How Can I remove rear seat?
Old Sep 17, 2004 | 07:31 AM
Thommino's Avatar
I want installa my switch in this way:
How can I remove rear seat?
Old Sep 17, 2004 | 08:27 AM
WHealy's Avatar
Mr. Blue Man
I found this text from this previous post. Hope it helps.
Removing the rear seats is very simple. But having room to put them back in after you would put this on the seat side of the cross bar ... I don't know that there is enough room. Are you sure that whoever did this previously didni't remove their rear seats?
Originally Posted by WHealy
Genom,
Thanks for the help. Foudn that you pull the rear seat bottom right up from the two fasteners with little effort. This then exposes two bolts holding the rear seat back. Loosen these and then the seat back can be raised off to more clips near the top. Then it can be lifted out.
Of course then you can remove this trim piece.
Thanks so much.
Old Sep 17, 2004 | 08:51 AM
Thommino's Avatar
I take the picture from your forum about 4-5 mouths ago?
I hope to be able to put my rear seat on again.
coolcars44
Nov 29, 2017 05:45 PM
jlm2664
SE For Sale/Wanted
Mar 9, 2016 11:50 AM
akagc
Aug 11, 2015 07:07 PM
Twiztog43
Aug 4, 2015 04:49 AM
