Components of the OEM radio???
Old Dec 30, 2004 | 01:44 PM
mospeed's Avatar
I'm a bit confused of the components of the factory/OEM radio. Does the radio actually consist of a CD player, on top of a radio (tuner), and if installed a cassette/minidisc? Or is the CD player integrated with the radio (tuner)? I searched for pics of the radio, but still a bit confused how it is assembled. One more question.... what "section" of the radio needs to be reflashed if indeed the CD is not part of the radio???? The radio needs to be upgraded to the new firmware correct?
Thanks, sorry if this is a simple question......
Ed
Old Dec 30, 2004 | 01:50 PM
r0tor's Avatar
the stereo is a modular design - so it actually has a cd drive that can be swapped out with say a mp3 cd player or a 6 disc cd changer. The tape / mini disc slot is the same deal - just another modular drive.
Old Dec 30, 2004 | 11:17 PM
rx8cited's Avatar
Originally Posted by mospeed
.....One more question.... what "section" of the radio needs to be reflashed if indeed the CD is not part of the radio???? The radio needs to be upgraded to the new firmware correct? ......
No reflashing required when adding/changing components.
Old Dec 30, 2004 | 11:35 PM
mospeed's Avatar
yeah, but the radio needs to be reflashed for the PIE.. correct?
Old Dec 31, 2004 | 01:39 AM
truemagellen's Avatar
Attracts tree branches
correct if you have a HU firmware less then 9.55...9.55 and higher you are good to go
mine was reflashed from 9.53 to 9.67 by thew of rx8garage, and now PIE works great
as for components of the HU
the part that needs to be reflashed is called the core...all you need is the core, not the CD unit, not the tape/md unit, not even the faceplate
to be safe you won't take the hu core out of the frame...this way it maintains a stainless steel structure around the core to protect it during shipping
Old Dec 31, 2004 | 09:15 AM
mospeed's Avatar
thanks.... exactly what I needed to know!
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
RX8mzda
Oct 1, 2015 10:17 PM
Quiggs321
Sep 30, 2015 05:34 PM
Learners_Permit
Sep 27, 2015 07:38 PM
