Sandpaper Paint
Old Sep 30, 2004 | 10:21 AM
PIXER's Avatar
Sandpaper Paint
Well, I've had the RX-8 for about 4 months now and decided to wax it. The paint felt REALY rough, kind of like sandpaper. (when I ran my hand across it, it actually took a little force just to move) Anyway, I wanted Zaino, but being 19 and paying for my car plus all other expenses (mainly just to impatient to wait) I used NXT. After waxing some of the paint feels the way it should, but the hood, front fenders, and front bumper are still sandpaperish, now I know what your thinking, and YES I DID wash my car prior to waxing, spent like 2.5 hours just washing (so maybe I took a break or two) Anyway, what should I do? I pay to much for this car to have it feel the way it does. Any help would be appreciated. Thanks
Old Sep 30, 2004 | 10:30 AM
StewC625's Avatar
Insanely Yellow
Use a clay bar kit - I use Meguiars, although the best one I've ever seen is the clay bar kit from Griot's Garage (www.griotsgarage.com). The sandpaper effect is from crap embedded in the paint as it was transported - most likely rail dust. Since you have a black car, you can't see it (VERY visible on a white or yellow car ... ) but you sure can feel it.
Once you've used it the paint will feel like a stripper's **** ... not enough O's in SMOOOOOTH to describe it.
The clay does swirlmark the paint slightly, so after using it, use Meguiar's #2 New Car Glaze and Swirl Mark remover, then rewax with the NXT and you're good to go.
Old Sep 30, 2004 | 11:06 AM
Zaku-8's Avatar
I tried using a claybar for the first time, and I'm just unsure about how to use it. How much downward pressure should I use for each swipe? If I'm claying light then it seems like nothing gets picked up, and if I clay with a lot of pressure then it seems like i'm scratching the paint with whatever particles might have gotten picked up
Old Sep 30, 2004 | 11:42 AM
StewC625's Avatar
Insanely Yellow
Make sure you're using LOTS of the spray detailer to lubricate the paint - and the clay should just glide over the paint regardless of the pressure you apply. You're not rubbing or polishing the paint but instead are picking up junk that's embedded in it. It won't pick up the crap on the first swipe. I usual do the car in 2 foot x 2 foot sections when clay barring it, wipe off the detailer, then feel the paint for smoothness. That tells you where to concentrate again - which I do, then move on. Takes about 2 hours to completely clay the car.
Old Sep 30, 2004 | 02:39 PM
NavyDood's Avatar
Who is this Navy guy?
I've said it once before and I'll say it again...... Claying your car will not and better not cause any kind of scratching or swirling. If it does, it's either contaminated or should be tossed in the trash.
Pixer...
Yes your right, Zaino may seem expensive at first. But in the long run it will not cost you any more than doing the autoparts store buying. Sometimes it's even cheaper because of all the trial and error ppl go through. An 8oz bottle of Zaino Z2 will do your car at least 20 times if applied properly. Zaino's clay comes with 2 bars and a handy storage tub. Zaino Z2, Z5, Z6, Z7 all compliment each other because they all contain the polish within them.
Old Sep 30, 2004 | 09:56 PM
PIXER's Avatar
Thanks for the advice. I was wondering, what would happen if I just put another coat of wax on it?
Old Sep 30, 2004 | 11:11 PM
bryrx804's Avatar
Its over spray clear coat I bet. Need to take a buffing wheel and burn if off ..well not burn but get some 3M polish and buff the over spray out. Taking a few thousands of a inch off the clear coat to remove over spray.
Old Oct 1, 2004 | 06:38 PM
PIXER's Avatar
Yeah, that sounds way to scary to me. Theres gotta be something else I can do.
Old Oct 1, 2004 | 10:09 PM
Tony Orlando's Avatar
Bored thread resuscitator
Clay it. Just make sure you're folding the clay over and exposing fresh material when it starts to get rough.
Old Oct 2, 2004 | 06:30 AM
wakeech's Avatar
mostly harmless
...how is a few thou scary when your paint is like 1/32nd thick??
using good ol' elbow grease, and not a power tool, it's literally impossible (i'm sure you'd DIE before you do it) to polish through the paint.
Old Oct 3, 2004 | 03:49 PM
bryrx804's Avatar
thats right. thats what paint shops do, just buff it out.. I have too out key marks out of cars that way. just takin the few layers of clear down..
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
GK1707
Sep 27, 2015 07:33 PM
djp6783
Sep 19, 2015 12:12 PM
