Has anyone relocated their battery?
Old Jan 28, 2005 | 11:09 AM
Dark8's Avatar
Ride Naked!
If so, where did you run the wiring? Any post-installation problems? And any pitures? Parts list? I figure I might as well fill up the almost useless trunk...
Old Jan 28, 2005 | 11:19 AM
expo1's Avatar
He's as bad as Can
What would be gained by moving the battery on a car that has 50/50 weight distribution? Now if it was to make room for a 20B I would understand.
Old Jan 30, 2005 | 06:20 PM
Spin9k's Avatar
Momentum Keeps Me Going
I think it isn't really 50-50 more like 52-48, and it is also out over the front wheel line, so moving it back into the trunk ahead of the axle line would be the best. Sounds like a good idea, probably a PITA though, unless you strip the car for racing.
Old Jan 30, 2005 | 06:43 PM
Omicron's Avatar
I've been wondering about this for some time now. I figure relocating the battery to the trunk after I get FI will pretty much keep the weight distribution 50/50... plus, it would allow me to get a significantly bigger battery, and leave more room in the engine compartment.
Genom and I discussed this a while back for unrelated reasons, and it looks like it'd be pretty easy to run the cabling up conduit under the RH side door sill...
Old Jan 30, 2005 | 06:51 PM
Kewl's Avatar
Former RX8 Owner.
I weighted my 8 - full fuel, spare tire, but nothing else in the trunk. No driver or PAX in the vehicle. Using four independent scales at the same time showed the weight on each wheel to be within about 10 pounds of each other all the way around. About as perfect and 50/50 front to back side to side as you could ask for.
Seems to me moving the battery - away from the heat of the engine - would be worth any negatives created.
Old Jan 30, 2005 | 11:57 PM
Im_DANomite's Avatar
I love GOOOLD
there is no point. so what about heat??
Old Jan 31, 2005 | 01:29 AM
Mr. Ed's rx-8's Avatar
no more 8
i am also very interested in moving the battery to the trunk...is there no one that has done this?
Old Jan 31, 2005 | 03:50 PM
Jay Goldfarb's Avatar
Check with the guys at Pettit Racing. They moved the battery to the trunk on the two cars that are being tested with superchargers. Tyler can help you 561-844-2258
Jay Goldfarb
Old Jan 31, 2005 | 04:43 PM
Nubo's Avatar
Lubricious
Anyone who does this should take great pains to make sure the battery is absolutely held in place securely. Wouldn't want something with that much mass entering the passenger compartment in a crash. Same for the spare tire that some people insist on just laying in the trunk to avoid using the carrier.
Old Jan 31, 2005 | 05:24 PM
almost useless? what are you talking about? search for a post by me that talks about all the stuff i packed in there. search "sleeping bags" that should find it. but long story short- i packed everything in the trunk that my wife and i needed for a week long trip to cali and back in late 2003. the only thing we didnt put in the trunk was a cooler of drinks and snacks which i buckeled in the back seat.
Old Jan 31, 2005 | 05:28 PM
here i found it for you
Originally Posted by zoom44
well i posted this the other day but here is what i fit in my rx-8:
how about :
in the trunk-
1 2 person tent
1 bag of tent poles and pegs
2 sleeping bags
2 sleeping pads
2 carry on size suit cases
1 picnic basket full of variuos pots pans and untensils etc
1 small backpack
2 gallons of water
a couple or 4 extra pairs of shoes
plus 2 quarts of oil and the tire inflation kit which are always there in the trunk.
1 cooler on a back seat, safely buckled in. and on the return trip a nice case of napa valley wine buckled in the other seat. plus me and my wife plus a couple of jackets, hat etc. not bad for a sports car on a week long,2000 mile journey through northern cali :D
and yes they were normal size (and fit in the"test the size of your carry-on" thing) carry-ons that have small wheels on the bottom and a telescoping handle. i should go home and put all of that stuff back in and take a pic
Old Jan 31, 2005 | 05:30 PM
another good packing job
Originally Posted by RXhusker
The little things like making a run to Sam's Club to pick up some stuff for the office and getting:
1 - 15 roll bag of paper towels
2 - 5000 count boxes of copy paper
2 - 30 packs of 1/2 liter bottles of water
and
10 cases of soda cans!
All that plus myself and a passenger :D
Not bad for a sports car -- lets see you try to get that in a s2k, 350Z, etc., etc.
Old Feb 2, 2005 | 04:15 PM
superscout03's Avatar
not to mention the amount of the 0 gauge cable you would need, that alone would add about 20 more pounds to the car. More chance for a fire to break out too, alot of amps there.
Old Feb 2, 2005 | 05:03 PM
Mazdax605's Avatar
20 lbs.,come on,even if you ran 4ott cable it wouldn't add that kind of weight.All you need to run is one wire from the battery in the truck to the starter,or where ever it goes now,and the ground can be picked up somwhere in the truck area.I relocated the battery in my RX-7,and only used about 6 feet of cable from the battery in the storage bin to the starter,and about 1 foot from the negative post to the seatbelt bolt on the passenger side for the chassis ground.I doubt I added any weight that could really be measured,aside from maybe the Optima battery weighing a bit more than the stocker.Relocating batteries isn't really that big of a deal I don't think,heck even the Miata has the battery in the trunk.Like others have said,be smart about it,and make sure the battery is tied down good,and make sure it is a non-venting type battery like an Optima.
Old Feb 2, 2005 | 05:07 PM
... and yet more evidence of the usefulness of the trunk
https://www.rx8club.com/rx-8-multimedia-photo-gallery-6/all-stuff-i-fit-our-8-a-51749/
92trbolzr
May 18, 2025 09:04 AM
cliffkemp
Dec 24, 2024 10:48 AM
Evan Gray
Sep 26, 2015 12:30 PM
