Intake Mod
Old Nov 17, 2004 | 10:37 AM
xxdevilzeroxx's Avatar
Revin 9500k
Intake Mod
intake mod,
1- 3" or 3 1/2" coupler
2- 3" inlet GREDDY style filter (or the real thing more $$$)
its a pretty simple mod. pull off the stock box, take off the deviders in the stock box with a screw driver, unscrew the tube which connects to the box (the one inside) take off the flared tip, which is screwed on, bolt the tube back on, then insert the coupler on the tube, then the filter right after, all you need from the coupler is the rubber part, you cant screw the clamps because of space issues. the rubber is good enough to seal the air, if you dont want to use the HKS style or the Greddy style which are mushroom style, use something else that fits, i used the Greddy because it was the only one that fits. you can get them at any shop or get the knock off ones at kragen (pretty much the same, just cheaper since your not paying for the name GREDDY) ill some pix soon
SHROOM
NEW VERSION
COUPLERS
Old Nov 17, 2004 | 10:48 AM
RXE16T's Avatar
'RX-EIGHT'
Cool mod.
A bit late for me though..... HKS intake kit already on its way.
Old Nov 17, 2004 | 03:57 PM
Ninja's Avatar
Yeah! Zoom Zoom Zoomin!
Benefits?
Old Nov 17, 2004 | 09:44 PM
wakeech's Avatar
mostly harmless
Originally Posted by Ninja
Benefits?
none, other than you get to say "i have a Greddy foam filter on my intake that resembles the colour of my car!!" or whatever.
Old Nov 18, 2004 | 11:14 AM
Revin 9500k
MPG??? why dont someone try testing, i know the car sounds much better with it on =) cheapest way of getting that sound, not as good as an open box filter, but itll do the job........
Hunterkelley24
Jun 14, 2022 08:32 AM
Sato Tatsuya
Oct 5, 2015 03:09 PM
Zube6115
Sep 30, 2015 12:57 PM
FubarI33t
Sep 28, 2015 08:45 PM
