Tein S-tech = Wheel Hop Solution?
Old Jan 25, 2005 | 12:34 PM
Xyntax's Avatar
THREAD KILLER
Hi, I just ordered a Tein S-tech set and I was wondering if any of you who has it got rid of the massive wheel hops this car is so capable of? I don't mind the wheel hops at launch because I won't be doing that all the time. What I'm annoyed about is the wheel hop when I shift. I'm running with modified CZ Stage 2 map and so it packs a lot of punch when it's on. If I turn it off, I would have no problem with wheelhops during shifts, just chirps (which I dont mind either).
Whenever I rip to 9K and shift to 2nd I would get bad wheelhops for a full second and when it starts to accelerate real fast again. I was running 32psi on my rear tires that time. So I decided to lower it to 28psi and I still get the wheelhops, but a little less annoying.
Shift to 3rd does it a bit but very subtle.
Old Jan 25, 2005 | 12:38 PM
trophymaker's Avatar
From what I understand the rear strut tower brace is a better solution to this problem.
Old Jan 25, 2005 | 12:58 PM
Xyntax's Avatar
THREAD KILLER
oh really? That's the first time I've read that. I might as well get that since I will be taking that portion apart during installation anyway.
Old Jan 25, 2005 | 01:05 PM
IZoomZoomI's Avatar
Boost needed
yea and sway bars can help. The springs won't get rid of the wheel hop totally, when I launch I still get a little bit but it does seem better.
Old Jan 25, 2005 | 01:06 PM
army_rx8's Avatar
X-Sapper
eveything i've read says if you upgrade the rear-sway bar it'll solve a lot of wheel hop issues (example racingbeats rearsawy is liek 155 adn it's one of the thickest and strongest.)
Old Jan 25, 2005 | 02:47 PM
Xyntax's Avatar
THREAD KILLER
Yeah ok. I was gonna get RB rear sway bars in the future anyway. I always thought sway bars affect the left-right tension and not front-back; springs can do that.
Old Jan 26, 2005 | 12:04 AM
Omicron's Avatar
My wheel hop went away when I replaced my stock springs with Tein H-Techs.
Old Jan 26, 2005 | 01:10 AM
Xyntax's Avatar
THREAD KILLER
^ Yeah I read about your posts. Very informative Omicron, thanks for that! It helped me decide on getting those Teins.
Old Jan 26, 2005 | 02:23 AM
StealthTL's Avatar
Where?
I can't find H-Tech springs anywhere, who's your hookup, 'O'Guy?
S
Old Jan 26, 2005 | 09:38 AM
slavearm's Avatar
Boost Junkie
I still get a little wheel hop even with the racing beat springs and sways. I think I need a rear strut tower brace or tie bar.
Old Jan 26, 2005 | 10:13 AM
Genom's Avatar
Not so Super right now
Replacing my rear sway bar did nothing for wheel hop. I am hoping the enw springs do.
Old Jan 26, 2005 | 10:14 AM
Xyntax's Avatar
THREAD KILLER
^ They say that RB springs has the least change in spring rate and drop from stock compared to other springs out there. That might be why it didn't affect your wheel hops so much. I'm still having a hard time understanding how a rear strut bar could be the solution.
Old Jan 26, 2005 | 01:23 PM
Omicron's Avatar
Well, note that I got the H-Techs, not the S-Techs which are stiffer... so that might have some effect.
I got them off eBay for like $130 from optionimports.com.
theblinkof
Oct 4, 2023 05:24 PM
hufflepuff
May 30, 2016 10:45 AM
duworm
Oct 1, 2015 04:57 PM
GranTouTou
Sep 30, 2015 06:11 AM
Evan Gray
Sep 26, 2015 12:30 PM
