MOD suggestion: Auto close moonroof w/ windows.
Old Oct 17, 2004 | 06:23 PM
w0rm's Avatar
PUSHER ROBOT
I often find myself using one hand to close the moonroof while im using the other to close up both windows and recently realized it might be neat to have the car close the moonroof when both windows are being rolled up at the same time.
Basically, the only time you're rolling BOTH windows up is a time you're probably wanting to close the moonroof as well. Poddibly, even have it so that the two windows roll up and then if you continue to hold on the window switches, the moonroof closes as well. I've looked over the tech manual and it doesnt seem to have enough information about the wiring for the moonroof.
Was wondering if anyone would be interested in a mod like this?
Old Apr 20, 2005 | 07:00 PM
irfan's Avatar
ElusiveSasquatch
you could rewire a moonroof switch next to your window switched so u could do them all at once? maybe wire it into a passenger side window swith that u mount on the driver side.. so it LOOKS stock at least?
Old Apr 20, 2005 | 07:06 PM
Redshift's Avatar
Spinning Dorito Junkie
I had something like this hooked up with my old Civic SiR.
With the help of a good installer, when he put in the alarm, he wired in a couple of relays that would close the windows and the sunroof when I armed the alarm.
I loved it, and it was a great party trick.
Old Apr 20, 2005 | 08:36 PM
tiggerlee's Avatar
May Cause Anal Leakage
Cool idea but I wonder how this would work in the reverse.
If both windows are rolled DOWN would the sunroof open?
Seems like there would be a lot of variations one would neeed to take into account before re-wiring.
Old Apr 21, 2005 | 06:18 AM
Artzy8's Avatar
RX8-Nuendo3 Life is Good
At one point manufacturers offered auto close on windows, that is until all of the smashed finger complaints came in.
It's probably a good idea to know where everyone's fingers are and manually shut a door window or sunroof - especially if kids ride in your 8 - IMHO.
bill
Old Apr 21, 2005 | 09:37 AM
devoid's Avatar
My doctor prescribed RX-8
I have all my windows including the sunroof close when I lock the car from the remote. (On the side note, this also allows me to open or vent the windows and sunroof from the remote)
Old Apr 21, 2005 | 12:04 PM
FONZIE's Avatar
AYYYY....I mean....ARRRR!
You should write a DIY on this. I already have the Devoid Deflooding DIY I might as well add another Devoid DIY!
Old Apr 22, 2005 | 12:24 AM
R Exotic 8's Avatar
wow, thats awesome. Can u please briefly explain on how you did that? I would love to do that with my 8. Thanks
Old Feb 24, 2006 | 11:13 AM
w0rm's Avatar
PUSHER ROBOT
Reviving this thread, has anyone come up with a DIY for autoclose on lock?
Old Mar 22, 2006 | 07:55 PM
devoid's Avatar
Since I'm back...for the moment...I'll write a very brief explanation of a simple close sunroof on fob lock....(you will likely want to look at page 118 of the electrical manual for this to make sense)
you need:
2 relays
1 delay timer (you can usually grab one from a local audio shop)
Grab a signal wire from the fob lock trigger...anywhere...look in the eletrical manual
Grab the positive power line into the sunroof motor (plug M-03, pin I)
take this always on power into relay 1 and the timer
take the lock trigger into the timer as the trigger
from the timer, send your output to relay 1's trigger
run a negative line into relay 2 (pull it from plug M-03, pin H)
from relay 2 run the output to plug M-03, pin A
from relay 1, run the output to the trigger of relay 2, AND power to the sunroof swich (which should be plug M-01, pin 2)
as I said...its a very brief explaination....
Old Jun 9, 2006 | 10:48 AM
zenmoused's Avatar
the stig is my hero
devoid- I think I speak for the entire RX8club community when I say PLEASE PLEASEE do a DIY on this. I think this is a feature almost everybody on this forum would want to wire, but nobody wants to screw up by venturing out on their own.
We would be eternally grateful.
Old Jun 16, 2006 | 02:18 PM
devoid's Avatar
I hate to say...but it's going to be a long time before I take apart my roof. Truly though, if you follow my written instruction, if will work. Now, if someone else in my area wants to do this, I'd be more than happy to help, and we can make a DIY at that time.
Old Jul 27, 2006 | 10:43 AM
terretsboy's Avatar
Official "That Guy"
Any word on this yet?
Old Aug 1, 2006 | 01:25 PM
terretsboy's Avatar
Official "That Guy"
Devoid where are you in Ohio? I would be willing to use my car to do a DIY for the windows and the sunroof. I will be back in Dayton on after the weekend of the 18th. Let me know.
Old Aug 3, 2006 | 10:00 PM
zenmoused's Avatar
the stig is my hero
Yes, do the DIY, or really ANY more info would be fantastic.
FastBlackMerc
Nov 1, 2015 02:59 PM
blu3dragon
Jun 15, 2013 07:36 PM
bullitz400
Apr 1, 2012 09:23 AM
ScooterAZ
Mazmart
Jun 15, 2006 07:56 AM
Deep Blue
Canada Forum
19
Aug 8, 2003 09:37 PM
