pyrometers
Old Oct 11, 2004 | 08:15 PM
Zaku-8's Avatar
pyrometers
What are pyrometers used for? Is it the kind of tool that is generally helpful, helpful only for people who track/autocross, or helpful only for tuners?
Also, can anyone make recommendations for particular pyrometers?
Old Oct 12, 2004 | 12:12 AM
shelleys_man_06's Avatar
Not anymore
I Googled the word (define: pyrometer). Here's what I found:
A thermometer designed to measure high temperatures.
An electronic device used to measure tire temperatures.
Old Oct 12, 2004 | 12:15 AM
Scott Farmer's Avatar
Pyrometers are used in the racing world to measure the temperature at different points on a tire. By measuring the temperature (and therefore, the load exerted on that part of the tire surface), you can measure how effective your alignment is. Ideally, you'd want as much of the tire surface as possible being used equally.
Pyrometers can also be used to measure the temperature of other components, such as brakes, headers, etc.
Old Oct 12, 2004 | 12:17 AM
epitrochoid's Avatar
Riot Controller
most often in our world, it refers to a exhaust gas temperature gauge. but also as the other guys mentioned..it's kind of a generic term
FerociousP
RX-8 Racing
May 17, 2014 02:13 PM
kbrewmr2
RX-8 Racing
Mar 24, 2014 01:43 PM
Gray Ghost
May 4, 2013 07:03 AM
Gray Ghost
Jun 17, 2012 08:41 AM
franniestopdat
Jan 19, 2008 08:19 PM
