DIY: Under the Dash “Holster” Mount
Old Dec 2, 2004 | 05:23 PM
cjrx8's Avatar
Post DIY: Under the Dash “Holster” Mount
I hope this doesn’t offend anyone, this is just informational.
I did this for myself because I have my CHL (Concealed Handgun License) and always have it with me. I used to have a Mazda 3 with the big center console cubby, very convenient. Well that is not the case in the RX8 so I came up with this convenient MOD.
Note that this mod could be done for all sorts of cases too, such as a PDA or Cell phone case, etc.
(Read all before attempting)
Old Dec 2, 2004 | 05:27 PM
cjrx8's Avatar
First I used a Fobus Roto Holster I got from www.productwizard.com it was about $23.00 plus shipping.
Old Dec 2, 2004 | 05:28 PM
cjrx8's Avatar
Next I unscrewed the screw in the back to disassemble the holster.
You will only need the holster part and screw. The paddle can be kept somewhere if you ever want reassemble later.
cjrx8's Avatar
Now get a drill and drill bit for the size of the screw. I used a 7/32” bit (just right!) Don’t use to big of a bit or MOD may come loose later.
Old Dec 2, 2004 | 05:29 PM
cjrx8's Avatar
Now go position the holster under the steering column in the middle some where convenient to get and idea of where to mount.
Old Dec 2, 2004 | 05:30 PM
cjrx8's Avatar
Next pop the panel off under the steering column. (Top first, then bottom.) Again, position the holster on the panel where it was convenient in the middle some where to get and idea of where to drill your mounting hole. Then drill hole through panel. Mine ended up being directly between some lettering on the back of the panel. Notice if you ever remove the MOD you would not see this small hole.
Old Dec 2, 2004 | 05:31 PM
cjrx8's Avatar
Next you will need the screw. Mine had a tapered head so I had to recess the hole from the back.
Next put the screw through the hole from the back.
Old Dec 2, 2004 | 05:32 PM
cjrx8's Avatar
Then put the back of the holster to the screw and use a screwdriver (powered or non-powered) to screw in the screw snugly.
Old Dec 2, 2004 | 05:33 PM
cjrx8's Avatar
Then put the panel back on and you’re done!
Old Dec 2, 2004 | 05:34 PM
cjrx8's Avatar
You can’t notice this unless you are looking for it, especially if you have tint.
Old Dec 2, 2004 | 05:35 PM
cjrx8's Avatar
Now you see it:
cjrx8's Avatar
Now you don’t!
Old Dec 2, 2004 | 05:36 PM
cjrx8's Avatar
Hope this helps solves someone else’s issues.
Old Dec 2, 2004 | 05:42 PM
mysql101's Avatar
heh. Now I just need a spot for my shotgun..
Old Dec 2, 2004 | 06:50 PM
Ninja's Avatar
Yeah! Zoom Zoom Zoomin!
But how do I mount my stealth rocket launcher? Errr as soon as I get that permit of course!
Old Dec 2, 2004 | 06:55 PM
im calling the cops
Old Dec 2, 2004 | 07:11 PM
RX3+5's Avatar
Bullshit Detector
Nice work!
Vince
Old Dec 2, 2004 | 07:13 PM
Omicron's Avatar
Very nice little DIY, cjrx8!
The only thing I might caution people about is that a CHL (aka a "CCW permit" in other areas) is usually for carrying on your person, and different laws apply to your vehicle. For instance, in AZ and CO, the weapon has to be more than 2 motions away for access... such as 1 motion to open glove box, 1 motion to remove the weapon is not enough. If you had it holstered in the glove box, removing it from the holster would constitute a 3rd motion and you'd be ok.
At any rate, check your local laws before considering this.
jenkins-crew's Avatar
Great DIY..Thanks!!!
Old Dec 2, 2004 | 09:07 PM
Zaku-8's Avatar
maybe installing a snap cover would add an extra motion
Old Dec 2, 2004 | 09:30 PM
Nemesis8's Avatar
Bigus Rotus
You'll shoot your eye out
Old Dec 2, 2004 | 09:47 PM
Omicron's Avatar
Nope, this mod would make it a 1-motion draw. Adding a thumb break holster would still be 1-motion. Adding a snapover holster would make it 2-motion. Nice try though! :D
Old Dec 2, 2004 | 09:51 PM
Butthead's Avatar
Nice mod homey. 'Bout damn time somebody had the ***** to post something like this!
Old Dec 2, 2004 | 09:59 PM
Zoomie's Avatar
Purchase a decent IWB holster and take it with you all the time. Luby's Cafeteria, Killeen, TX, 1995, 23 dead - a gun left in someone's car could have saved many lives. Yeah, they're big. Yeah, they're bulky... Cold, wet, tired? Tell it to the mortician. Sorry for the exteme point of view; but if you're going to have a CHL, use it. Don't leave you're gun in the car under the dash. Also, training, training, training. OK, enough off-topic (which I believe was RX-8).
Old Dec 2, 2004 | 10:25 PM
cjrx8's Avatar
I never said I left it in the car. I just wanted a place to put it while driving in the car. It is usually behind my back, so more comfortable/convienent there......just for clearation.
