You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join RX8Club.com today!
Hi all, I was wondering what the diff between the stock exhaust and the mazdaspeed exhaust is? Does the mazdaspeed have bigger piping? Louder sound? Better performance? Diff design? Also would an aftermarket exhaust, such as the RB, void the warranty? Appreciate all the help!
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on RX8Club.com!
This has all been covered, I think, but I'll go ahead and try to answer. The Mazdaspeed exhaust has bigger tips from what I've heard and makes a "sportier" sound. Most intake/exhaust mods don't do much, and some even reduce power.
Aftermarket exhausts void the warranty on the part you replace. If Mazda can prove that the aftermarket part caused some other part to fail, then they won't fix it under warranty. For example, if you install and intake that had a metal filing generator that dropped metal filings into the combustion chamber and it caused the engine to violently explode, everything destroyed in the explosion would not be fixed under warranty because the intake caused the explosion. That's not likely to happen (as a metal filing generator would be worthless on an intake due to the potential damage), but just an off-the-wall example.
Haha. I was going to respond to this first, but Futurama is on. :D
Some exhausts may lose in peak power, but they may make up for it low-speed and/or average power gain. It's up to you where you want to make power. Exhaust tuning is very weird for the novice enthusiast, but it follows simple fluid principles.
Tips are the same size as OEM. It's only slightly louder than stock.
See my signature for my Mazdaspeed modifications.
__________________ Present: 2006 BMW X3, Silver Gray Past: Sunlight Silver, 4AT, Grand Touring Pkg., 6-disc CD changer Genuine Mazda stuff: Front air dam, front and rear splash guards, pearl satin fuel door, aluminum pedals Mazdaspeed stuff: Exhaust, Front and Rear Strut Bars, Front and Rear Sway Bars, Springs and Shocks JDM stuff: J-Spec fender strakes, J-Spec clear corners /// Other stuff: tint
Hey 310Guy, is the Mazdaspeed exhaust worth the $$ in terms of the exhuast note and performance. My dealership told me that it was in the neighborhood of $900 just for more or less a muffler and tips.
Chad
'04 RX-8: Winning Blue, 6MT, all options exc. navigation, 14% Solar Gard Quantum tint all around, clear corners, exhaust finishers, all exterior bulbs LED, rotary stem caps, EVO-R CF painted eyelids, and more to come.....
