Duct Tape works wonders... even on the RX-8
Old Oct 22, 2004 | 10:00 PM
GotBass's Avatar
Still plays with cars
I have not heard of this yet.
I was driving home last night, my friend who was following me called me and said my tail light/brake light was out. I figured he was f*ing with me, knowing Im over protective of my new car. But when I got home I checked it out and sure enough it was out. Upon further examination this morning I realized that it wasnt burnt out, the bulb fell out of the socket and was lying at the bottome of the ficture. Problem is the only way I could get into the ficture (with out breaking it) was through the little hole in the back where the socket screws into. There was no way I could even get a finger into the fixthre. The only solution - a wire coat hanger with duct tape on the end. Still wasnt an easy task but I finally was able to stick the bulb and pull it out. The fillament was still fine and the light works again.
Old Oct 22, 2004 | 10:27 PM
D MENAC 7's Avatar
Moderator with a mycocardium
ahh, I had one fall out too, I just removed the two bolts, pulled the wires and turned it upside down and shook it like a piggy bank and out it popped.
Old Oct 23, 2004 | 05:36 PM
irish8's Avatar
Get in ma belly!!
Take it to your dealer and have it fixed/replaced under warranty!! That should not have happened.
- Irish
Old Jul 31, 2009 | 01:29 PM
Lord ET's Avatar
Is that a bike rack?
Sweet thread resurection!!
I've got this problem still, anyone else!
Old Jul 31, 2009 | 02:42 PM
oreo's Avatar
It's happened to my car 2 times in 38K miles. I think its a design flaw of the bulb socket. I just teke out the hole thing and shake it . It takes about 5 minutes.
Old Jul 31, 2009 | 02:44 PM
rodjonathan's Avatar
silent assasin
yea shaking it works great i actually got mine fixed under warranty now though
Old Jul 31, 2009 | 02:52 PM
oreo's Avatar
what did they fix under waranty exactly, you got a new wiring harness for the bulb??
Old Jul 31, 2009 | 03:00 PM
silent assasin
yeah they changed the wiring harness on both sides ... i got a ticked for it twice and ive had legal problems with mazda usa before so the dealer replaced em no questions asked ... i think a few cars had that trouble ... and it wasnt just rx8s
Old Jul 31, 2009 | 03:07 PM
oreo's Avatar
good to know. sad thing is my car is out of warranty and there is not a TSB out there for it.
Old Jul 31, 2009 | 03:17 PM
Lord ET's Avatar
I always end up taking the whole assembly out too and shaking it. Then when I put it back in I bent the contacts onthe bulb outward and the contacts inside the socket inward.. it holds it in for almost a year for me until it falls back out.
Old Jul 31, 2009 | 04:12 PM
invasion08's Avatar
I had to use a coat hanger and duct tape when i forgot to put a piece of tape on my rx8strakes LED parking light. That bulb was a pain to remove. Finally got it though
Old Jul 31, 2009 | 04:18 PM
yeah for duct tape!
Old Jul 31, 2009 | 05:20 PM
rotarygreg's Avatar
grass hopper
wow you guys are inventive. ive seen a few 8s come into the dealer with this too. i usually use a magnet....the contacts in the bulb are metal after all. You do need a smallish magnet with a bit of grab to it though. works every time and it only takes like 2 mins too.
Old Jul 31, 2009 | 05:27 PM
fastlaneracing's Avatar
Rotor User
Pictures in the signature should be limited in size.
Old Jul 31, 2009 | 05:50 PM
04RX8man's Avatar
Rotary Powered Countryboy
wow this is a pretty wild thread revival.....
duct tape is all you need for any job
8is>enuff
Sep 24, 2015 08:57 AM
Jazzmeson
Aug 30, 2015 02:23 AM
ripigs
Aug 2, 2015 10:44 PM
Jazzmeson
Aug 2, 2015 09:49 PM
stickmantijuana
Jul 19, 2015 10:33 AM
