View Poll Results: Which would you do off the line on the Drag strip?
Drop the clutch with some throttle
7.14%
gradually release the clutch
92.86%
Voters: 14. You may not vote on this poll
Drop or gradually release?
Old Sep 2, 2004 | 10:58 PM
TORacing's Avatar
Which is better for the clutch when taking off in a drag race dropping it or letting it off slowly? Which is better with achieving an advantage in the race dropping or letting it slowly? Which do you do, in race conditions off the line of course?
Old Sep 3, 2004 | 12:03 AM
wakeech's Avatar
mostly harmless
slipping the clutch before you hit green is obviously the only way to launch to get the best time.
Old Sep 3, 2004 | 01:13 AM
IZoomZoomI's Avatar
Boost needed
ouch that would kill the clutch... not going to argue with the method tho.
Old Sep 3, 2004 | 11:10 AM
TORacing's Avatar
well, i'm looking for a way to achieve both advantage and keeping my clutch.
Old Sep 3, 2004 | 01:02 PM
epitrochoid's Avatar
Riot Controller
dropping the clutch wont hurt the clutch, its better for it then slipping it is. repeatedly doing it WILL however completely destroy everything behind the clutch. transmission, driveshaft, rear end, axles. those aren't designed to wear out like a clutch is and are much more expensive to repair. if you drop the clutch you wont get a decent launch anyway.
Old Sep 3, 2004 | 01:15 PM
Astor's Avatar
They Come At Night
I smell clutch just reading this, but really, the only way to prevent wheel hop is to let it slip, a clutch is cheaper to replace than tranny, dif, axle, etc.
Old Sep 5, 2004 | 06:53 PM
RotorManiac's Avatar
Absolute Rotary Madness
so, its better to drop it, isn't it? I mean, you might lose some time spinning the wheels, but the damage will be smaller, right.
LB2739
Jul 9, 2019 02:25 AM
XianUnix
Sep 29, 2015 03:48 PM
Jb4ker96
Sep 27, 2015 10:06 PM
Trekk
12
Sep 25, 2015 03:08 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
