Does anyone know....
Old Dec 12, 2004 | 03:58 PM
Gambit's Avatar
Screw gas mileage
My girlfriend has a 2000 celica and she was having trouble starting it today. The starter turns like it's supposed to but the engine didn't catch and start. I don't think i'ts the battery because the starter was turning. Its an automatic and it's kinda cold outside...like high 30's Farenhiet
Old Dec 12, 2004 | 05:21 PM
truemagellen's Avatar
Attracts tree branches
no gas?
Old Dec 12, 2004 | 05:56 PM
shelleys_man_06's Avatar
Not anymore
It's the battery. Thing happened to me when I was trying to start my Celica when I owned it. All it needs is a jump-start and it'll be fine.
Old Dec 12, 2004 | 06:18 PM
MrH's Avatar
MrH
Obviously not. It cranks over.
Old Dec 12, 2004 | 06:56 PM
Butch Brown's Avatar
If it turns over real fast it may be a broken timing belt
Old Dec 13, 2004 | 07:55 AM
Gambit's Avatar
Screw gas mileage
I found this, in case anyone else has a similar problem
Checking your battery
Batteries are probably the biggest single cause for non starting, especially in colder weather. Batteries are less efficient the colder they get so the start of cold weather usually shows up any inefficiencies with the battery. Some of the time the problem seems to point to other things, i.e. the engine still turns over but doesn't fire up. Sometimes this can be due to the engine management system which only turns on the power to the coils if there is enough ampage left in the battery. If the power is too low then the ignition system is not powered up which leaves any power left in the battery to turning over the engine. Without the drain of having to power an ignition the engine turns over quite quickly and you could be forgiven for thinking that the fault lies elsewhere. Check you battery first. It's the most likely cause of non-starting faults and it is free and easy to check.
team420
Sep 18, 2013 09:29 AM
deanrx8
Jun 20, 2013 06:33 AM
Paco664
Apr 30, 2013 07:54 PM
Gyro_Bot
Canada Forum
21
Feb 3, 2013 07:30 PM
cmonk518
Nov 28, 2012 10:19 AM
