Car off, no clutch, first gear...
Old Dec 15, 2004 | 08:15 PM
Pkskull77's Avatar
If you put a car that’s turned off in first without using the clutch, will you damage your Gears/Transmission? Not that I would ever do this on purpose but every once-and -awhile I make the mistake.
Old Dec 15, 2004 | 08:36 PM
mysql101's Avatar
heh. I don't think it will damage much since you're at low rpm, your car will likely choke up and die. What you have to worry about is the car jumping forward and you hitting a wall or another car.
Old Dec 15, 2004 | 08:46 PM
bigblockbeater's Avatar
black RX-8 6 speed
if the car is off then the gears are not spinning. no harm no worries, i wouldn't try it with the engine running though. unless you know how. i had a pickup once and the throwout bearing went out so i had to drive the it without a clutch i got pretty good at shifting without the pedal! it wasn't too friendly on the starter however because in order to get the truck to move i had to turn off the engine, place it into 1st and the start it again. needless to say i had to rebuild the starter soon after lol.
delicious_dallan
Jan 17, 2020 09:17 AM
Dokuji
Nov 1, 2016 02:51 PM
BigMikeATL
May 26, 2016 12:31 AM
akagc
Aug 11, 2015 07:07 PM
thewatcher101
Aug 4, 2015 10:42 AM
