Alignment settings for street/track use
Rating: Thread Rating: 4 votes, 5.00 average.
Old Oct 28, 2004 | 09:11 AM
TrackAddict's Avatar
I miss my 'Bu
For all you guys getting on the track with your RX8... What are your alignment settings? Please indicate if you do roadcourse or autocross. I don't know how significantly different those settings should be. I use my RX8 as a daily driver and plan on doing the occasional track day. My settings are as follows with me in the car:
Front Camber -0.7 Left, -0.7 Right
Front Caster 6.7 Left, 7.2 Right
Front Toe 0.09 Left, 0.09 Right
Front Cross Camber 0.0
Front Cross Caster -0.5
Front Total Toe 0.18
Rear Camber -1.4 Left, -1.4 Right
Rear Toe 0.13 Left, 0.12 Right
Rear Total Toe 0.25
Thrust angle 0.01
Old Oct 28, 2004 | 06:50 PM
Ophitoxaemia's Avatar
dizzy snake pilot
those are good conservative settings i think. for track use id use a little toe out in front (like -.125 to -.25 total) plus less rear toe-in (like .125 or even try 0) as much front negative camber as you can get (even if it means less caster). tire temps will be the best judge though on camber. if it is a left turning track, for example, then you can bias the camber a little for more right side camber.
james
Old Oct 28, 2004 | 07:42 PM
PUR NRG's Avatar
Hey, have you tried using the search function? This is one of those questions that has lots of answers if you care to look.
________
Oral sex
Old Oct 28, 2004 | 08:12 PM
ronbauer's Avatar
Annie and I ended up at -0.9 up front with 0 toe and -0.7 in the rear also with 0 toe.
This was not what we wanted as we had heard that -1.5 up front was possible, but -0.9 was all we could get. To help the car rotate, we therefore lessened the amount of rear camber that we could get and didn't bother with putting any toe-in in the back. At the first autocross we did, it seemed to work okay with the 275/35/18 Hoosiers we were running. It did push a fair amount in the slow stuff, but that was overcome by just slowing down more. In the fast stuff, it worked pretty well, though a bit boaty (needs better shocks....)
Ron
Old Oct 28, 2004 | 08:47 PM
I miss my 'Bu
There is indeed a bunch of info however there is no thread that allows users to list their specs and compare notes. If you see one, post a link please. Some have their settings in their garage like Dark8 and AlexCisneros. If anyone else has theirs listed please reply here.
Old Oct 28, 2004 | 09:12 PM
Dark8's Avatar
Ride Naked!
I'm running -1.4 (max I could get) camber and 7.3 caster on both sides of the front. -1 camber on the rear, 0 toe all around. It's a little loose and I will add another -.5 rear camber on the next alignment and see if that tightens things up. The car takes on a good 4 wheel drift around fast sweepers. :D
I'm also lowered about .75 inches if that has any effect on how much camber you can get. I also used a floor jack to lift on the wheels when I tightend things up after installing the coilovers.
Old Oct 29, 2004 | 02:55 PM
RotaryZZ's Avatar
So does anyone know what is the factory specification on alignment for our car??
Old Oct 29, 2004 | 03:32 PM
Dark8's Avatar
Ride Naked!
Here are pics of the shop manual for the front and rear settings for the sports suspension:
Attached Thumbnails Alignment settings for street/track use-front.jpg   Alignment settings for street/track use-rear.jpg
Old Oct 29, 2004 | 04:21 PM
RotaryZZ's Avatar
I'm sorry but I'm a little confused.
Is the one on the left for the standard suspension setup while the smaller print on the right is for the sport suspension set?
And there is no difference between front and rear??
As for the camber setting, how come there are a whole set of numbers?
Old Oct 29, 2004 | 05:17 PM
Dark8's Avatar
Ride Naked!
Left column is factory acceptable variation. Far right column is the setting. Second column from right is your vehicles ride height measured from the center of the wheel straight up to the edge of the fender. So, determin your ride height and use the numbers to the right to determine the factory setting. Hope that makes sense.
Old Nov 2, 2004 | 10:22 AM
RotaryZZ's Avatar
>Left column is factory acceptable variation................
That I understand. But what I'm saying is there are really two tables of settings. The table on the left is for the regular suspension while the table on the right is for the sport suspension.
Since I've the sport package, I'll only follow the settings on the right table. But what seems to be missing is the Caster settings. Should I use the same one as in the table to the left which is for the regular suspension? And what about the different settings for the front versus the rear? Are these numbers applicable for both front and rear wheels??
Old Nov 2, 2004 | 04:32 PM
Dark8's Avatar
Ride Naked!
Sorry, my bad. Here are the sport suspension tables:
Attached Thumbnails Alignment settings for street/track use-alignment.jpg
Old Nov 3, 2004 | 10:01 AM
RotaryZZ's Avatar
That looks much better ;-) Btw, I realize there is no caster settings for the rear, should I use the one on the front too?
One observation, in general the rear has a more pronunced -ve camber than the front according to the specification. But my impression is that most people will have a more -ve camber on the front instead when they try to set the 8 up for track use! Am I missing something or am I totally off the mark?!
Old Nov 3, 2004 | 10:54 AM
Dark8's Avatar
Ride Naked!
"Btw, I realize there is no caster settings for the rear, should I use the one on the front too?" Not sure what you mean. If you are wanting a caster setting for the rear, there isn't caster adjustments for the rear.
I was running -1.4 front and -1 rear and the rear is just little too tail happy. For next season I'm going to try -1.4 rear and see if that brings it back to neutral. Keep in mind that I'm setting it up for auto-x. I definately wouldn't want a tail happy car going around a 80 mph sweeper on a race track. A little understeer can be good.
Old Nov 3, 2004 | 12:58 PM
I miss my 'Bu
My rear camber is at -1.4 so to get a bit better rotation do you think I should just get more front negative camber or go to rear toe of zero? I plan on dialing in more negative camber up front but don't want to go to extremes due to tire wear concerns.
Old Nov 3, 2004 | 02:38 PM
dizzy snake pilot
i always set my camber by looking at tire temps. even if you want to use less camber, you could still use tire temps to determine how close the front versus rear camber settings are.
for maximum performance, you want the inside (inboard third) of the tire a little hotter than the outside. (this is because the inside will heat differentially during braking and straights)
james
Old Nov 3, 2004 | 02:50 PM
RotaryZZ's Avatar
What's the general consensus for the front and rear camber settings for both street and occasional track use? More -ve camber on the front than it would be on the rear??
Old Nov 3, 2004 | 03:05 PM
AlexCisneros's Avatar
Don't pay too much attention to my alignment settings, remember I run staggered . Also I am going to be putting more positive camber in the rear to lower the traction of the rear tires and get more rotation. I just haven't gotten around to it :D .
...unless of course Tanabe released their coil over system at SEMA
Old Nov 20, 2004 | 08:52 AM
fastmike's Avatar
Did the new 8's(not mine) alignment yesterday w/ about a 1/4 tank of fuel
It is a base with rear spoiler.
500 miles or something on the understeering pig.
Owner(110 lbs?) sat in the car while work was happening.
I sure do like seeing the "red zone" when working with the Hunter machine.
Kinda funny...
Stock wheels make it tough to get alignment rig set up on. We had to tape the frame of each sensor to avoid wheel scratches and could not get an exactly even hook up to the wheel but machine supposedly compensates for the runout.
Left front was the "least adjustable" and alignment was kinda based around that.
Right front has lots of adjustment possible.
Ended up with 1.0 neg with 6.7 caster both sides and .01 toe in a side.
Playing with caster adjustment did not really increase camber.
Car gains LOTS of camber as you turn the steering wheel. I mean up to almost 2 deg neg on outside wheel with just under 3/4 of a wheel turn.
It also gains a little camber as front suspension is compressed and also goes slight toe out.(should help turn in under braking if you choose to do that sort of thing).
Kinda cool that it does all those things. Ideal imo.
As the suspension is uncompressed(car lifted), Camber appeared to decrease ever so slightly(loses about .1 when strongly lifting the car) and toe seemed to just barely toe in.
Rear ended up with 1.4 neg a side and .02 toe in a side.
You can pretty much do/end up with whatever you want in the rear.
Lots of camber available and lots of toe to play with.
Toe adjuster is VERY sensitive to movement. A little twist of the adjuster translates into lots of toe change. Toe adjuster does not really mess with camber either.
Car should be VERY easy to change at track using rear toe as one way to do it.
Too much exit oversteer? just add some toe in at the rear.
Got that push that you hate? just take the rear toe in out of the car but beware of too much rear toe out at the track!
As the car squats on suspension in the rear, it gets a little more camber and slight toe in.
Good for us!
I forgot what is did when we lifted it...sorry.
These lift/pull down on the car does not take into effect bushing changes under power, braking or cornering but I was glad to see that all the math was going in the correct directions.
On a quick recon run, it appears that the "mid corner power on excessive push/understeer" is gone.
Owner should get at least 10 runs and I should get a few in this Sunday at a practice to see how fun/fast the car is.
Car owner prefers tail happy over push but would prefer tail happy/oversteer coming into corner to rotate then neutral mid corner even when accelerating slightly then maybe just a hair of push right at the end of the corner under full power.
We'll see..Kinda hard to do stuff on a completely stock car.
Shocks/maybe a bar(not for sure yet on that)/some 710's and an exhaust should help the zoom-zoom a little bit.
Our local buddie/rallyist builds high quality custom exhausts and car will be there TONIGHT.
I am trying to talk car owner into a on/off straight pipe right out the back but have not been successful...yet...
Car owner wants the exhaust to exit where it does now but that is the HEAVY way and has 2 extra 90 bends!)
I need to make sure that car does not use back pressure to control ports like the older 7's did. I think that it is all electronic now???
Stock tires are the SP sport 8090's and appear to have some good stick.
We see if I have the same opinion after running it at the autox course...
FM
Old Nov 20, 2004 | 09:51 AM
I miss my 'Bu
Thanks for the writeup. Please follow up after your tests on a track or autocross. I am particularly interested in all the settings as I feel mine could use some minor tweaking to reduce corner exit power-on understeer.
Did you find any ride height differences on the car?
Any ideas how to fix a side to side ride height difference of a 1/4 inch?
Thanks.
Old Nov 20, 2004 | 11:35 AM
fastmike's Avatar
Thanks.
We are starting at a baseline setup so that we can measure how much time each mod is worth on the autox course.
We can keep the board informed(unless we find the "special secret" that makes the car as fast as S-2000's!)
We were just "shooting in the dark" + a little bit of consultation with others with this first setup.
I did not measure ride height or measure corner weights.
Fixing things like what you describe above(ride height) is very possible but somewhat difficult to do if you want to stay legal in SCCA's solo2 Bstock class.
If you do not care about legality and want to do something about your ride height diffs, just shim the stock springs or perches.
The hard part is getting ahold of a corner weighting pads/box.
Most race shops can set u up but make extra sure that the floor where they are doing the setup is level or that they level the pads with a super long bubble or electronic level(or other means).
Be sure to ballast the seat etc. so that you are in a race ready condition.
I looked at your original post in this thread and if it was my car I would first take most of your front and rear toe in out and try to fix that left front caster so that it matches the right. Remember that more caster = more camber as you turn the steering wheel.
I really need to do some pyrometer testing to figure all the stuff out "for real" though on the 8.
I sold my good one too! UGH!
Good luck,
FM
Old Nov 22, 2004 | 09:57 AM
PUR NRG's Avatar
110 lbs? Male or female? And what is the "red zone"?
________
Hot Box Vaporizers
Old Nov 22, 2004 | 07:20 PM
fastmike's Avatar
It is a female.
Hunter machine screen flashes red when you take settings out of "factory" ranges.
I was not "thrilled" with setup this Sunday but not totally unhappy either
The car needs some rear toe-in.
I still do not think that the big front bar is the way to go either. I might be one of the few on that one though.
I would rather size bar for long corners/turnarounds and use the shocks to tune for slaloms.
That is just me though. AND some shocks ARE needed.
I have a set of D/A's from my TTRX and are going to look if they will fit/work.
Doubtful but worth taking a look at.
Car does brake nicely if you do not use antilock too much and seems to turn in for the first 2 transitions nicely but starts to oversteer/crab sideways a little too much in the rear when power hits at top rpms while turning.
Hopefully we will get it worked out.
FM
Old Nov 23, 2004 | 01:41 AM
ronbauer's Avatar
Of course fastmike was running on the stock tires in Shelbi's car..... ;-)
We meanwhile were on 275/35/18 Hoosier A3S04s (we'll get the Kumho 710s when they're out next year,) and have our Racing Beat front swaybar. Temps were in the low to mid 40's, so our poor tires were having a very hard time getting up to temp and staying there. :-(
The car worked very well with some minor push, but that had more to do with the surface than anything else, as we were turning on VHT at one point. The car was very predictable, and could be made to get some good rotation at the limits. The car does still exhibit some pretty strong push in real slow turns, but as I noted earlier, this can be overcome by slowing down more.
While I agree with FM that the car needs shocks, I whole-heartedly disagree with his idea of not changing the front sway bar. It tightened up the car a bunch and it still turns in very well. We'll ultimately get shocks and tune the slow speed understeer out of the car that way.
BTW, of our little practice, I took top Pax time against some good ES cars. It will be very interesting to compare the car to the 968 we're planning to run next year......
Ron
Old Nov 23, 2004 | 11:06 AM
Banannie's Avatar
I rode w/ Shelbi on one of her runs, and the difference between front bar v. no front bar was pretty dramatic. I DEFINITELY would not take the bar off our car...
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
