Oil Pressure Guage high?
Old Nov 12, 2004 | 10:36 PM
ssjelite23's Avatar
Maybe next lifetime...
Question Oil Pressure Guage high?
I noticed on my 8 today that the reading on the oil pressure guage is about two hash marks above the center hash. From reading the owner's manual, it states it should be right at or a little below the center hash.
The 8 runs fine. I even recently took it in to the dealership for oil change.
Should I be worried about the oil pressure or is this something other 8 owners have experienced?
Old Nov 12, 2004 | 10:40 PM
RXE16T's Avatar
'RX-EIGHT'
I hate to tell you this, but that gauge doesn't actually work.
It is connected to a sensor in the sump that gives it either a on or off signal, not an actual reading.
Old Nov 12, 2004 | 11:57 PM
ssjelite23's Avatar
Ah, interesting. Thanks. :o
Old Nov 13, 2004 | 01:20 AM
takahashi's Avatar
NJ is true... it is a 1/0 thing. So there is only on/off. The absolute value is not important, as long as it is above a certain oil pressure, it will be positive.
Old Nov 13, 2004 | 04:32 PM
RX PRN's Avatar
If the sensor were changed, would the gauge give you a actual reading? or would you have to rep;ace the gauge as well?
Old Nov 13, 2004 | 05:15 PM
RXE16T's Avatar
'RX-EIGHT'
I'm not certain, but IMO, I believe you should be able to wire it up somehow.
Anyone try this?
Old Nov 13, 2004 | 06:10 PM
RX PRN's Avatar
To add to this, my 2001 Dodge Durango has a gauge that reflects actual oil pressure (one of the few things taht Dodge did right). It would be nice if there was an easy MOD that gave the RX8 the same function in that it lacks a oil level gauge.
mr. GrandGame
Sep 9, 2025 10:41 PM
9krpmrx8
Nov 5, 2015 11:45 PM
HMSS013
Aug 28, 2015 03:08 PM
talonhart2
Aug 26, 2015 04:14 PM
foxyRoXy8
Aug 18, 2015 10:26 PM
