2004 Rx-8 issues data poll
Old Nov 1, 2004 | 11:08 AM
samsonite1's Avatar
uh.....
All,
In an attempt to trend the issues with the 8's I will be compiling a list and publish the results once we have a sampling. Please provide the following data for the poll.
Build date
Current mileage
ecu flash level
Any issues with the previous level?
Any issues with the current level?
MT or AT
Any issues with the transmission? If so, what?
Issue with gears?
Issue with the clutch?
Issue with the T/O bearing?
Issue with noise?
Issue with flywheel
Issue with harmonic balance?
Tires on the car
Issues with alignment?
Issues with balance
Issues with cupping on the inside?
Any aftermarket mods
Did the mods effect stock components? If so what was the mod and what did it affect?
Driving style normal or aggressive
Driving cycle - %city % highway
Issues the car has been in for
Outstanding issues
Engine oil - dino or synth
Any issues with the motor?
Transmission oil - Dino or synth
Did any issues with the transmission get better with the fluid change?
Diff oil - dino or synth
Did any issues with the diff get better with the fluid change?
Body - Any issues?
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc
Brakes - any issues? Noise? Premature wear?
Old Nov 1, 2004 | 11:17 AM
samsonite1's Avatar
uh.....
I'll start
Build date Aug 2003
Current mileage 24617
ecu flash level L
Any issues with the previous level? no
Any issues with the current level? no
MT or AT MT
Issue with gears? hard shift to 6th
Issue with the clutch? noisy
Issue with the T/O bearing? noisy
Issue with noise? i seems to have a lot of drive line rattles.
Issue with flywheel no
Issue with harmonic balance? no
Tires on the car Bridgestone
Issues with alignment? yes. It wanders on the freeway. It has been checked
Issues with balance no
Issues with cupping on the inside? yes
Any aftermarket mods no
Driving style normal or aggressive normal with typical shifts between 4 and 5 k
Driving cycle - %city % highway 90% highway 10 % coty
Issues the car has been in for: Recalls and normal maintenance
Outstanding issues drive seat creaks.
Engine oil - dino or synth dino
Any issues with the motor? no
Transmission oil - Dino or synth dino
Did any issues with the transmission get better with the fluid change? have not changed
Did any issues with the diff get better with the fluid change? have not changed
Body - Any issues? no
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc drive seat creaks, window lifts make a lot of noise, center console had to be replaced twice, rattle coming from the rear speaker area, rattle coming from the center console behind the radio/vent area - no Nav. Brushed aliminum accent pieces scratch easy. floor mats look ratty now.
Brakes - any issues? Noise? Premature wear? a lot of noise. I will get addressed with the tsb
Old Nov 1, 2004 | 11:43 AM
RotorGeek's Avatar
Still spining
Originally Posted by samsonite1
All,
Build date 01/2004
Current mileage 4560
ecu flash level M
Any issues with the previous level? No
Any issues with the current level? No
MT or AT = MT
Any issues with the transmission? If so, what? No
Issue with gears? No
Issue with the clutch? No
Issue with the T/O bearing? No
Issue with noise? Normal noise
Issue with flywheel No
Issue with harmonic balance? NO
Tires on the car
Issues with alignment? No
Issues with balance No
Issues with cupping on the inside? No
Driving style normal or aggressive None that effect this
Driving cycle - %city % highway 60 hwy, 40str
Outstanding issues
Engine oil - dino or synth Dino
Any issues with the motor? Nope
Transmission oil - Dino or synth Dino for now
Did any issues with the transmission get better with the fluid change? No
Diff oil - dino or synth Dino
Did any issues with the diff get better with the fluid change? No
Body - Any issues? Nope
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc Noise coming from map light
Lots of brake dust
I have had a very toublr-free ownership so far. My MPG has gone from 14 to 18 so i am very happy with that.
Old Nov 1, 2004 | 11:52 AM
Slims8's Avatar
Piston Traitor
Build date Aug 2003
Current mileage 13100
ecu flash level "M"
MT or AT - MT
Any issues with the transmission? Yes
If so, what?
Issue with gears? yes - 2nd, 3rd, 6th
Issue with the clutch? - Yes - "Exploded"
Issue with noise? - Yes
Issue with flywheel
Tires on the car - Factory
Issues with balance
Any aftermarket mods - No
Driving style normal or aggressive - Normal
Driving cycle - %city % highway - 65% Highway, 35% city
Transmission Failure (Gear problems - 40 days in Shop)
Transmission Problems (Gear Failures - 12 days in Shop)
Clutch Exploded (9 days in shop... 12 days in my driveway)
Outstanding issues
Clutch
Engine oil - dino or synth - Dino
Brakes - any issues? Noise? Premature wear? - Noise
Old Nov 1, 2004 | 11:57 AM
Gaels22's Avatar
my issues
Build date: June 2003
Current mileage: 19434 kms
ecu flash level: M
Any issues with the previous level? Poorer Gas mileage, flooding
MT or AT: AT
Any issues with the transmission? If so, what? None
Issue with gears?None
Issue with the clutch?None
Issue with the T/O bearing?None
Issue with noise?None
Issue with flywheel: None
Issue with harmonic balance?None
Tires on the car: Bridgestone Potenza's
Issues with alignment?: None
Issues with balance: None
Issues with cupping on the inside? Yes, cupping very badly; Mazda Eastern District Service Manager looking into problem : Causing way too much road noise in car
Any aftermarket mods: None
Did the mods effect stock components? If so what was the mod and what did it affect?None
Driving style normal or aggressive: Not normal but not aggressive : I like speed
Driving cycle - 80 city 20 highway
Replace Oil Pan
Replace Spark Plugs
Replace Battery
Upgrade ECM
Replace Center Column 3M Tape
Replace Climate Control ****
Outstanding issues: Tire Cupping Problem and Front Brakes Squeeling
Engine oil - dino
Any issues with the motor? None
Diff oil - dino
Body - Any issues? Yes
3M Tape had to be replaced on Center Column of both sides of car due to chipping - under warranty
Something rattles on dashboard by Steering wheel - no clue what it is
Finish on the ceiling poor around the airbags
Truck finish is very poor - it doesn't connect to the truck and has a 1/2 inch gap
Big problem with front brakes squeeling - Mazda will hopefully replace
Old Nov 1, 2004 | 04:15 PM
th1rd3y3's Avatar
05 STi/05 Titan
Here is my information
Build date: 08/03
Current mileage: 10800
ecu flash level: M
Any issues with the previous level? Yes, loss of power, oil light flashing, CEL
Any issues with the current level? Occasional oil light
MT or AT: MT
Issue with gears? Yes
Issue with the T/O bearing? Unsure
Issue with flywheel? No
Issue with harmonic balance? No
Tires on the car: Stock and winter tires on 17" wheels
Issues with balance? No
Any aftermarket mods: Yes, GReddy Exhaust, Vivid Racing SS Clutch Hose
Did the mods effect stock components? No
Driving style normal or aggressive: Mostly normal
Driving cycle - %city % highway 80%City, 20%Highway
1. Grinding
2. ECU Flash
3. Recalls
Outstanding issues
Grinding just fixed hopefully will remain fixed.
Engine oil - dino or synth: Dino
Transmission oil - Dino or synth: Synth
Did any issues with the transmission get better with the fluid change? Barely but problem was alreay very bad
Diff oil - dino or synth: Synth
Did any issues with the diff get better with the fluid change? Barely but problem was alreay very bad
Random rattles and creaks when slow cornering
Squeaky brakes fixed by TSB so far
Old Nov 1, 2004 | 07:57 PM
epitrochoid's Avatar
Riot Controller
Build date 11/03
Current mileage 16500
ecu flash level M
Any issues with the previous level? Low power, poor MPG, engine bucking
Any issues with the current level? Idle is a little rough
MT or AT MT
Issue with gears? None
Issue with the clutch? None
Issue with the T/O bearing? Just the noise everyone gets
Issue with noise? Synchros are a little loud, but normal
Issue with flywheel None
Issue with harmonic balance? None
Tires on the car OEM Potenzas
Issues with alignment? Tires tramline alot due to 10% tread remaining
Issues with balance None (I even halfway expected there to be)
Issues with cupping on the inside? None
Any aftermarket mods CZ Stage 1.1, HKS Legamax Exhaust
Did the mods effect stock components? If so what was the mod and what did it affect? Coilpacks may be damaged by earlier stage 1 design, otherwise none
Driving style normal or aggressive aggressive
Driving cycle - %city % highway 30/70
Issues the car has been in for Recalls and flashes only
Outstanding issues None
Engine oil - dino or synth Castrol 5w-20 Dino Poop
Transmission oil - Dino or synth Redline Mt-90 Synth
Did any issues with the transmission get better with the fluid change? Yes!
Diff oil - dino or synth Redline 75W-90
Did any issues with the diff get better with the fluid change? Hard to tell (changed at the same time as tranny)
Body - Any issues? None
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc NAV screen rattles at times in the heat
Brakes - any issues? Noise? Premature wear? Standard noise, I really don't care about it though
Old Nov 2, 2004 | 09:22 AM
rkostolni's Avatar
Build date 11/03
Current mileage 6k
ecu flash level M
Any issues with the previous level? yes, repeated check engine light, cat clogged
MT or AT MT
Issue with the T/O bearing? Normal noise
Issue with noise? Just normal T/O noise
Any aftermarket mods No
Did the mods effect stock components? If so what was the mod and what did it affect? N/A
Driving style normal or aggressive Fairly Normal considering this is a sports car
Driving cycle - %city % highway 60% 40%
Issues the car has been in for Check engine light, replace cat, shock sensor to sensitive, rattle, will be going in soon for rusted rotors,
Outstanding issues
Diff oil - dino or synth dino
Interior is good, no probs
Brakes - any issues? Noise? Premature wear? no issues
Old Nov 2, 2004 | 09:27 AM
Slims8's Avatar
Piston Traitor
Very interesting start... Notic 3 transmission failures, all with a build date of August of '03?
Old Nov 2, 2004 | 09:42 AM
Slims8's Avatar
Piston Traitor
August, September... This trend may be useful. I wish some people would post about their "exploding clutches"
Old Nov 2, 2004 | 10:00 AM
RX8SpdDmn's Avatar
I have a late build '04, M Flash.
I have rattles and buzzes.
Yesterday, the tranny stopped allowing me to get into 6th gear. About 15 minutes later, I got it in again. I've had it not let me go in a couple times before, but then went in on the next attempts. This time, I tried over and over and over before finally getting it in. I'll be going to visit the dealer the next time this happens.
Slight brake squeal, but it's not consistant.
Old Nov 2, 2004 | 10:06 AM
RX8SpdDmn's Avatar
Build date - Not sure, but late '04
Current mileage 1200
ecu flash level M
Any issues with the previous level? N/A
Any issues with the current level? Poor mpg.
MT or AT MT
Any issues with the transmission? If so, what? Requires a lot of attention to shift smoothly
Issue with gears? I get locked out of 6th gear sometimes. Yesterday it wouldn't let me back in for ~15 minutes
Issue with noise? in neutral, clutch released, it's noisy
Issues with alignment? no
Issues with cupping on the inside? no
Any aftermarket mods N/A
Driving cycle - %city % highway 50/50
Issues the car has been in for - none yet.
Outstanding issues
Engine oil - dino or synth not changed yet
Transmission oil - Dino or synth stock
Diff oil - dino or synth stock
Body - Any issues?
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc - rattles between driver's side A Pillar and dash, and in driver's door.
Brakes - any issues? Noise? Premature wear? some light sqeal, inconsistant
Old Nov 2, 2004 | 11:28 AM
smoothrx8's Avatar
All,
Build date: 06/03
Current mileage: 8400
ecu flash level: M
Any issues with the previous level?: ?
Any issues with the current level?: NO
MT or AT: MT
Any issues with the transmission? If so, what?: NO
Issue with gears?: NO
Issue with the clutch?: NO
Issue with the T/O bearing?: NO
Issue with noise?: NO
Issue with flywheel: NO
Issue with harmonic balance?: NO
Tires on the car: OEM
Issues with alignment?: NO
Issues with balance: NO
Issues with cupping on the inside?: NO
Any aftermarket mods: NO
Driving style normal or aggressive: Normal
Driving cycle - %city % highway: 95% city/5% highway
Issues the car has been in for: None
Outstanding issues
Any issues with the motor?: Nope
Transmission oil - Dino or synth: Dino
Did any issues with the transmission get better with the fluid change?: N/A
Diff oil - dino or synth: Dino
Did any issues with the diff get better with the fluid change?: N/A
Body - Any issues?: Orange Peel!!!
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc: Rattle near rear right speaker is driving me crazy!!!
Brakes - any issues? Noise? Premature wear?: Brake dust everywhere
Old Nov 2, 2004 | 12:15 PM
samsonite1's Avatar
uh.....
Once we have a sample of 20 cars, We can start trending.
I have noticed as well about the 8-03 build date and transmissions......
Old Nov 2, 2004 | 01:12 PM
Nemesis8's Avatar
Bigus Rotus
Build Date: 09/03
Current mileage 30K
ECU flash level R
Any issues with the previous level? None
Any issues with the current level? None
MT or AT? MT
Any issues with the transmission? If so, what? Noisey
Issue with gears? Second Gear Grinds
Issue with the clutch? None, after I replaced the hose with the MS part
Issue with flywheel? None
Tires on the car: Pirelli P-Zero
Issues with alignment? None
Issues with balance? None
Any aftermarket mods? Click Here
Did the mods effect stock components? Yes
If so, what was the mod and what did it affect? MS Suspension - handles better than my buddies Porsche 911 Carrera now!
Driving style normal or aggressive? Aggressive
Driving cycle - %city % highway: 30/70
Issues the car has been in for: Recalls and flashes
Outstanding issues: None
Engine oil - dino or synth 5W-20 Dino
Transmission oil: Redline MT-90 Synthetic
Diff oil: Redline 75W-90 Synthetic
Did any issues with the diff get better with the fluid change? Can't tell
Body - Any issues? Cheap Paint and Orange Pealed Clearcoat
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc: Rear passenger side rattle
Brakes - any issues? Noise? Premature wear? Brakedust Everywhere, and Wheel Hubs Rusted
Old Nov 2, 2004 | 01:54 PM
NomisR's Avatar
Build date 11/03
Current mileage 7500
ecu flash level M
MT or AT MT
Tires on the car: Potenza
Driving style normal or aggressive: semi agressive
Driving cycle - %city % highway 35% city 65% Highway
Issues the car has been in for: Recall, M Flash, Maintainance
Outstanding issues: Rattle in rear door
Transmission oil - Dino or synth Whatever they put in at the factory
Did any issues with the transmission get better with the fluid change? No changes
Diff oil - dino or synth No idea
Did any issues with the diff get better with the fluid change? No clue
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc Rattle on rear driver side door and mirror
Brakes - any issues? Noise? Premature wear? None yet, no noise, but excessive brake dust.
Old Nov 4, 2004 | 10:43 PM
beachdog's Avatar
Build date 09/03
Current mileage 8000
ecu flash level M
Any issues with the current level? Y (the drive by wire is more sensitive at low speed than previous levels. harder to creep at low speed - manual trans)
MT or AT
Issue with gears? crunchy 1-2 shift occasionally - plan to fix with synth trans oil
Issue with noise? Y loud in neutral (again, plan to fix w/synth)
Tires on the car
Driving cycle - %city % highway 30c 70h
trans input shaft noise
1-2 shift crunchiness
a/c fast cycling
abs pump failure
Any issues with the motor? rough idle
Transmission oil - Dino or synth currently d
Diff oil - dino or synth currently d
Old Nov 5, 2004 | 07:09 AM
peterlemonjello's Avatar
Current mileage: 16200 miles
ecu flash level: M
MT or AT: MT
Driving cycle - 90%city 10%highway
Upgrade ECM
All Recalls
Replace Door Sills
Outstanding issues:
Engine oil - Castrol 5w20
Transmission oil - dino
Diff oil - dino
Small problem with front brakes squeeling. After 14,000 miles squeaks aren't near as bad.
Old Nov 6, 2004 | 01:54 PM
Slims8's Avatar
Piston Traitor
Samsonite, How's everything looking. It looks like there are plenty of people with tranny problems for the car to only be about a year old. I wish more people had posted which had major problems or Mazda's refusal to fix.. Oh well.
Old Nov 6, 2004 | 04:58 PM
zoom_zoom33's Avatar
It sounds like most problems with the tranny on the MT's only saw one AT reply
Old Nov 6, 2004 | 07:12 PM
samsonite1's Avatar
uh.....
So far it is showing issues with Transmissions and fit and finish. I will show the compiled data on Monday
Old Nov 7, 2004 | 02:04 PM
RotaryJeff's Avatar
I'm Not Here.
Build date Nov 03
Current mileage 15000
ecu flash level M
MT or AT
Issue with gears?
Issue with noise?
Issue with flywheel
Tires on the car Stock
Driving style normal or aggressive Moderately Aggressive
Driving cycle - 60%city 40% highway
Outstanding issues
Did any issues with the transmission get better with the fluid change? N/A
Did any issues with the diff get better with the fluid change? N/A
Body - Any issues?
Replaced outside loose pass side window guide/molding
Replaced center console latch button, TWICE. (Pops out of alignment)
Replaced Ashtray door (tensioner/spring gave out)
Jeff
Old Nov 8, 2004 | 10:39 AM
QuarterMile's Avatar
Build date Aug 2003
Current mileage 14500
ecu flash level "M"
MT or AT - MT
If so, what?
Issue with gears? yes - 2nd grinding
Issue with the clutch? - Yes "Exploded"
Issue with flywheel
Issues with balance
Driving cycle - %city % highway - 75% Highway, 25% city
1. Transmission grinding
2. Clutch Exploded
Brakes - any issues? Noise? Premature wear? - Very squeaky
Old Nov 8, 2004 | 12:33 PM
rex's Avatar
rex
Revvus Maximus
Build date 9/2003
Current mileage 4300
ecu flash level M
Any issues with the previous level? Poor fuel economy
MT or AT MT
Issue with gears? Poor synchro action on 1-2 shift when cold
Issue with the clutch? Clutch burned easily when new - pressure plate loose
Issue with noise? Consistently noisy since new
Tires on the car Bridgestone Potenzas
Any aftermarket mods None except cosmetic mods
Driving style normal or aggressive Mix: 50% normal/50% aggressive
Driving cycle - %city % highway 80%city 20%highway
1. Clutch burning caused by loose pressure plate
2. Various reflashes and all relevant recalls
Outstanding issues
None
Transmission oil - Dino or synth synth
Synthetic (RedLine) oil improved general shift quality when warm, but did not affect 1-2 shift when cold
Diff oil - dino or synth dino - stock
Did any issues with the diff get better with the fluid change? Not applicable
Interior - Fit and finish. Rattles and squeaks. Noisy window lifts? Etc None
Old Nov 8, 2004 | 04:25 PM
JMD RX-8's Avatar
Build date - June 2004
Current mileage - 4,500
ecu flash level - M
Any issues with the previous level? - n/a
Any issues with the current level? - n/a
MT or AT - MT
Any issues with the transmission? If so, what? - None
Issue with gears? - None
Issue with the clutch? - None
Issue with the T/O bearing? - None
Issue with noise? - None
Issue with flywheel - Plan to swap out for RB lightweight one
Issue with harmonic balance? - None
Tires on the car - OEM Dunlop 8090
Issues with alignment? - No
Issues with balance - No
Issues with cupping on the inside? - No
Driving style normal or aggressive - 50% aggressive
Driving cycle - %city % highway - 50/50
Issues the car has been in for - Re-program alarm for new key. Dealer couldn't do it and I found instructions posted on here. Thanks much...saved me a 4 hour appointment to flash immobilizer.
Outstanding issues - None
Engine oil - dino or synth - Castrol GTX
Transmission oil - Dino or synth - OEM - Synth in a month
Diff oil - dino or synth - OEM - Synth in a month
Body - Any issues? - Too many women admiring it (not an issue by any means)
Brakes - any issues? Noise? Premature wear? - Excessive dusting from front rotors only.
