You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join RX8Club.com today!
not to bad I guess, since I came from a 2003 mustang Gt making 400hp
but this car does get the girls to look !!!
(i had a pretty, young bank teller start flirting with me in the drive thru line---the mustang never got that !!! )
nice baseline.. post a pic of the dyno sheet.. it's the only way you can get street credit with this crowd
Originally Posted by dmp
what is a dynamic dyno?
Just another company that makes dyno's.. like mustang, dynametrics, dynojet, etc..
Greddy Turbo Kit 240rwhp @ 7psi!, Ti 6MT, GT, Borla Cat-Back Exhaust, SR Motorsports Lightweight Flywheel, Rotora Drilled/Slotted Rotors, EBC Red STuff Brake Pads, RB F/R sway bars, RB plug wires, Tein Springs, Ganador Racing Mirrors, Richard Paul Short Throw Shifter, MS F/R strut bars, MS Front Bumper, MS Side Skirts, MS Spoiler, Lineage Ground Wires, Royal Purle Oils, Red Line Trans/Diff Fluid, Axis Hiro 19x8.5/19x9.5(Summer wheels), Kyokugen Lugs, My Website!
Philo - I didn't see if you answerd - sorry to topic jump;
Were the dyno numbers from your recent dyno 'correct'? If so, do you know what the correction factor was?
you should always use uncorrected results for a forced induction system. the reason being is with FI you create your own atmospheric conditions from pressurizing the air. make sense?
However, humidity, heat, etc, can change things - I think corrected values are still valid, having said that, I always use uncorrected results anyway...to me its more important what my car actually measures at, not what it'd measure in a 'perfect world'.
:D
True, but the thing is, the ambient air temp is not intake temp through the turbo and intercooler nor is the barometric pressure correct since the air is pressurized in the intake system. So the correction value the dyno program comes up with is going to be way off base compared to actual conditions inside the car which you can't really measure without a butt load of special equipment.
For a N/A car, corrected values are useful.. but for forced induction, they are very sketchy.
Not bad at all - a high end claim - let's see the sheet man
Original RX8 247HP at the crank (Assume 20% loss = 197 RWHP)
Detunned US RX8 238HP at the crank (Assume 20% loss = 190 RWHP)
RX8Club Member RX8's make 210-220 HP at the crank (Assumine 20% loss = 168-176 RWHP)
Sorry your wrong Jon, corrected numbers are important no mater what. Blown engines are not exempt. We use these corrections so we can compare engines run in differnt conditions. If I run a test in Santa Monica and you run yours in Denver who has more power. I'd beat you hans down every time. You have to get a correction for altitude and temp and water vapor.
We all correct to the same standard. Now standards are different. We have SAE and Standard. All after market people use Std all Oem's use SAE.
The SAE uses ........................I don't remember. but I think it's 29.38 Hg and 70f.
Std is 29.92 and 60f. you can see the diff.
The factors seem to be accepted through out the industry. Except by some men in the RX 8 club.com. Well like I said "Just because it is written does not mean it is carved in stone"
Who knows there might be another Ricardo in our ranks.
Tis why I don't compare my car with any car but those run during my dyno sessions...Thus, I only read 'measured'.
I agree with that in terms of belt driven superchargers but not when it comes to exhaust driven turbos. Remember that a turbo will compensate to a point for altitude since it makes boost pressure as a reference to sea level pressure. Since a belt driven supercharger makes boost relative to ambient and not sea level, a correction is needed. Technically there should be some form of correction for an exhaust turbocharged engine too but the standard correction factors are more wrong than they are right. You and Jon are both right. It just depends on what type of supercharging you are using.
Please help me understand something. Mazda states 238hp. We see rx-8 club members all the time with 210-220 at the crank. Then we "assume" a 20% loss. Why dose this car only put 170-180 to the rear wheels? Don't get me wrong I love my car but crap we jump all over products that claim 5-15hp increases and spend $300.00-$1200.00 for them and we are down 58hp from the claimed crank hp to actual wheel hp. What is the reason for that big of a loss?!?!?!?!
'04 titanium grey 6speed blk/red int. GT
clear corners..rims and more to come
Please help me understand something. Mazda states 238hp. We see rx-8 club members all the time with 210-220 at the crank. Then we "assume" a 20% loss. Why does this car only put 170-180 to the rear wheels? Don't get me wrong I love my car but crap we jump all over products that claim 5-15hp increases and spend $300.00-$1200.00 for them and we are down 58hp from the claimed crank hp to actual wheel hp. What is the reason for that big of a loss?!?!?!?!
Just a correction - I have yet to see ONE rx8club member dyno his engine at the crank. Automakers NEVER rate their cars at 'wheel HP'. We are likely down 10-20HP from what mazda rates...based on our WHEEL HP and guessing what acceptable drive-train losses should be.
