Mazda can't fix the noise under the hood
Old Dec 10, 2004 | 07:40 AM
slllygrl10's Avatar
EX-Member
Angry Mazda can't fix the noise under the hood
I dropped my 8 last monday night they changed the A/C and pulleys that didnt work. They changed the Air compressor pulley's and belt that didnt work. So the whole time my car was in the shop for 3 days they couldnt figure it out. I dont know if anyone is having similar problems. I hear this chirping noise it sounds like the belt or something you can hear it rotating. I might have to dropped it off again next week. What should I do?
Old Dec 10, 2004 | 01:41 PM
first thing i always look at with a chirp in the engine bay is water pump. did they look at that before doing the other stuff?
Old Dec 10, 2004 | 01:54 PM
slllygrl10's Avatar
EX-Member
Hmm when I turned on my car I could hear water... But it sounds like its a belt I have asked my friends with rx8 to listen to the noise they say it has to be a belt.
Old Dec 10, 2004 | 02:47 PM
but if they changed the belt and it still makes the noise...... the water you are hearing is gurgling thru the heater, thats air trapped in there. not a big deal but there are ways to get rid of it.
Old Dec 10, 2004 | 03:59 PM
Nubo's Avatar
Lubricious
Belt dressing can quiet a noisy belt, at least temporarily enough to identify it as the source.
Old Dec 10, 2004 | 04:59 PM
bigblockbeater's Avatar
black RX-8 6 speed
take it to a rotory pro. that's my advice for everything lol. these guys at the dealer don't know how to work on wankles. if they didn't have the manual they would think it was a 4banger
Old Dec 10, 2004 | 05:02 PM
Mr M's Avatar
Evolution of REvolution
If it chirps for an instant when you rev the engine it is normal. That is the normal combustion noise of the rotary. Sometimes it becomes more pronounced after a PCM reflash, or the battery has been disconnected.
When does it chirp?
Old Dec 10, 2004 | 05:09 PM
beachdog's Avatar
Likewise, when does it chirp?
Has anyone had their head under the hood while it makes the noise? The a/c compressor clutch makes noise when it engages and disengages. Of course that noise will be somewhat random.
Old Dec 11, 2004 | 07:11 AM
slllygrl10's Avatar
EX-Member
When does it chirp?
When its in Idle but I sometimes hear it while Im driving.
Old Dec 11, 2004 | 07:41 AM
Gyro's Avatar
Rotary Abuser
When does it chirp?
Sounds to me like a momentary lean out condition. Normal, if only heard at startup and when you blip the throttle.
Old Dec 11, 2004 | 11:34 AM
Mr M's Avatar
It is not leaning out, it is the sound of combustion (rotary engine combustion is much more violent than a reciprocal). I have never had an engineer explain exactly what they mean by violent, but the fact that you have two flame fronts (from the trailing and leading part of the combustion chamber) must contribute to it.
sillygrl, sorry, I'm lost. 'Fraid it is in the hands of the gods (or technicians).
Old Dec 11, 2004 | 04:35 PM
Tony Orlando's Avatar
Bored thread resuscitator
It's called a "Jet Air valve", and according to Mazda's tech line, it's louder in some cars then others, but a normal operating noise. Don't ask me what it does.... I have the noise, too, and my dealer tech (A long-time Rotary tech who REALLY knows his trade) got the info from Mazda.
Old Dec 11, 2004 | 04:51 PM
snap-on's Avatar
Is this ths noise?
Not you Abbid..Yours is a tranny issue.
WHINE OR SQUEAL NOISE FROM ENGINE AT IDLE
Applicable Models
Model Starting S/N Ending S/N
2004 RX8 00000000 ZZZZZZZZ
Some customers may complain of a high-pitched whine or squeal noise fromthe engine at an idle. The noise can be eliminated by raising the engineRPM slightly above idle. This is most likely caused by the primary port jet air nozzles and / or the metering oil pump air ports. The jet air nozzles are located in the primary port of each rotor. The jet air flow is acheived by using air flow from an area prior to the throttle plate. The metering oil injection nozzles also use this airflow prior to the throttle plate to assist oil flow into the engine. This creates a metered vacuum leak into the engine and may cause a high pitched whine at idle. This noise is considered to be a normal characteristic of the RENESIS rotary engine. Use the procedure outlined in the repair instructions to confirm noise is from the jet air or metering oil pump nozzles. 1.Confirm noise. 2.Remove engine cover. 3.Locate both air supply hoses for jet air nozzles and metering oil pump nozzles. Hoses are attached to the air duct located between the MAF and throttle body. Disregard hose that attaches to the oil filler tube4.Confirm noise is caused by jet air or metering oil pump nozzles by temporarily pinching off air supply hoses using pliers. 5.No repairs should be attempted if noise is reduced or eliminated.
Old Dec 11, 2004 | 04:57 PM
snap-on's Avatar
I was trying to separate the engine noise from "other".
The noise in the MRI I posted can be slightly louder in some cars than others.
I had a forum member in a while back and we noticed it on two or three cars.
Old Dec 11, 2004 | 05:16 PM
slllygrl10's Avatar
EX-Member
This is fixable right??
Old Dec 15, 2004 | 12:42 PM
slllygrl10's Avatar
EX-Member
Ok I just got my car yesterday. Mazda called the tech line and said that its normally becuz some cars it can be louder some cars it can be faint. They told me to keep getting it to high rpm's and maybe it will go away. My friend's 8 had this problem but it just went away. So we will see.
Old Feb 4, 2005 | 07:47 PM
bxb40's Avatar
Rotary Newbie
I have such a noise when it is colder outside. It seems to come from the AIR pump (it has a fan of some kind) and it varries with the RPM. The AIR pump is a black assembly located on the top of the engine, passenger side. Maybe you guys can listen to it when someone revs the engine... Mine sounds like a turbine and is louder than the engine itself.
Old Feb 6, 2005 | 12:07 AM
max5roadster's Avatar
INDY RX8 CLUB - Officer
I don't want to high-jack a thread, but today I too noticed a very odd and loud noise at full throttle or dipping into the throttle (In any gear) that resembles a chirp/screech/ultra high-pithced rattle which occurs from 5500-6200 RPM and sometimes occurs even closer to 8000+. I have noticed this since around 250 miles, but today (800+ miles) was the first day I could have the windows down and it was LOUD-echoing off buildings. If it were not so high pitched, I'd think it was an exhaust buzz. Is this a proper description of the sound you are all refering to? I have never had any CELs or anything yet, just this odd sound. Any thoughts?
Old Feb 6, 2005 | 07:19 AM
slllygrl10's Avatar
EX-Member
Mazda replaced my spark plugs cuz my car flooded last January but since they replaced the spark plugs the noise has gone away.
Old Feb 23, 2005 | 06:18 PM
Snake8's Avatar
I am not sure exactly what noice you are referring to? Mine makes a noticable chirp sound when I accelerate after I shift gear at low RPM. It revs up with engine speed, and goes away at mid-high RPM. Is it normal? Is it same kind of noice you hear. sillygirl?
Old Feb 25, 2005 | 06:40 PM
slllygrl10's Avatar
EX-Member
Yes, the noise would go away at mid-high rpms.
Old Jul 9, 2005 | 10:31 AM
1.Confirm noise.
Old Jul 9, 2005 | 10:37 AM
or this one one of the 2
A chirp or squeak may be heard at times from the engine compartment.
This can occur at engine start, or during engine acceleration. The
noise can easily be mistaken for a squeaky accessory drive belt. The
noise is actually caused by a slight momentary lean mixture, which
results in engine detonation.(Pinging) The RENESIS rotary engine runs
much leaner than previous rotary engines, resulting in improved fuel
economy N lower exhaust emissions. This momentary lean condition will
not cause engine damage.
IMPORTANT!
It is important to note that customers who use low octane fuel will
experience a noticeable increase in engine noise. The RX8 requires
premium fuel for best performance N engine life.
Old Jul 9, 2005 | 08:13 PM
ummm... I now have a whine not a chirp. Swear its the bearing. Sounds just like it.
But for some reason I think it's a little behind the water pump. i really haven't checked it out yet.
Old Jul 9, 2005 | 08:38 PM
NO noise
Damn, it's been there for quite some time.
Now I go out and check, and nothing. Only the sucking noise from the intake.
