Clutch Play?
Old Sep 9, 2004 | 07:49 PM
HERO's Avatar
Clutch Play?
Hi all. I was wondering if this was the case with any other 8's. My clutch pedal has about 2 1/2" (my estimate) of play at the top of the clutch. By this i mean i can press down the pedal about 2 1/2" without it having any effect. It does come back up to the top when i depress the clutch, but i still feel like that top portion isnt doing anything.
Sorry for the bad explanation, but anyone have any thought on this? :o
Old Sep 9, 2004 | 09:52 PM
RUmble's Avatar
I noticed on my test drive that the clutch has a lot of distance. I hate that.
Old Sep 9, 2004 | 11:18 PM
B-Nez's Avatar
Well technically what you describe is not necessarily free play. Free play would be where the pedal moves and excessive distance before moving the piston in the master cylinder. What you describe sounds more like a long throw, which yes my RX-8 also has. The way to tell is to get your head down there with a flashlight and measure. I can give you the exact procedure from the shop manual, if you like, but it sounds like nothing different than what the rest of us are experiencing. Also, you can have a buddy look under the hood while you press the pedal and observe what the slave cylinder is doing.
Old Sep 10, 2004 | 12:51 AM
Soundave's Avatar
Decepticon
I kinda like it. It was the same on my old FC, so maybe I'm just use to it.
theblinkof
Oct 4, 2023 05:24 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
GARCIAC951
Sep 10, 2015 07:17 PM
