Cheap shifter improvement: $35
Old Jan 1, 2005 | 03:37 PM
PUR NRG's Avatar
Got it from Mazda Motorsports, but it's a third party part so someone else actually makes it. Don't know who unfortunately. It's an aluminum shift bushing that replaces the stock plastic one. According to them the plastic "can wear quickly under racing conditions. A worn shifter bushing causes increased wear to synchro rings which can result in serious damage to other trans components."
Net result: after using Redline tranny fluid my shift felt noticably smoother than stock. After installing the bushing I felt the same increase in shift smoothness. For the price it's a worthwhile mod.
I don't plan to install a short(er) shifter. I think the stock throw is fine and under track conditions I can shift faster than the synchros will allow. So between this and the Redline I'm happy.
________
CLITORIS
Old Jan 1, 2005 | 09:30 PM
Gomez's Avatar
Shifty Bastard.
Rightio man, we need a pic. I've been looking at something like this for a while. I knew they were available for the RX-7, but this is the first I've heard of one for the 8. Aluminium, you say????!!
Old Jan 1, 2005 | 09:34 PM
Gomez's Avatar
Shifty Bastard.
Hang on....are we talking about the bushing that fits onto the bottom of the shifter, onto the ball? Like this RX-7 one.....
Attached Thumbnails Cheap shifter improvement: -sft_cl_1.jpg
Old Jan 1, 2005 | 09:37 PM
speedweasel's Avatar
Rotary Powered Vermin
Where did you buy?
Old Jan 1, 2005 | 10:26 PM
PUR NRG's Avatar
Yep, that's the part. As for where I bought it, that was the first thing I mentioned.
________
butt Cam
Old Jan 1, 2005 | 10:31 PM
Gomez's Avatar
Shifty Bastard.
...and it's aluminium??? Seems like too soft a metal to be putting in a high wear area...?
Old Jan 1, 2005 | 10:32 PM
adrian-1's Avatar
Ex- member.
I was wondering about those. The website is mazdamotorsports.com , BUT you have to be a registered racer to be able to order from them.
I believe they are around $35. Thanks for the info, I may order one.
Old Jan 1, 2005 | 10:36 PM
adrian-1's Avatar
Ex- member.
It's more durable than the stock white plastic piece.
Picture below is the MS short shifter but you can see the plastic piece we're talking about replacing.
Attached Thumbnails Cheap shifter improvement: -015-037-japanparts-400.jpg
Old Jan 1, 2005 | 10:43 PM
Gomez's Avatar
Shifty Bastard.
Yeah, good point, I suppose I just had the bronze ones in mind......
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
theblinkof
Oct 4, 2023 05:24 PM
200.mph
Dec 10, 2018 03:49 PM
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
