto owners. A 6.4 0-60 ispretty decent considering what our automatics run stock (mines around 8.1) - so atleast now you have some respectable straight line performance. I wonder how powerful it feels in the mid range. Also let us knowhow the tranny holds up
Clearly if/when I go this route itwill be w/SSRs kit.
Old Feb 14, 2005 | 07:38 AM
DreRX8's Avatar
Hmmm--very interesting, 6.4 consistent seconds to 60 is what the auto RX8 should have been doing in the first place--but this is the route I may go once my warranty is up. Keep us posted--and good work.
Old Feb 14, 2005 | 08:58 AM
Broke_Apex_Seal's Avatar
I new the auto would be fine. How does it shift? Any slippage at all?
Old Feb 14, 2005 | 03:50 PM
spr grn8's Avatar
It's Super Green...
Apex8, maybe you can give us a run down on any and all mods you have on your RX8. Alot of us would be interested what youv'e put together, like intake and exhaust to go with the turbo. Thanks!
Old Feb 14, 2005 | 04:16 PM
PUR NRG's Avatar
I don't know at what point it becomes "illegal" advertising, so I thought I'd put a plug in for him. Just from his post alone you wouldn't know he's a professional mechanic with years of experience working on rotaries--although the information content is a definite clue.
________
WEED VAPORIZERS
Old Feb 14, 2005 | 11:32 PM
Wait actuallyI have a question for whoever can answer this. How is it that Ricks automatic Rx8 improved over 2 seconds in its 0-60 time (went from an 8.8 to 6.4) w/the GReddy turbo kit while philodoxs manual Rx8 made a much less impressive improvement (went from 5.9 seconds to somewhere around 5.0 - 5.2 seconds)?
Why would the smaller engine make a larger gain than the bigger one w/the same exact kit?
Old Feb 14, 2005 | 11:44 PM
Captain Amazing's Avatar
Adding horsepower to a lower powered car will make more of adifference then adding horsepower to a higher power car. Example: adding 30hp to a 200hp engine will make a bigger difference in 1/4mile times compared to adding 30hp to a 500hp engine. Well, I think that is why there is a difference. I could be completely wrong. :o
Old Feb 15, 2005 | 08:07 AM
DreRX8's Avatar
Well--we would need to compare the powerbands of the two cars--but in essence I believe that the auto has more consistent performance than the manual--remember the 5.9s in the 6spd is hard to repeat consistantly. Also I think that some folks commented that due to the 4-port config they respond better to boosting--perhaps someone else can offer a more technical response.
Old Feb 15, 2005 | 10:19 AM
PUR NRG's Avatar
Two points to consider:
1. The stock auto has slightly more torque than the manual.
2. Diminishing returns means the next incremental increase takes more effort.
________
LAMBORGHINI V8 SPECIFICATIONS
Old Feb 15, 2005 | 04:18 PM
I guess itreally doesnt matter in a sense b/c even though he is technically making larger gains than the manual Rx8s are w/the same exact kit - its still not performing quite as fast as the stock manual Rx8. Wouldnt it be more beneficial to have a kit specifically designed for the automatics 4port configuration rather than using a hand me down from the manual or is that irrelevant?
Old Feb 15, 2005 | 05:15 PM
PUR NRG's Avatar
Which components would be different for an automatic vs. manual? Except for the larger fuel injectors kit components would be the same.
________
CHRYSLER SEBRING (COUPE)
Old Feb 15, 2005 | 10:45 PM
therm8's Avatar
Bummed, but bring on OU!
air flow wise the 4 port and 6 port engines are pretty similar up to about 7000 rpm i'd be willing to bet. When the tertiary ports open on the 6 port, that's where you'd see a difference. Therefore you should be able to get away with using the same setup.
I'd really like to see a stock dyno on a 4 port. I don't think they suffer as much from the factory tune as the 6 ports. The 6 ports are losing 20hp to that (based on a few peoples statments in other threads, don't want to get this thread hijacked with another hp discussion), I wonder if the 4 port loses anything at all. I doubt they had to cut back on power like on the 6 port for cat longevity (since they use the same cat). But what do I know :D .
Old Feb 16, 2005 | 08:17 PM
Being part of the minority on this forum sure does sucks (this thread is barely getting any attention).
Anyway Im pretty sure our automatics fall somewhere in the 130 - 150 whp range.
Still not sure if buying a turbo kit for our automatics is viable though b/c if Gordons rumor ends up being true and Mazda is upgrading the automatic Rx8s to the high power engine for the 2006 model year - then youll probably have stock 2006 automatic Rx8s doing 60 in low 6s that you can trade for + warranty + everythings brandnew.
Regardless I hope Rick manages to squeeze some more power out of GReddys kit. What hes already accomplished is amazing (a 2 second improvement for less than 5grand?) but itd really be great if he could get his automatic Rx8 to match the performance of the stock manual Rx8s w/this kit. Hes almost there anyway.
Old Feb 17, 2005 | 07:36 AM
DreRX8's Avatar
This is true--I probably would trade mine in on the hi-power RX8 if this is true as well--especially if the SMG comes to fruition.
Old Feb 17, 2005 | 07:56 AM
Phil's 8's Avatar
FI by Pettit-BHR-Cobb AP
JeRKy 8 Owner Being part of the minority on this forum sure does sucks (this thread is barely getting any attention).
I've been following this thread since the onset and am sure that there are many others. I don't want to sound as stupid as I am about what your doing so I try and stay in the shadows. All I know is I want to go faster. PLEASE KEEP THE COURSE. I will send a little encouragement from time to time
Old Feb 17, 2005 | 08:00 PM
z00m-z00m's Avatar
:P cant wait to get more power out of my AT RX8 :D
Old Feb 23, 2005 | 07:49 AM
DreRX8's Avatar
Any new developments on this end?
Old Feb 23, 2005 | 10:29 AM
CaptainZoom's Avatar
The European 192 hp version has got a 5-spd manual box.
Mazda claims 7,2 sec for 0-62 mph(0-100 km/h).The only test I've seen is 7,7.
The LP hits the rpm-restrictor in 2nd gear at 104 km/h.(64,6mph)
The 5-spd man is therefore obviously faster than the 197 hp 4AT..
The Euro 231 hp 6-spd got a claimed 6,4,but best I've seen is 6,9...
Old Feb 23, 2005 | 06:57 PM
Its been nearly 2 weeks since Rick (apex8) last posted anythingabout his turbo charged automatic Rx8. PUR NRG couldyou call him andask him to post an update for us?
Old Mar 1, 2005 | 09:41 PM
Three weeks andstill nothing. Must have fuckedup his car or something..
Old Mar 1, 2005 | 10:34 PM
arr ex eight's Avatar
lol true..where are you rick?
