DIY: Code your own key / remote
Old Nov 3, 2004 | 01:38 PM
Mazda Monkey's Avatar
This information can be used to add a new key and / or remote (including 2005 retractable key / remote to 2004 cars) to your vehicle.
Two things to keep in mind-
Key programming-
You MUST have at least two existing keys in order to add another new key. This will not work if you only have one good key, & want to add a new key. If you only have one good key(or have lost all keys) you will need to go to the dealer.
Remote programming-
IMPORTANT- When the instructions indicate you must press the door switch 3 times, they mean the door ajar switch located on the rear door, just below the front door catch.
Enjoy!
GIF Images work, just click on DIY: Code you own key links below
Attached Thumbnails DIY: Code your own key / remote-key1.gif   DIY: Code your own key / remote-key-2.gif   DIY: Code your own key / remote-key-3.gif   DIY: Code your own key / remote-key4.gif
Old Nov 3, 2004 | 02:57 PM
romulus's Avatar
great post, but I was just able to read the key programing. The last attachment only shows procedure 1 and 2 and no where says to press the door switch 3 times (procedure 5?). Could you point out in your attachment how to program the remote?
Old Nov 3, 2004 | 04:16 PM
Oops. Try # 4
Old Nov 3, 2004 | 04:38 PM
romulus's Avatar
Ohh much better.. I first, I thought that I needed new glasses hahaha By the way, I am ok with my old keys but at least I got the option in upgrading later on
Old Nov 3, 2004 | 04:42 PM
Lock & Load's Avatar
Great info thanks .
cheers
michael
Old Nov 10, 2004 | 06:02 PM
takahashi's Avatar
eh..... https://www.rx8club.com/series-i-do-yourself-forum-73/diy-code-your-new-key-yourself-15244/
1/2 of a repost ? :D
Old Dec 6, 2004 | 06:38 PM
HighRev'n's Avatar
Thanks Mazda Monkey (and takahashi). Got the '05 Key/Remote this weekend. Programming went smoothly. I have an early build '04 RX8 (pre-order) in case anyone was wondering. So if it worked on my car I think it should work on any '04. Hardest part was probably finding a place to do the key cut. Ended up getting it cut at an Ace Hardware store on one of those key tracing (touch less) machines.
Old Dec 11, 2004 | 01:24 PM
mercury273's Avatar
Mercury273
So the idea that I am getting, is that, if I only have one remaining valid key, and my valet key I cannot program my new retractable key without the Dealer's assistance with the WDS? Or is there a way other than the WDS to achieve this. Thanks
Old Dec 11, 2004 | 05:11 PM
takahashi's Avatar
K1nG,
They need for VIN number just for data logging. Mazda obviously does not want to give a RX-8 chipped key to anyone. There is no "special" key for your car. Most RX-8 key should be generatic for all RX-8 models *(4 port or 6 port)
mercury273,
Valet key should have a chip in it since it can start a car. So theoretically you can use it as a 2nd coded key.
WDS DOES NOT code keys - it is simply bullshit and the identification tag is at your ignition of your car (not the WDS). If so WDS can start your car without your key and why do they want you to leave your set of keys behind for service then .
Hope this helps.
Old Dec 12, 2004 | 11:32 AM
mercury273's Avatar
Mercury273
Thanks takahashi, I will give that a try.
Old Dec 12, 2004 | 08:51 PM
mercury273's Avatar
Mercury273
Voila, it worked and on the first try even
1 valid key
1 valet key
then the new flip one.
worked like a charm
Old Dec 12, 2004 | 09:37 PM
takahashi's Avatar
I was going to say...
* you bastard, ~ a new flip key *
But hey... it worked and glad I helped.
Old Dec 13, 2004 | 05:26 PM
mercury273's Avatar
Mercury273
Haha, thanks again
Maybe you should go and pick one up.
Old Dec 16, 2004 | 10:50 PM
Originally Posted by takahashi
K1nG,
mercury273,
Hope this helps.
If you only have one remaining key that starts the engine, WDS is the only way to program additional keys, can't do it yourself with only one good one.
Old Dec 21, 2004 | 08:25 PM
rx8rx8's Avatar
Question I can't get my key work right
I really need someone to help me. Programing remote part is as easy as cake. :D
But the key..... oohhh how to make it work??
thanks
Old Dec 21, 2004 | 09:38 PM
rx8rx8's Avatar
Talking
I got it works. :D only point is quick quick and quick.
thanks every one on this fourm
Old Dec 26, 2004 | 07:53 PM
Omicron's Avatar
FYI for those of you with the '05 key, or those replacing the remote... doing the key replacement procedure alone will not program the remote. To get that part working, you need to follow page 4 of the directions posted:
Attached Thumbnails DIY: Code your own key / remote-key4a.gif
Old Jan 7, 2005 | 10:35 AM
Omicron's Avatar
I used a thin one that's a little bit less than 1/2 inch.
Old Jan 10, 2005 | 10:51 PM
RotaryJeff's Avatar
I'm Not Here.
Okay, this is cool.
But if I want the new retractable key for my 04 car, do I just order a "blank" one from the dealer, get it cut somewhere, and then do the posted procedures?
Jeff
Old Jan 11, 2005 | 12:03 AM
Omicron's Avatar
Originally Posted by N5TEV
Okay, this is cool.
Jeff
Yes and yes. If you order it from a dealership and give them your VIN, they can ship it to you pre-cut. Then all you have to do is program the car to accept the key and the remote.
Old Jan 12, 2005 | 09:23 AM
magixpuma's Avatar
just coded my own 05 key thanks guys. the transmitter was the hardest part but ill give good instructions right here.
1 sit in car
2 open driver door
3 put the key in move it
to lock to on
to lock to on
to lock to on
theres a small button in the door jam with a rubber stopper on it press it 3 times
now check that the door buttons still work and lock and unlock the doors.
then press any button on your key fob twice. now be patient cuz it takes like 5 seconds for it to first work.
MAKE SURE YOU DO THIS ALL QUICKLY!!!! 30 secs and under.
Old Mar 18, 2005 | 02:25 PM
socalightning's Avatar
Thumbs up 2005 key for my 2004 RX8
Just had my new "switch blade" key/remote cut at the dealership - they did it for FREE! I then quickly programmed the new key in the ignition in like 30 seconds thanks to the D.I.Y. here. Then I programmed the remote fob (attached to the new key) in like another 45 seconds. All my keys and remotes are working with my 8. This was the easiest upgrade by far thanks to the folks who posted to/on this D.I.Y.
Old Mar 18, 2005 | 03:46 PM
RotaryJeff's Avatar
I'm Not Here.
What did you all pay for your keys?
I was charged separately for the key half, and the remote half, which plug together.
Jeff
Old Mar 19, 2005 | 06:42 PM
Got it here... http://www.rx8garage.net/?page=shop/...roduct_id=260&
Old Mar 28, 2005 | 10:21 PM
jmatero's Avatar
is the 05 RX folding key the same as the 05 Mazdaspeed MX-5? I'd like to order it for my 04 Mazdaspeed MX-5.
