Removing the Stock Intake
Old Nov 16, 2004 | 08:01 PM
liqiud's Avatar
I know...you are saying to your self...do a search... I have searched...and can't find anyone that has documented how to do this...is it that easy...? If anyone can point me in the right direction, that would be great, since I need to pull it out tomorrow at lunch time. Thanks.
Old Nov 16, 2004 | 08:06 PM
RXE16T's Avatar
'RX-EIGHT'
To remove the entire airbox:
1.Remove engine cover
2.Remove battery cover
3.Undo hose clamp on accordian pipe
4.Hold both front corners of airbox and push towards rear of engine bay.
5.Clips should pop out of holders in radiator support.
6.Push and lift up.
7.Disconnect all ancillary attachment
I think that's all..... trying to work off my memory.
Hope that helps.
Old Nov 16, 2004 | 09:19 PM
liqiud's Avatar
thank you very much...it's like i thought...pretty easy to do...
rotorocks
47
May 11, 2016 03:23 PM
FoxRacer600RR
Aug 31, 2015 06:32 AM
RXeckless
Aug 16, 2015 12:51 PM
TheWhiteAce
Aug 6, 2015 02:26 PM
